ptcruiser Posted July 29, 2009 Share Posted July 29, 2009 (edited) Hi Folks I'm new around here but the group build got me intersted! Here's what I intend to complete. I've had the kit knocking around for some time: and the intention is to produce this classic: First issue will be replacement wheels! Hope to catch up with some of you at Donington on Sunday Rich Edited July 29, 2009 by ptcruiser Link to comment Share on other sites More sharing options...
Rallychef Posted July 29, 2009 Share Posted July 29, 2009 welcome aboard Rich, very different from the builds put forward so far, never the less a winner of the 1951 RAC rally, so I look forward to seeing your build progress Regards Ian D Link to comment Share on other sites More sharing options...
keefr22 Posted August 4, 2009 Share Posted August 4, 2009 Looking forward to this one! Keef Link to comment Share on other sites More sharing options...
ptcruiser Posted August 5, 2009 Author Share Posted August 5, 2009 Ok so what do we get? Main body has a serious mould line that will need sorting And hiding in amongst the sprues were these little beauties, no need to scratch build them now! No mention anywhere on the box they were included. I saw NUB 120 at the Silverstsone Classic in July but had not seen this GB at that point. So in order to get the reference I took a quick trip to the Jaguar And Daimler Heritage Trust at the Browns Lans, Coventry site. And there she sits in all her splendor! The staff are very helpful and my thanks for them to total access (just not allowed to sit inside). Many other classic and famous Jags to be seen, well worth the trip. Anyway, a taster of things to do/to come: Dashboard: The Bonnet is going to prove interesting with those louvres, but I have a plan! some general shots of things to do! Rich Link to comment Share on other sites More sharing options...
little-cars Posted August 5, 2009 Share Posted August 5, 2009 Knock off hubs, and louvered bonnet takes me back.... I'll be interested in seeing how you recreate the louvers. Link to comment Share on other sites More sharing options...
Nick Belbin Posted August 10, 2009 Share Posted August 10, 2009 Lowvry bonnet . . . Rodders? Link to comment Share on other sites More sharing options...
grufsnik Posted August 13, 2009 Share Posted August 13, 2009 (edited) Gods what a gem , ime watching this one, what a beauty. All the best with that bonnet, it would send me a bit loopy i think. Grufers Edited August 13, 2009 by grufsnik Link to comment Share on other sites More sharing options...
ptcruiser Posted August 28, 2009 Author Share Posted August 28, 2009 OK, I've actually made a start now. First thing on the instruction sheet was the engine block, so this is what I'm starting with, and I didn't like the moulded in starter motor or oil filter. The coil has to move anyway and the dizzy is pants! Off they came, after first filling in with Sqadron white putty. I've lost one of the block plugs but theat will be added back once I'm happy witht the rest of the filling & sanding. I've managed to keep the Jaguar logo on the block which will be highlighted later. Whilst the putty was out I filled in the chassis rail which will be visible with the bonnet open. And a couple of sink marks on the diff. Also had a first pass at the main body mould line, which showed up some sink marks at the front end, filled and sanded back. Link to comment Share on other sites More sharing options...
keefr22 Posted August 28, 2009 Share Posted August 28, 2009 Good start! Looking forward to seeing the finished engine! Keef Link to comment Share on other sites More sharing options...
Rallychef Posted August 29, 2009 Share Posted August 29, 2009 Nice start Rich, looking forward to seeing some more regards Ian D Link to comment Share on other sites More sharing options...
ptcruiser Posted September 7, 2009 Author Share Posted September 7, 2009 (edited) Hi folks, A bit of an update. Insides of the main interior body pannels cleaned up and superfluous mouldings removed. I've taken out the door panels as on the real one they were too. Carved off the door pull cord that will be replaced later and open up the attachment hole too. In the engine bay the diagonal bars should actually attached the radiator and the 'pot' on the nearside is a duplicate of the offside, in case you wanted a lhd version. Also added in a couple of extra locating pieces for the new bulkhead (see below) Moving on to the engine, a bit of before and after. Carved off the starter, oil filter, coil and dizzy and replaced those with ones turned up from sprue. Ignition leadds from stripped telephone wire, using the outer casing as boot covers. Also picked out the Jaguar logo on the casing. Colours used a combination of Alclad, Humbrol metalcoat and enamel and Tamiya paint stick. A bit of a compromise with the air filters as there isn't enough room between the carbs and the body pannel to fit deeper ones, but these should give the right impression. I've truncated the exhaust headers ready for the twin pipes that run the full length of the car as opposed to the 2 into 1 provided in the kit. An idea of other engine bay mods. The bulkhead is not wrong for most types, but is for NUB 120. This may be down to this car being an early aluminium body as opposed to later steel bodied ones? Still needs a bit of tidying up, but basically removed the angled area where the bonnet mounts are. The lower bulkhead in the kit parts feature the cabin heater matrix (not used) fuse box (hidden beneath another cover) and I don't know what the device on the off side is supposed to be, but it's not on NUB, so all in all it was easier to replace the kit part and start from scratch Next stage is to figure out the wheels so that I can get the suspension right, before I can fix the interior and the engine.....I hope you enjoy Rich Edited September 7, 2009 by ptcruiser Link to comment Share on other sites More sharing options...
