cger Posted January 2, 2009 Share Posted January 2, 2009 Hi all, this is my first posting on this nice forum. I am currently building the Trumpeter Seafury in 1/48 scale. I plan to do it as a Cuban natural metal bird. The Trumpeter cockpit is too shallow and quite basic, I kept the side console and rebuilt the seat and back plate: I kept the instrument panel as it will not be very visible anyway. The stick and gunsight are rebuilt with plastic bits. Another picture of the seat with an epoxy cushion: I plan to drop the flaps, so I built new flaps from plasticard: Now a picture of the resin 1000lbs bombs leftover from the Flightpath detail set, and scratchbuilt bomb pylons: A close up picture of a bomb, the texture is done with Mr Surfacer 1000 and articifial snow: The wheelbay was detailed with plastic rod and fuse wire: The legs get durits from copper wire, the tailwheel is separated from the fork and gets some photoetch from Part: That is all for the moment, best, Christian. Link to comment Share on other sites More sharing options...
wkennerley Posted January 2, 2009 Share Posted January 2, 2009 Wow this looks to be a great built, I will be watching this one. I am doing a 1/72 Seafury but it won't be anything like this one Link to comment Share on other sites More sharing options...
Martian Posted January 2, 2009 Share Posted January 2, 2009 This looks like it will be a very interesting thread indeed! Keep upthe good work. Martin Link to comment Share on other sites More sharing options...
Jon Kunac-Tabinor Posted January 2, 2009 Share Posted January 2, 2009 Hi Christian - and welcome to Britmodeller, or Bienvenue a Britmodeller! Looks like you sea fury is going to look very nice. It this is of any use - here's my build thread for the same model - if you are planning to tackle the scooped out cockpit sill shape on the model and other problems- I hope this proves of some use or inspiration!! http://www.britmodeller.com/forums/index.p...amp;hl=sea+fury Bon Chance Jonners Link to comment Share on other sites More sharing options...
cger Posted January 2, 2009 Author Share Posted January 2, 2009 Hi Jon, many thanks for your kind comments. I looked at you nice build and will try to correct the kit problems in the cockpit area. I knew about the pb behind the cockpit (the incorrect slope of the kit), but it seems there is more work here. best, Christian. Link to comment Share on other sites More sharing options...
cger Posted January 4, 2009 Author Share Posted January 4, 2009 Here are a few more pictures: the bombs are painted and weathered with pigments: I noticed afterwards that there should be a red band around the bomb, I will add it later. The wheel bay is painted yellow zincchromate: The cockpit pieces are painted in dark grey, details are painted with Vallejo acrylics: The cockpit tub: the seatbelts are made with lead foil, with photoetched buckles: The next step will be to correct the shape of fuselage around the cockpit, best, Christian. Link to comment Share on other sites More sharing options...
cger Posted January 12, 2009 Author Share Posted January 12, 2009 Hi all, I post some new pictures: First I cut away the flaps on the lower wing pieces and boxed the flap locations with plasticard: I rebuilt the part behind the cockpit with plastic strips and epoxy putty: The cockpit sides were also corrected with plastic strips: The next step will be to assemble the outer and inner wings, Christian. Link to comment Share on other sites More sharing options...
Mike Posted January 12, 2009 Share Posted January 12, 2009 Christian... excellent work so far Link to comment Share on other sites More sharing options...
David H Posted January 12, 2009 Share Posted January 12, 2009 Beautiful work so far, Christian. Nice job on the sheet plastic work, especially around the cockpit opening. All the Best, David Link to comment Share on other sites More sharing options...
Graham T Posted January 12, 2009 Share Posted January 12, 2009 Watching with interest. Link to comment Share on other sites More sharing options...
Jon Kunac-Tabinor Posted January 12, 2009 Share Posted January 12, 2009 Oh yes, Oh yes, Oh yes. I like it!!! That is some great work there - this is going to look Goood me thinks!! Jonners Link to comment Share on other sites More sharing options...
AndyL Posted January 12, 2009 Share Posted January 12, 2009 Now that's some pretty good work! Link to comment Share on other sites More sharing options...
KiwiSteve Posted January 13, 2009 Share Posted January 13, 2009 Great work on the Sea Fury Link to comment Share on other sites More sharing options...
cger Posted January 14, 2009 Author Share Posted January 14, 2009 many thanks for your kind comments! I tried to fit a thermoformed windscreen that was left from an old Flightpath set, but after fitting it I found it was too high, so I have ordered a Squadron replacement. In the mean time, I added red bands to the bombs and some signs with a fine brush, supposed to represent marks done with chalk: The Trumpeter wheels were badly molded on my sample, so I replaced them with wheels from Hobbycraft: The wheel doors were painted with Alclad: Finally I kept the Trumpeter spinner, painted yellow with Gunze acrylics. The blades are undercoated with Alcad aluminium and weathered with pigments: I will have to stop the build, waiting for my windscreen to arrive best, Christian. Link to comment Share on other sites More sharing options...
perry Posted January 14, 2009 Share Posted January 14, 2009 Yo man, thats crackin' work! How did you get that effect with the bomby thingies? Link to comment Share on other sites More sharing options...
cger Posted January 16, 2009 Author Share Posted January 16, 2009 Hi Perry, I used some tricks I learned from armor guys: the texture on the bombs was done by brushing a quite heavy coat of flat varnish, covered with baking soda. Remove the excess baking soda with a stiff brush until the texture is correct. I then airbrushed an undercoat of rust color (Tamiya red brown), then stippled the bombs with liquid mask using a piece of foam. Next the top colors are applied, removing the liquid mask you get nice rust spots. To get color variation, some rust spots are painted with various orange rust shades. Finally I applied washes of oil paints and pigments (both as a wash and dry). best, Christian. Link to comment Share on other sites More sharing options...
cger Posted May 17, 2009 Author Share Posted May 17, 2009 Hi all, having finally received a Squadron canopy, I was able to resume the build of my Seafury. Here are a few pictures: the airframe is painted with various Alclad shades: The Cuban markings were designed on a PC with Inkscape (a nice free vector drawing software) and printed on decal paper with a inkjet printer: The weathering was done with pastel washes (pastel powder thinned in enamel thinner). I find it gives a better dusty aspect than washes with oil paint. It remains to glue all the various small bits, hope you enjoy it, Christian. Link to comment Share on other sites More sharing options...
davidelvy Posted May 17, 2009 Share Posted May 17, 2009 That is nice. I do like "foreign" Sea Furies. Link to comment Share on other sites More sharing options...
Murdo Posted May 17, 2009 Share Posted May 17, 2009 I really like that build! Link to comment Share on other sites More sharing options...
Alan P Posted May 19, 2009 Share Posted May 19, 2009 This is a lovely build Christian, very nice work indeed! Link to comment Share on other sites More sharing options...
Thanos Mentzelopoulos Posted May 19, 2009 Share Posted May 19, 2009 Really stunning piece of work!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
cger Posted September 19, 2009 Author Share Posted September 19, 2009 Hi all, I at last managed to finish my Seafury started long time ago... Here are some pictures I took yesterday: I hope you will like it, best, Christian. Link to comment Share on other sites More sharing options...
OzH Posted September 19, 2009 Share Posted September 19, 2009 Wow, that is an absolute beauty! I don't think I picked up on this thread before, brilliant work throughout. Great weathering, really convincing finish. Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 19, 2009 Share Posted September 19, 2009 Likewise. Very nice, and I really like the shades on the different panels. Link to comment Share on other sites More sharing options...
daz greenwood Posted September 19, 2009 Share Posted September 19, 2009 Like it! Link to comment Share on other sites More sharing options...
