AnonymousDFB1 Posted January 17, 2009 Share Posted January 17, 2009 Right this is my third entry into the GB, complete with resin cockpit and AM decals I've made a start, by separating all the resin bits from the casting blocks Now as I I have never fitted a resin cockpit before, what is the correct sequence. I'm guessing that I should paint it up fit all the bits together and then fit it to the fuselage? I can't see how to dry fit it without putting it all together and if I try without it all being cemented together it falls apart as I try. Link to comment Share on other sites More sharing options...
bexwh773 Posted January 17, 2009 Share Posted January 17, 2009 Im no expert Sis, but Id sand the office & fuselage until you have a nice dry fit, then paint & fit Looking forwards to this one Bex Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted January 17, 2009 Author Share Posted January 17, 2009 The problem is that I can't keep the side wall or the front IP in place while I dry fit it. Link to comment Share on other sites More sharing options...
bexwh773 Posted January 17, 2009 Share Posted January 17, 2009 The problem is that I can't keep the side wall or the front IP in place while I dry fit it. tape & blue tak will sort that Sis Bex Link to comment Share on other sites More sharing options...
daz greenwood Posted January 17, 2009 Share Posted January 17, 2009 Mmmmmmmmmmmmmmmmmm Tomcat. Link to comment Share on other sites More sharing options...
Rabspat Posted January 17, 2009 Share Posted January 17, 2009 Mish, to keep it in place while you work, blu tack is the best option then sand,sand,sand till your happy. I am guessing Aries F-14D pit? You should have to sand much, also construct the Front Wheel Well as you need that in place as well to make sure you get a nice tidy fit. HTH Link to comment Share on other sites More sharing options...
Rabspat Posted January 18, 2009 Share Posted January 18, 2009 Hey Mish how did you get on with the Resin Pit? Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted January 18, 2009 Author Share Posted January 18, 2009 Studying lots of on- line tutorials and articles so I don't mess it up. Link to comment Share on other sites More sharing options...
Rabspat Posted January 18, 2009 Share Posted January 18, 2009 Mish, i discovered no matter how much reading one does you can still either do a fantastic job, or screw it up. My advice to you is just do it and take your time sand abit test fit. Sand abit more and so on till your comfortable with the fit. There is no right or wrong way when it comes to resin pits and everyone has there own style of doing one, so in away you need to find yours. Link to comment Share on other sites More sharing options...
Skull Leader Posted January 18, 2009 Share Posted January 18, 2009 Mish, I can certainly understand your caution... what the others have said is true, however. You can read tutorials until you're blue in the face, but until you actually go to try for yourself, you'll never know . the Aries pit in 1/48 isn't too hard to work with, fortunately (better than the black box/avionix one), just go slow and check things from every angle. Seeing your previous work on other projects, I know you'll be able to swing this with little trouble at all Looking forward to your progress! Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted February 2, 2009 Author Share Posted February 2, 2009 Well done a lot of sanding and dry fitting this afternoon and I think I have it all fitted. No pics as I didn't have a spare finger, it's a bit fiddly holding the whole lot together. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 4, 2009 Author Share Posted March 4, 2009 Finally got back to doing some work on this one. During fitting I managed to knock off the two 'horns' that go either side of the canopy ram. So I got the origin part and cut away the parts I needed and grafted them onto the resin cockpit. All primed up and ready for painting Link to comment Share on other sites More sharing options...
bexwh773 Posted March 4, 2009 Share Posted March 4, 2009 Looks like a good start there Sis Bex Link to comment Share on other sites More sharing options...
Andy Mullen Posted March 4, 2009 Share Posted March 4, 2009 Mish do you intend to have the canopy up or down? If down I would include this in the dry-fit process, as when I attempted this with the 1/72 Aires pit, my canopy was dipped in Klear and curing, when I fitted mine, and a few weeks later I found the pit had bulged the canpoy sill. This meant if I wanted to have a closed canopy, I would have either pry the canopy apart to fit or undo the assembly, sand the pit sides and refit. As it was, mine was having an open canopy, so wasn't as noticeable. Your were lucky you got the "horns" on yours, both my 1/48 pits I have, seem to have had them knocked off prior to packaging. Good luck Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 5, 2009 Author Share Posted March 5, 2009 Thanks Andy, as with most of my builds I will have the canopy open. But a very good point. Yes I wish Aires would revise their packaging. Link to comment Share on other sites More sharing options...
daz greenwood Posted March 5, 2009 Share Posted March 5, 2009 I love that cockpit. Very nice. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 7, 2009 Author Share Posted March 7, 2009 Little update, I've started painting the cockpit Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 9, 2009 Author Share Posted March 9, 2009 Cockpits nearly done, just a little more and the seats to paint. Link to comment Share on other sites More sharing options...
Paul - Brazil Posted March 11, 2009 Share Posted March 11, 2009 Hi! It's looking good! Everytime I build using resin sets is a headache. Best! Paul. Link to comment Share on other sites More sharing options...
marine4 ever Posted March 15, 2009 Share Posted March 15, 2009 lookin' good Mish! Can't wait to see more. Semper fi Dan Link to comment Share on other sites More sharing options...
Tedfellows Posted March 15, 2009 Share Posted March 15, 2009 There's a recession on Mish, stop using the Queens Currency as nose weights!!!! Lol Looking good is that Pit! Adam Link to comment Share on other sites More sharing options...
Areos Posted March 16, 2009 Share Posted March 16, 2009 Very nice start, Keep going!! Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 28, 2009 Author Share Posted March 28, 2009 Right back on this one again In the few hours I managed to work on er today I got the Aires cockpit all fitted and buttoned up. And started on the U/C wells Link to comment Share on other sites More sharing options...
HOUSTON Posted March 28, 2009 Share Posted March 28, 2009 Looking GOOD Mish.. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted March 29, 2009 Author Share Posted March 29, 2009 This mornings efforts Link to comment Share on other sites More sharing options...
