KiwiSteve Posted April 20, 2009 Share Posted April 20, 2009 I'm using the Tamiya 1/48 F4U-1 Corsair to build a early F4U-1D Corsair serving with the RNZAF in the Pacific theater. I've finally managed to find the image I wanted of a Kiwi Corsair a F4U-1D (NZ5482) of 3 Service unit based out of Jacquinot Bay, East New Britain PNG in 45. This will be the look that I'm trying to go for the faded and heavily weather sea blue with replacement panels in non-matching colours, I might have to use a little artistic license seeing as this is the only pic of the aircraft that I have I'll be using Venture 1/48 V4880 RNZAF Corsairs Pacific Theater Decals and Ultracast Corsair wheels which are very nicely cast. Progress so far Side walls Engine Cockpit A bit more progress on the fuselage, you've gotta love these tamiya kits the wing root joins was almost perfect Link to comment Share on other sites More sharing options...
Red Dragon Posted April 20, 2009 Share Posted April 20, 2009 The outer wing panel fit can be "interesting". Phil Link to comment Share on other sites More sharing options...
Silver Fox Posted April 21, 2009 Share Posted April 21, 2009 The outer wing panel fit can be "interesting".Phil I found the best way for me to achieve a good outer to inner wing fit was to leave out the wing bulkhead on the outer panel and not to use the short spars. This gave a little give when assembling whih really helped. Looking good so far, the Ventura decals are really well produced and I like the roundel colour which possibly capture the fading prevelant in the SW Pacific. Link to comment Share on other sites More sharing options...
Calum Posted April 22, 2009 Share Posted April 22, 2009 Great work on that pit. Link to comment Share on other sites More sharing options...
Mike Posted April 22, 2009 Share Posted April 22, 2009 Good work so far Steve... keep it up Link to comment Share on other sites More sharing options...
Alan P Posted April 22, 2009 Share Posted April 22, 2009 Cracking start Steve, your interior green is a very good colour, did you mix it yourself? Link to comment Share on other sites More sharing options...
KiwiSteve Posted April 22, 2009 Author Share Posted April 22, 2009 Cracking start Steve, your interior green is a very good colour, did you mix it yourself? It's Xtracrylixs XA1117: Interior Green (FS34151) the cockpit was preshaded then the base colour airbushed then shadows sprayed in, next a wash and finally the ribs where highlighted with the base colour to make then stand out Link to comment Share on other sites More sharing options...
AnonymousER99 Posted April 22, 2009 Share Posted April 22, 2009 Excellent work so far Steve!! Love those NZ markings too Link to comment Share on other sites More sharing options...
KiwiSteve Posted April 26, 2009 Author Share Posted April 26, 2009 Some more progress, shes ready for a coat of primer and then onto preshading and fading. Just a quick drop tank question, what colour should I paint them white or light grey?? Link to comment Share on other sites More sharing options...
Martian Posted April 26, 2009 Share Posted April 26, 2009 This one looks very interesting. Martin Link to comment Share on other sites More sharing options...
Pete M. Posted April 28, 2009 Share Posted April 28, 2009 Hi Steve. Just a quick couple of notes to help with your build. As NZ5482 was an F4U-1D, the cockpit sidewalls above the side consoles should be black. The drop tanks would have been white. Check out my build of 'Lil Audry' also of No.3 SU using a photo from the same sequence as that you have posted. http://rnzaf.hobbyvista.com/rnzafmod.html It's about 1/3 down the page. I'm doing a major refurbishing of my site at the present time, and hope to have it all updated within the next couple of weeks. Still no Corsair pages other than my No. 14 Squadron ones, but I'm working on it! Hope this helps, Pete M. Link to comment Share on other sites More sharing options...
KiwiSteve Posted May 2, 2009 Author Share Posted May 2, 2009 Some more progress mainly the pre fading and shading paying particular attention to the fabric areas seeing as they tended to faded rather fast. Also painted the int blue on the replacement rudder as well as painting the drop tanks, they should be white. But I'm trying out something to see if it works, what I've done is preshaded nato black, base colour Lt gray and then I'll post shade patchy white. Sorry the pics are a little dark. Pre shade and fade Int blue on the rudder Cowl, flaps and drop tanks And the prop Link to comment Share on other sites More sharing options...
KiwiSteve Posted May 2, 2009 Author Share Posted May 2, 2009 Cheers guys, paints on the shading and fading is pretty much finished, the preshaded worked really well on the fabric surfaces, with the post fading working well on the upper surfaces. Link to comment Share on other sites More sharing options...
Mike Posted May 2, 2009 Share Posted May 2, 2009 Scratching my chin on this one at the moment Steve... Are the last lot of pics overexposed so we can see the subtleties of the paintwork? Judging by the pale cutting mate, I'd say yes. Any chance of some more pics with a more standard exposure? Overexposing tends to mess with the color a little bit, and it's making the blues look a bit purply on my monitor... Mind you, it could just be my tired eyes You're not bad at this modelling lark, are ya? Link to comment Share on other sites More sharing options...
KiwiSteve Posted May 3, 2009 Author Share Posted May 3, 2009 (edited) You mean like using the flash Mike Hows that matey better Edited May 3, 2009 by KiwiSteve Link to comment Share on other sites More sharing options...
darson Posted May 3, 2009 Share Posted May 3, 2009 Steve great looking progress there she looks great. I think the way you've painted the kit up should really match the original photo when it's done. Also, forgive me if you are planning this already but if an aircraft is carrying two different sized drop tanks like that then smaller of the two was filled with Napalm and normally painted yellow so it could be identified by the ground crew. Cheers Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted May 3, 2009 Share Posted May 3, 2009 lovely work there steve, great painting Link to comment Share on other sites More sharing options...
KiwiSteve Posted May 6, 2009 Author Share Posted May 6, 2009 Ventura Decals are on just waiting for some yellow numbers to finish up, but while I've been waiting I've started to add the paint chipping If your wondering the reason the upper port and lower stbd decals look abit rough, thats ventura replicating the ground crews over painting the US markings when they received the planes. Link to comment Share on other sites More sharing options...
Silver Fox Posted May 7, 2009 Share Posted May 7, 2009 Looking godd mate, nice and grungy. Link to comment Share on other sites More sharing options...
Angels49 Posted May 7, 2009 Share Posted May 7, 2009 A cracking build Steve.., but you're cheating mate, you 'ave a piccie to look at..... , wait a tic...that's what we all do....Ok It's just that you are quite brilliantly making an exact copy....'urry and finish mate I'm liking this one much!!! Link to comment Share on other sites More sharing options...
