Iain Ogilvie Posted May 23, 2009 Author Share Posted May 23, 2009 (edited) OK - Busy day today - and I'll start by admitting I'm cheating with this GB and have a 'helper'... Son Cameron - aged 25 months - loves the 'airplanes' in daddy's cabinets and. well, wanted to help... So - starter for 10 - Camerons' contribution to the project today: I suspect he'll grow up to me a modeller - and like flying things Iain Edited May 23, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 23, 2009 Author Share Posted May 23, 2009 (edited) OK - The constructive stuff: Started the day by cutting out and prepping the inner wing areas - and following the theory that a picture speaks a thousand words: Yes - daylight - sanded to perfection Wanted to add a little more strength to the front joint - so guess what? Nah - you weren't even close... I surprised myself and decided to use some casting resin - so more masking tape to form a mould - and - whilst I was at it - I thought I'd sort the front engine bulkhead on the fuselage: Ready for resin.... Iain Edited May 23, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 23, 2009 Author Share Posted May 23, 2009 (edited) To mix the resin my favourite method for small amounts is to use a clear 35mm film canister - and pour equal amounts of each liquid - they don't initially mix - as you can see - which helps hugely. Lid on - a good shaking - then pour... And here's the result on front fuselage after attacking with the bar sander: Wing inner sections leaked - so I quickly poured off the excess - removed the tape - and cleaned up the inside leaving a small amount of resin inside the joint which should suffice for now... Iain Edited May 23, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 23, 2009 Author Share Posted May 23, 2009 (edited) On a roll - I decided I'd prep the tail fin: And bonded the respective halves together using Plastic Weld... Got carried away - and prepped the horizontal stabilisers: Then thought - oh Phuket (yes - of course I mean that place in Thailand...) In for a penny - in for some wings... First off - trim the trailing edge 'step' with scalpel - carefully scoring from the inside: Followed by a loooooooooooooooooooooooooooong session with the sanding bar - and this is where we are: More news when there's, erm, more news I guess! Have fun! Iain Edited May 23, 2009 by 32SIG Link to comment Share on other sites More sharing options...
HOUSTON Posted May 23, 2009 Share Posted May 23, 2009 hEY Iain, it is coming along just nicely and I see you have gotten your little boi Cameron to help you too.. Hmm Geez!! you start them young dontcha!!! I am enjoying following this thread very much.... HOUSTON... Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 24, 2009 Author Share Posted May 24, 2009 (edited) Cheers Houston... He's been sat watching today - mesmerished. Keeps shouting 'Daddy's Airplane' Anyhoo - a little progress today - started on bulkheads and getting everything ship shape... Firstly - I'd previously cut a section out from the fuselage at the base of the rudder as the moulding was poor and didn't line up - so first step to square everything up with a scalpel: Next - couple of pieces of 20thou sheet glued in place: After the Plastic Weld had 'gone off' - not long in today's sunshine - trimmed roughly with sprue cutter - then scalpel - then sanding stick: Now - stuff Ive been putting off - I hate making bulkheads that fit! First one - the bulkhead next to the door - as this on is a certain position and can formm a reference point for others behind. Base easy as it forms a square the same width as the floor: Lines were then marked where bulkhead was inline with the base of the roof. To get the curve in the roof I dug out my trusty profile guage - and pre-set the available 'prongs' to the width of the fuselage - so minimise distortion of the roof section when I took the profile: Profile was taken and transferred to my bulkhead 'blank': Bulhead then trimmed and sanded - and hey presto: Even better - she fits perfectly with floor and the rest of the fuselage: Now that fits - time to mark out the door and cut out: Opening made and neatened up - time to add some corrugations - firstly on the back. Cut oversize, bond, trim back... And here I've started detailing the front: Now full of coffee and planning another few hours tonight as I don't have to go to work in the am Have FUN! Iain Edited May 24, 2009 by 32SIG Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted May 24, 2009 Share Posted May 24, 2009 Most admirable work Iain but now we know it is really Cameron that does the modelling! you just hold the plastic for hinm to take the piccies! looking excellent any road Link to comment Share on other sites More sharing options...
Mike Posted May 24, 2009 Share Posted May 24, 2009 Nice job of the bulkhead Iain... Caz reckons your lad's cute Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 25, 2009 Author Share Posted May 25, 2009 (edited) Cheer folks - am a little biased - but I think he's a good lad OK - a little more... But first a question - is this too many pictures? Or is it useful? Don't want to bore peeps with unnecessary updates - but it's also my driver - i.e. I feel I have to make regular progress and post or I'll feel guilty - and this in turn is driving me forward... Hope that makes sense? Anyhoo... Rearmost bulkhead - nice and tight - and straightens up back end a treat: Another bulkhead in place - still needs detailing and is also sitting a little high here - that's coz the floor is springy! Roof on - starting to get 'interesting' Removed canopy in place (exactly same as clear vac) - but shows there's a Ju-52 lurking in there somewhere!! And finally for tonight - measure three times - mark three possible locations - check plans, check 1:48 Revell kit - move again - check - and CUT - the opening for the dorsal gun position: That's all for tonight folks - I need zzzzzeeeeeeeeeeds... And NO Blimp - great photo - but I ain't changing course with a seaplane version now! Have fun... Iain Edited May 25, 2009 by 32SIG Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted May 25, 2009 Share Posted May 25, 2009 Rearmost bulkhead - nice and tight - and straightens up back end a treat: steady on Iain - this is a family show Carry on up the Junkers :swanneewhistle: Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 25, 2009 Author Share Posted May 25, 2009 (edited) OK - a little progress so far today - measuring up and creating two rather substantial wing spars from 60 thou sheet: And now I need your help! Had assumed there was one square opening above the lower gunners 'bin' - but looking at the Revell parts I'm guessing there are two - one above the bomb aimer's fairing (square) and one above the bin - a larger shape... Can anyone confirm as I'm about to cut slots for the spars and create some 'interior' around this area... The Revell parts: It's the two areas to cut out 'between' the bomb bays (marked B on the mouldings) that I need confirmation on - assuming I need to cut both out and one spar running between the two? 'cos it looks like a square here: Any pointers really appreciated! Iain Edited May 25, 2009 by 32SIG Link to comment Share on other sites More sharing options...
