alex Posted January 16, 2009 Share Posted January 16, 2009 (edited) Hello there,some questions: what weapons did the RAF/RN use in the last decades, and how are they available in 1:72? (thinking mostly of the well-known Hasegawa weapon kit, maybe some kitbashing or scratching them). If anyone has some good tips how to get hold of them (cheap kits with heavy ordnance, maybe some small changes to foreign counterparts), feel free to post or PM, I will try to update and correct this list according to your input, and hopefully it will grow into a kind of usable "reference list"!Free Fall weaponsBackground: AFAIK, they didnt't use the US free fall bombs (Mk. 82-84, Snakeeyes), but only their own ones.Kits: 1000lbs: Revell Tornado GR1 (4x). Airfix Jaguar (4x) and old Hawk (4x), Hasegawa Harrier GR.5 (2x)AM: 1000lbs: Aviation Workshop (Resin / 2 pcs / £5)Bomblets dispensersCBU-87Background:Kits: Revell Jaguar RoG, (4x, but look terrible)AM: 6 of them in the Hasegawa weapon kit (X72-9)BL-755Background info: Withdrawn 2007 / 2008Kits: Italeri Harrier GR3 (4x). Hasegawa F-16 and Jaguar (2x). Airfix Jaguar (4x) and Harrier GR3 and GR5 (5x), Fujimi Alpha JetAM: ?JP-233 Bomb dispensersBackground: used on Tornados in Desert Storm 1991Kits: Hasegawa Tornado GR1 (2x)AM: Model Workshop (Resin / 2 pcs / £7.50)Air to ground missiles / rocketsCVR-7Background: Used on Harrier GR7 and Jaguar GR3Kits: Airfix Harrier GR.7/9AM:Aviation Workshop (Resin / 2 pcs / £5)SNEB 68mm-PodsBackground: Harrier GR3's in the Falklands War (apparently, this info is wrong...)Kits: Revell Hunter FGA9 (2x) and old Airfix Hawk (4x), Airfix Harrier GR.1 and GR.3, Airfix Buccaneer S2B/S2D/S Mk.50 (4x), Hasegawa Harrier GR.3 (2x)AM: Aviation Workshop (Resin / 2 pcs / £3.85), Italeri Nato weapons setAGM-65 MaverickBackground: Used on Harrier GR7 since 1999Kits: should be many of... Revell Hunter Mk.58 (2x)AM: 6 of them in the Hasegawa Weapon Kit (X72-4), Italeri Nato weapons setBrimstoneBackground: Used on Tornado GR4, Harrier GR9 and Typhoon F2. Since 2005Kits: Hasegawa EF (6x, incl. pylons)AM: The new Hasegawa Weapon Kit (X72-10)Storm ShadowBackground: Used on Tornados GR4 (since 2003) and EFKits: Revell EF (2x), Hasegawa EF (2x)AM: Aviation Workshop (Resin / 2 pcs / £10)AlarmsBackground: Used on Tornados GR1-GR4, some Tornados F3Kits: Revell Tornado GR1 (2x), Hasegawa EF (4x)Italeri Tornado IDS (3x)AM: ? Sea Eagle Background: Used on Buccaneers, Sea Harriers and Tornados GR.1B Kits: Airfix Sea Harrier FRS.1 and FA.2 (2x), Hasegawa Sea Harrier FRS.1 (2x) AM: ?Laser guided bombs Background: Apparently, the British Paveways are made differently than the US ones (shape), so no big use for the Hasegawa pieces.Kits: Revell Tornado GR1 (2x CPU-123B), Airfix Harrier GR.7/9 (2x GBU-12, apparently missing the GPS antenna?) Airfix Buccaneer S2B/S2D/S Mk.50 (2x Paveway II)AM: 2000 lbs Paweway II from Aviation Workshop (Resin / 2 pcs / £7.50). Hasegawa, but are they correct for RAF?Air to Air missilesAIM-9L SidewinderBackground:Kits: most, really...AM: Hasewaga Weapons kit (8 in the X72-3 and 6 in the X72-9), Eduard Brassin (4x)AIM-120 AMRAAMBackground: will replace the Skyflash. Used on Tornado F3, Tiffies and SHar FA2Kits: Revell EF (4x), Hasegawa EF (4x)AM: Hasewaga Weapons kit (4 in the X72-3 and X72-10, and 6 in the X72-9), Italeri Nato weapons setAIM-132 ASRAAMBackground: will replace the AIM-9Kits: Revell EF (2x), Hasegawa EF (4x)AM: Aviation Workshop (Resin / 2 pcs / £4.50), Hasegawa Weapon kit (X72-10), Italeri Nato weapons setMeteorBackground: not yet in serviceKits: Revell EF (2x), Hasegawa EF (2x)AM: Hasegawa Weapon kit (X72-10)SkyflashBackground:Used on Tornado F3, was replaced by AMRAAMKits: Revell Tornado F3 (4x)AM: 6 AIM-7 in the Hasegawa Weapons Kit (X72-9); do they look 100% like Skyflashes?4 AIM-7 in the Hasegawa Weapons Kit (X72-3) Edited October 6, 2014 by alex 2 Link to comment Share on other sites More sharing options...
