Iain Ogilvie Posted May 8, 2011 Author Share Posted May 8, 2011 Been carefully marking out positions and sizes of fuselage windows: Holes so far drilled out to 7mm and 8mm - the latter will be opened out to 10mm diameter. Have used wood drills as these give precision placement on the plastic and a power driver as this turns at far lower speeds than a drill and prevents heat/plastic melting around each hole. The nose gear bay all marked out and exactly 2.25 times larger (linear) compared to the Heller 1:72 kit. Need to pour over photos now before I make the cuts to ensure all is good with regard to juxtapositions of windows/doors etc.. More later in the week... Iain Link to comment Share on other sites More sharing options...
Radleigh Posted May 8, 2011 Share Posted May 8, 2011 Good lad Iain Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 9, 2011 Author Share Posted May 9, 2011 (edited) Tonight I have mostly been collecting more images of the Wright R-3350 Duplex-Cyclone engines. Don't suppose anyone knows where I can find a set of scale drawings for these engines? Need to keep the enthusiasm going now but it feels like we may just be getting on a roll - hopefully an un-stoppable one. Iain Edited May 9, 2011 by Iain (32SIG) Link to comment Share on other sites More sharing options...
ollieholmes Posted May 9, 2011 Share Posted May 9, 2011 Try contacting any of the people who still fly a Connie, i would think they may have something. Link to comment Share on other sites More sharing options...
youngtiger1 Posted May 10, 2011 Share Posted May 10, 2011 That is a monster of a kit. I want to know were will you put it...onces it is complete? ...lol Very nice work...keep it coming. Mike Link to comment Share on other sites More sharing options...
Mark M Posted May 10, 2011 Share Posted May 10, 2011 iain its the first time ive seen this you are MAD!!! BUT I LIKE IT Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 10, 2011 Author Share Posted May 10, 2011 (edited) Try contacting any of the people who still fly a Connie, i would think they may have something. Hi Ollie - have made some contacts - was just wondering if anyone had anything lying around That is a monster of a kit. I want to know were will you put it...onces it is complete? Cheers Mike - live in an old barn and I have a couple of garages with mezzanines - at some point I'll make some deep cabinet space (*very* deep ). Alternatively would look nice in a very large glass coffee table (the type that's like a large flat display case) - but would probably be frowned upon by higher authority iain its the first time ive seen this you are MAD!!! Awww - you say the nicest things Mark (and I prolly have to agree!!) Does mean that I haven't got much further with my two Hawks in the past week - mia culpa. Planning some high level plastic chopping tonight when I get home Iain Edited May 10, 2011 by Iain (32SIG) Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 11, 2011 Author Share Posted May 11, 2011 (edited) Well - I appear to have mislaid a bunch of Constellation books I'd amassed - so need to make some purchases again. But I have found an original service manual for early Connies I had tucked away from when I started - some great drawings in there which will help hugely. Also found original manual for the R2800 I had stashed away - pity it's the wrong engine! So if anyone out there is rebuilding one? Tonight I've been neatening up the drilled windows and checking the nose gear bay mark out before cutting. Good job I did 'cos I had it marked out 6mm too far forward - so fixing that now. Hopefully more pix at the weekend. Iain Edited May 11, 2011 by Iain (32SIG) Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 14, 2011 Author Share Posted May 14, 2011 Been spending a little time today modding the Tip Tanks, neatening up the nose gear bay opening and cutting away the windshield area to make a master for vaccing: Tanks way too long - so marked up and Tamiya tape used to mark straight perpendicular lines. Cut with razor saw and made easier by the foam fill. Here you can see the difference Edges trued up with the 'T' bar before bonding. Thick superglue used to form a strong bond - after ensuring everything straight! Canopy area market out with tape prior to cut. Thin superglue run into the joint - just for the length of the joint surface on the area to be removed. Out with the razor saw... ... and Connie's now a convertible! Removed section will be filled with resin and shaped to produce a master pattern. Nose gear bay cut out. More later Iain Link to comment Share on other sites More sharing options...
Moofles Posted May 14, 2011 Share Posted May 14, 2011 blimey this is intense. Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 14, 2011 Author Share Posted May 14, 2011 One of the guys over on LSP wondered how it compared with an SU 27 - so here's a quick shot - along with an F-100D Iain 1 Link to comment Share on other sites More sharing options...