blimp Posted May 25, 2009 Share Posted May 25, 2009 hi Iain , the rear cut out is the 'recess' for the dustbin in it's retracted position . - i not sure it's quite that shape though , reckon it's a bit narrower . note how the edges of the hatches follow the fuselage longerons , pictures don't help so i'll have to see how it all 'hangs' when i do mine . Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 25, 2009 Author Share Posted May 25, 2009 (edited) Cheers Blimp, That last pic I posted appears directly abover the bin - and looks square to me... That larger panel looks more like the ventral 'luggage bay' used on the airliner? <scratches head> I'm going to do a dry assembly of the Revell parts and see if I can work this out... Relaxing hobby.... Pah... Iain Edited May 25, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 25, 2009 Author Share Posted May 25, 2009 (edited) Having looked at everything I have I'm pretty convinced Revell have got it wrong - and the square hatch needs to be moved back so that it's front edge lines up with the front edge of the larger cutout marked on the Revell parts... This then gives a single square opening above the 'bin' - in the right place - and no opening above the bomb aiming kit. The photo we have of the interior only shows one hatch on the floor - the detail above shows one square cutout directly above the 'bin' and the pick we have of the ventral bin from the side appears to support this... There - I've convinced myself - I think... Iain Edited May 25, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Mike Posted May 25, 2009 Share Posted May 25, 2009 There - I've convinced myself - I think... Iain Do you actually need us for this conversation, or is it just you and your personalities having a chat? Link to comment Share on other sites More sharing options...
blimp Posted May 25, 2009 Share Posted May 25, 2009 (edited) hi mike , sorry squire . - the bin retracted , it does go into the belly , but only the edge of the curve , so i reckon the revell/monogram version is too wide . it is a very snug fit to miss the aft spar [/left] as for spars Iain , there are plenty to choose from [ ( you can use the centrelines of the window pillars as datums ) Edited May 25, 2009 by blimp Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 25, 2009 Author Share Posted May 25, 2009 (edited) Do you actually need us for this conversation, or is it just you and your personalities having a chat? Erm - did you hear something? No - why - did you... Erm - I though you realised you were running a Care in the Community programme? Blimp - thanks - I think I've got it sussed now Bear in mind the underside will all be re-skinned in currugated sheet... Hatch marked 'actual size': This year my analyst says I'm allowed Power Tools - so - break out Dremel (and face mask) - circular saw: Next tool: Cutting through resin fro reverse - it's a bit thick! Hatch opened out 2mm all round to allow for the plastic thickness for the 'internal detail' box I'll be making. Slots for spars marked up and clamped in workmate: Half an hour widening slots with file - and Bobs yer Uncle - just need to tweak slightly: Next step is to mark out and cut slots in the spars to allow the floor to sit at the right height. All for now folks - must run - have a joke I've been dying to tell myself! Iain Edited May 25, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Mike Posted May 25, 2009 Share Posted May 25, 2009 You've done these big kits before, haven't you? I'd be scared to death taking a full sized hacksaw to the fuselage of anything I built... AND putting it in a vice! Link to comment Share on other sites More sharing options...
blimp Posted May 25, 2009 Share Posted May 25, 2009 . . . . and i was going to suggest using brass strip . . . too late . Link to comment Share on other sites More sharing options...
Mike Posted May 25, 2009 Share Posted May 25, 2009 Btw Iain - where do you get those neat little circular saws from? I imagine they create less heat than the traditional abrasive cutting discs that come with Dremels & the like. Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 25, 2009 Author Share Posted May 25, 2009 (edited) Btw Iain - where do you get those neat little circular saws from? Can't remember exactly - I think it was a Poundstretcher type shop - wasn't expensive. Yes - it's a lot better than the cutting disks - especially on resin... About the thickness of a razor saw: This is the set: Just packing up for the day - and lots of chores not done yet... Still - I think I'm making progress - just over two months to go in the GB - we may just make it yet! In the words of Rolf Harris - 'Can you tell what it is yet?' Couldn't resist taping some parts loosely together to get a feel for her! Looks like a Ju-52 to my eyes Iain Edited May 25, 2009 by 32SIG Link to comment Share on other sites More sharing options...
Touvdal Posted May 26, 2009 Share Posted May 26, 2009 Lookes like a Ju-52 , but you still have a long way. I have follow your progress and work metods, facinating cheers Jes Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 28, 2009 Author Share Posted May 28, 2009 I have follow your progress and work metods, facinating Hi Jes - I hope you realise I'm making it all up as I go along! Iain Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted June 4, 2009 Share Posted June 4, 2009 (edited) Hi Jes - I hope you realise I'm making it all up as I go along! i thought making it up as you go along is what model making was all about well done Iain as Jes said, a fascinating project to watch! Edited June 4, 2009 by walrus Link to comment Share on other sites More sharing options...
blimp Posted June 4, 2009 Share Posted June 4, 2009 INNOVATION ! young paul , - ground breaking , the stuff of legends etc etc . seriously though , i reckon you deserve a medal for even thinking about this build Iain . capitol ,capitol . ( he's not just not just soft in the head like me ) Link to comment Share on other sites More sharing options...