Troffa Posted January 16, 2009 Share Posted January 16, 2009 A good source for RAF weapons is the out of production Airfix RAF/Nato weapons set. These can still be found in dusty corners of model shops-(I got mine in "Toys and Prams" in Wisbech a couple of years ago.) and contains detailed parts and an etched fret for a wide variety of RAF weapons, Including the JP233 and the CPU-123/B LGB that the RAF use. Maybe Airfix might consider a re-issue if they still have the tooling. Link: http://sepecat.info/b/2007/02/12/the-airfi...to-weapons-set/ Link to comment Share on other sites More sharing options...
Dave Fleming Posted January 16, 2009 Share Posted January 16, 2009 BL755 - Hasegawa F-16 SNEB 68mm pods - Revell Hunter FGA9; LGBs - the Revell Tornado GR1 has a pair of CPU-123B ones, as well as radar fused 1000lb free fall bombs Link to comment Share on other sites More sharing options...
alex Posted January 16, 2009 Author Share Posted January 16, 2009 thanks, I have adjusted the list, and added the "Aviation Workshop" items! Alex Link to comment Share on other sites More sharing options...
spike7451 Posted January 16, 2009 Share Posted January 16, 2009 BL755 - Hasegawa F-16SNEB 68mm pods - Revell Hunter FGA9; LGBs - the Revell Tornado GR1 has a pair of CPU-123B ones, as well as radar fused 1000lb free fall bombs Withdrawn in 1985,half way thru my weps course,current one is Mk930 which is programmabe multi-purpose. Link to comment Share on other sites More sharing options...
TEZ Posted January 16, 2009 Share Posted January 16, 2009 The Hasegawa Jaguar also includes BL 755. PP Parts and Flightpath covered quite a few UK weapons. Link to comment Share on other sites More sharing options...
XV107 Posted January 16, 2009 Share Posted January 16, 2009 With regard to Paveway - the Hasegawa GBU-24 (the 2000lb Paveway III) is correct for the GR4 and Harrier GR7/9 I believe that Aviation Workshop are planning to do the Brimstone, with launchers (I answered a post from someone of an after-market disposition enquiring about the weapon). Don't forget Paveway 4, which is a tad different from the GBU-12, so no out-of-box employment of the Hasegawa ones if you like to be accurate! RAF Harriers in the Falklands didn't use SNEB, but the RN's 2-inch rocket; there was an issue over stray wriggly amps setting off the SNEB, IIRC. Finally, there are the 540lb free-fall bombs that the Harriers have been carrying in Afghanistan. I can't think of a source for these. Link to comment Share on other sites More sharing options...
Rob M. Posted January 16, 2009 Share Posted January 16, 2009 Finally, there are the 540lb free-fall bombs that the Harriers have been carrying in Afghanistan. I can't think of a source for these. Don't a pair of those come with the old Matchbox 1/72 Sea Harrier? Rob M. Link to comment Share on other sites More sharing options...