F111Fan Posted May 14, 2011 Share Posted May 14, 2011 HOLY CRAP, THAT THING IS MASSIVE! Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 14, 2011 Author Share Posted May 14, 2011 OK - last before bed - all a bit rough - nothing a session with sanding sticks shouldn't cure - but should start to make some more serious progress from now on... Crew entry door cut out... Lines up nicely with internal floor! Foam section under floor - marked out to show nose gear bay cut out. This area will be removed so that the gear bay can be boxed in. Start made on canopy pattern - lots of work to be done! Pattern filled with resin to provide stable base for shaping. Maybe some more tomorrow... Iain Link to comment Share on other sites More sharing options...
jimbuna Posted May 14, 2011 Share Posted May 14, 2011 Absolutely incredible....a veritable monster!! Link to comment Share on other sites More sharing options...
yardbird78 Posted May 15, 2011 Share Posted May 15, 2011 Your work on that monster Connie is beyond words to describe it. I am deeply impressed. Darwin Link to comment Share on other sites More sharing options...
ancient mariner Posted May 15, 2011 Share Posted May 15, 2011 More nagging!!! Hurry up or they will have finished the "real thing" Link to comment Share on other sites More sharing options...
smyfe Posted May 15, 2011 Share Posted May 15, 2011 Keep Going !!!! I love the picture in post 83, with the in scale hard standing. Mick Link to comment Share on other sites More sharing options...
Radleigh Posted May 15, 2011 Share Posted May 15, 2011 Love the signature Iain! Looks good glad I upped the thread now Great updates. Link to comment Share on other sites More sharing options...
Martian Posted May 15, 2011 Share Posted May 15, 2011 This is looking good! Keep it up! Nag nag nag nag............... Martin Link to comment Share on other sites More sharing options...
jenshb Posted May 15, 2011 Share Posted May 15, 2011 There's a lot of work, but I'm sure the end result will be spectacular. As the cockpit windows are flat, would it be easier to cut out the window shapes out of flat plasticard and then glue them together for a faceted appearance rather than filing them to shape and get them all symmetrical? You can of course still use filler and Milliput to fair them in to the overhead fuselage and smooth things out... Jens Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 15, 2011 Author Share Posted May 15, 2011 (edited) Hi folks - just about to start work again Hopefully you don't mind me flooding the forum with updates - it kinda keeps me going as I feel I have to feed the thread with new stuff. Building something like this it's not individual areas that are difficult - it's keeping overall inspiration/interest up. Hoping this thread will keep fueling progress! I doubt anyone else out there wants to have a go at the same project - but hopefully it might inspire some to have a go at vacs/scratch building. Jens - my first plan was to make the windshield with plastic sheet but the moulded shape around this area needs correcting anyway and I was concerned about getting everything perfectly lined-up. Making a solid pattern gives me the chance to do a lot of fine tuning to get the shape and angles all correct - the cockpit needs to look right as it's such a feature. Have a share in an industrial grade vac machine - so will make pattern then make a female mould and vac into that so that external edges are sharply defined. On build - one of the panes will be opened up as the Connie had an opening pane on both sides of the cockpit. Iain Edited May 15, 2011 by Iain (32SIG) Link to comment Share on other sites More sharing options...
jenshb Posted May 15, 2011 Share Posted May 15, 2011 What I meant was to make the windows for your mould from flat plastic to ensure they are the same sizes and shapes between left and right and that the panes end up being sharp while the windows being flat. I always find it difficult to file consistent, flat faces, but maybe that's me:) Jens Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 15, 2011 Author Share Posted May 15, 2011 Ah - got you - that's a great thought - I think I'll try that! Iain Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 15, 2011 Author Share Posted May 15, 2011 OK - change of plan today - wanted to start correcting the wings - for span and nacelle spacing. First step was to remove the nacelle fairings - each one was a slightly different shape and not a constant fairing into the wing mouldings. Decided to be brave and remove completely so that the wings could be made perfectly smooth and constant section - before going back at some point to the fairings and reshaping before re-fitting. Sounds extreme, but hopefully will make sense. Ooops - and the wings are un-equal at the roots! Upper wings - nacelle fairings removed. Wings marked up (very carefully) and a plan concocted. Will get upper sections sorted first - then worry about undersides which will also need flap areas cutting out. The areas where fairings removed squared off to make it easier to fill the hole with plastic sheet. Just working out how much the wings need extending - verdict a nice round 25mm. Wing leading edge extended the 25mm with section separated along a line parallel with the leading edge that results in a nice square elongated opening where the nacelle fairing was. Both wings extended and drying before I blank off the gaps from behind with more plastic sheet. More soon... Iain Link to comment Share on other sites More sharing options...
ollieholmes Posted May 15, 2011 Share Posted May 15, 2011 Your making good progress there. Link to comment Share on other sites More sharing options...