keefr22 Posted September 10, 2009 Share Posted September 10, 2009 Nice update, she's looking good! Keef Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted September 10, 2009 Share Posted September 10, 2009 Nice work Rich Link to comment Share on other sites More sharing options...
Rallychef Posted September 12, 2009 Share Posted September 12, 2009 Nice work Rich, regards Ian D Link to comment Share on other sites More sharing options...
ptcruiser Posted October 1, 2009 Author Share Posted October 1, 2009 Well here's the Jag's dash. Top was where it started, middle is where it needed to go, bottom where it's at. The timing clocks were made from aluminium tube with sprue cores to pack it out. The dials were re-drawn and scaled down and printed on clear decal sheet. The printing is too fine, but be assured they're as close to the real thing as you can get! Just one other note, the kit decal placement guide is for a LHD version... Not happy with the dial below the dash, should have printed another off whilst I was at it. Will get another before it's fitted. The red swith to the right hand of the dash is for a modern manual radiator fan. Apparently even in the time of eventing the car overheated, hence the bonnets louvres - the next installment.... Enjoy Rich Link to comment Share on other sites More sharing options...
keefr22 Posted October 1, 2009 Share Posted October 1, 2009 Looks good Rich! Can't wait to see how you deal with the louvres....! Keef Link to comment Share on other sites More sharing options...
T-Tango Posted October 1, 2009 Share Posted October 1, 2009 Coming along really well Rich. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted October 1, 2009 Share Posted October 1, 2009 Nice work. Link to comment Share on other sites More sharing options...
ptcruiser Posted October 14, 2009 Author Share Posted October 14, 2009 Here's some pics for the Jag. A bit of frustration with the bonnet, 1st pic was version 1, copied the original with two layers of 6mm Tamiya tape onto tin foil (the type you get from takeaway trays). Used the original to form the shape, cut small darts into the compound curves around the nose, filled the ridges with Liquid Filler and then tried to cut the louvres in. Pants. 2nd is version 2 where I cut the louvres before forming the shape. Better, but need to be neater with the louvres... 3rd still to be done, but learning all the way! However, good news as the wheels arrived today, so everything else can now move forward! The kit wheel sits in the middle for comparison Rich Link to comment Share on other sites More sharing options...
keefr22 Posted October 14, 2009 Share Posted October 14, 2009 Interesting idea for the bonnet Rich, looking forward to seeing attempt 3! Hope it works out OK as I have an Airfix Stratos that I've ruined by trying to 'modify' the bonnet louvres!! I'll happily steal your idea if it works like it should! How are you actually cutting the louvres? Looking forward to seeing those wheels when they're together too! Keep going! Keef Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted October 14, 2009 Share Posted October 14, 2009 I'm liking this Link to comment Share on other sites More sharing options...
ptcruiser Posted October 23, 2009 Author Share Posted October 23, 2009 Update on the Jag: Wheels: parts (Profil24) Built test run. Just need to add the drum brakes behind: Kit exhaust Replaced with twin pipe as it should Still working on those louvres! Enjoy Rich Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted October 23, 2009 Share Posted October 23, 2009 gosh those wheels are the dogs, very nice indeed Link to comment Share on other sites More sharing options...
keefr22 Posted October 23, 2009 Share Posted October 23, 2009 Really nice rims Rich, I like those! Still looking forward to seeing those louvres!! Keef Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted October 23, 2009 Share Posted October 23, 2009 Nice work Rich, those wheels to look good Link to comment Share on other sites More sharing options...