Seahawk Posted January 17, 2009 Share Posted January 17, 2009 Don't a pair of those come with the old Matchbox 1/72 Sea Harrier?Rob M. If we're talking the 70s-era 1000lb bomb, there are 4 in the Airfix Jaguar and Hawk kits: they're the ones I've mentally earmarked as the best 1/72 representations, but there may be better around now. I reckon they certainly they beat anything Hasegawa and Matchbox have produced. Hawk also has 4 SNEB pods. Again I used to consider them best of breed but they're maybe shaded now by those in the Revell Hunter. Jaguar also has 4 BL755 cluster bombs. Fine if you can find some etched brass fuses for the nose, but I vaguely recall seeing something better: Revell Tornado?? From memory there are some bombs in the Airfix Strikemaster which appear to depict a size not otherwise done in 1/72. 250lb? I am not aware of any representations of the RN 2" rocket pod, even poor ones. Nick Link to comment Share on other sites More sharing options...
spike7451 Posted January 17, 2009 Share Posted January 17, 2009 If you are modelling LIVE 1000Lb's for a project after 1985,YOU WILL need to extend the nose because of the Mk930 fuzing unit,see photo. Merv Link to comment Share on other sites More sharing options...
jeffclark7 Posted January 27, 2009 Share Posted January 27, 2009 Hi Alex You seem to have forgotten the REAL weapons - Those little bundles of instant sunshine: Blue Danube, Yellow Sun, Red Beared and the different versions of WE.177. All of these are available in the Belcher Bits Kit BL.3 Jeff Link to comment Share on other sites More sharing options...
Richard E Posted January 27, 2009 Share Posted January 27, 2009 And on more day-to-day level: CBLS 100 used by Jaguars, Buccaneers, Harrier GR3 and Sea Harrier FRS1 and FA2: available from Aviation Workshop and a long discontinued Harrier set CBLS 200 used by Tornados and Hawks: available from Flightpath as part of their Hawk detail set, our own Desmojen and the long discontinued Harrier set ACMI pod: available from Aviation Workshop Link to comment Share on other sites More sharing options...
spike7451 Posted January 27, 2009 Share Posted January 27, 2009 Hi AlexYou seem to have forgotten the REAL weapons - Those little bundles of instant sunshine: Blue Danube, Yellow Sun, Red Beared and the different versions of WE.177. All of these are available in the Belcher Bits Kit BL.3 Jeff Ahh...Load training every month at the WTC...The memories..... Link to comment Share on other sites More sharing options...
alex Posted October 6, 2014 Author Share Posted October 6, 2014 Added some weapons, since some new kits emerged the last five years! Alex Link to comment Share on other sites More sharing options...
magman2 Posted October 6, 2014 Share Posted October 6, 2014 New Hasegawa 1/72 set : Europe Aircraft Weapon Set http://www.1999.co.jp/eng/10288021 1 Link to comment Share on other sites More sharing options...
Giorgio N Posted October 6, 2014 Share Posted October 6, 2014 Some also existed earlier: for example the Sea Eagle is also included in the hasegawa Sea harrier. The amraam and Sparrows/sidewinders were included in Italeri's NATO weapons set. This also includes a couple of mavericks, can't remember the version, and the SNEB pods. This set also included a couple of Sea Skuas, but these while British are not strictly an RAF weapon BL755s are in Fujimi's Alpha Jet, the old tool Airfix Harrier GR.5 and the Hasegawa Harrier GR.3. The latter also includes 2 1,000 lbs bombs and 2 SNEB launchers, none brilliant IMHO 1 Link to comment Share on other sites More sharing options...
marksandygill Posted October 10, 2014 Share Posted October 10, 2014 Had a look on Hannants at what Olimp do, just weapons wise you're looking at; Typhoon update: 4x EPWII Tornado update: 2x PWIV and 3x Brimstone (inc triple launcher) GR7/9 update: 2x EPWII and 2x PWIV £15.99 each (but that's obviously including other parts/decals!), I wish I could make resin copies myself...! Link to comment Share on other sites More sharing options...
charlie_c67 Posted January 10, 2015 Share Posted January 10, 2015 Barracuda studios are apparently going to release after market Redtop missiles and obviously they are in the airfix lightning kit along with Firestreaks. I thought I got some Red tops from freightdog at Telford but can't find them on the website :-/ 1 Link to comment Share on other sites More sharing options...
