Oily Posted July 26, 2009 Share Posted July 26, 2009 (edited) This is my 'home made' compressor to power my Premi-Air G35! This is an Angel Air paintball air bottle,1.5 litre rated at 4500psi.It has a digital regulator so i can set the psi really accurately.This is connected via a piece i made at work some time ago to the water trap/regulator but seeing as the air we use is filtered(bottles filled from dive centres) i can't see it catching much!! Here you can see the output pressure,set at 110psi Here you see this regulator set at 10psi All in all i'm very pleased with it and its save me a small fortune.Having been to RDG Tools to pick up the reg+hose,i saw the compressor i was going to buy on the shelf,it's tiny!! No wonder they get hot. ps,if the picture on the tank insults anyone then i'll take it down Edited July 26, 2009 by Oily Link to comment Share on other sites More sharing options...
AdriaN (MLT) Posted July 26, 2009 Share Posted July 26, 2009 10psi? doesnt the paint come out in blobs? Link to comment Share on other sites More sharing options...
Oily Posted July 26, 2009 Author Share Posted July 26, 2009 10psi? doesnt the paint come out in blobs? It was just to show it working,that's all I'm using Alclad2 which needs to be sprayed at 15/20psi Link to comment Share on other sites More sharing options...
AdriaN (MLT) Posted July 26, 2009 Share Posted July 26, 2009 It was just to show it working,that's allI'm using Alclad2 which needs to be sprayed at 15/20psi I spray everything at 20psi Link to comment Share on other sites More sharing options...
