1275i Posted January 9, 2009 Share Posted January 9, 2009 Has anyone ever built this kit and does it have any issues? Any help is much appreciated. Cheers, Rob Link to comment Share on other sites More sharing options...
smeds Posted January 9, 2009 Share Posted January 9, 2009 Biggest problem you have is fit. The fuselage sections appear to be different diameters for starters. The leading edge of the fin has issues, narrower than the rest of the fin. The upper wing join to the fuselage is poor, needs reinforcment. The nose section is also poor. nothing under the visor, just a hollow nose cone. Don't try to make the drooping nose work, it will break. Thats just for starters. Enjoy !! smeds Link to comment Share on other sites More sharing options...
Mark Posted January 9, 2009 Share Posted January 9, 2009 In the middle of doing one right now and well, hmmmm........ It's easily the best 1/72nd Concorde out there! All points above are valid, although Bra-Z do a resin insert for under the visor. The only way to make the visor work would be to try and copy the fragile plastic linkages in metal! Good Luck!! Link to comment Share on other sites More sharing options...
AnonymousA667 Posted January 9, 2009 Share Posted January 9, 2009 As above, but to add to the list the nose gear bay is positioned too far aft and the visor is too long. Parts fit is indescribably poor, but as busdriver points out this is it if you want a 1/72 Concorde. peebeep Link to comment Share on other sites More sharing options...
1275i Posted January 9, 2009 Author Share Posted January 9, 2009 thanks for the replies guys, seems i have no choice then, if i want a BIG concorde then i'll have to build this one. Thanks for the help! Link to comment Share on other sites More sharing options...
chadders Posted January 9, 2009 Share Posted January 9, 2009 All the above + the wheels are too narrow mate. Airwaves do (did) replacements, Mark Link to comment Share on other sites More sharing options...
atdb27 Posted January 9, 2009 Share Posted January 9, 2009 (edited) Re fuselage sections - Glue the 3 port side pieces together and the 3 stbd side pieces. Easier to do filling along a seam than all the way round! DONT paint the inside black - A PIG to cover up with the white colour. Engine parts in black aren't much help either. Nosegear bay - Just how 'too far back' is it please anyone ? Adrian Edited January 9, 2009 by atdb27 Link to comment Share on other sites More sharing options...
AnonymousA667 Posted January 9, 2009 Share Posted January 9, 2009 Nosegear bay - Just how 'too far back' is it please anyone ? I didn't make any notes as mine was already underway when I found out and I decided to leave it. I think it may have been 13mm. peebeep Link to comment Share on other sites More sharing options...
atdb27 Posted January 9, 2009 Share Posted January 9, 2009 I didn't make any notes as mine was already underway when I found out and I decided to leave it. I think it may have been 13mm.peebeep Thanks for that - Noted for my next build. Adrian Link to comment Share on other sites More sharing options...
chadders Posted January 10, 2009 Share Posted January 10, 2009 (edited) This is from IPMS-NL hope it helps, http://www.ipms.nl/pim/eairfconco.html Mark Edited January 10, 2009 by chadders Link to comment Share on other sites More sharing options...
atdb27 Posted January 10, 2009 Share Posted January 10, 2009 This is from IPMS-NL hope it helps,http://www.ipms.nl/pim/eairfconco.html Mark Hi Mark, Interesting link. Bits I didn't know/realise. Cheers Adrian Link to comment Share on other sites More sharing options...
chadders Posted January 11, 2009 Share Posted January 11, 2009 Hi Mark,Interesting link. Bits I didn't know/realise. Cheers Adrian Glad you found it helpful mate, Mark Link to comment Share on other sites More sharing options...
kitnut617 Posted January 12, 2009 Share Posted January 12, 2009 (edited) I've got one on the go too, I found quite a few things wrong, especially the wings and nacelles. If you'd like to have a look at this link I've tried to explain how I went about correcting it from what I can see from photos http://thekitforum.16.forumer.com/viewtopi...sc&start=15 go to page 2 for most of the relevant info, the rest is about RAF Concordes. Robert Edited January 12, 2009 by kitnut617 Link to comment Share on other sites More sharing options...
