Decals over Tamiya AS-12
beetcleaner
Building the 1/72 Airfix Sabre and finishing it in NMF with a Tamiya AS-12 spray can. My usual method is two coats of Klear, MicroSet before applying decals then MicroSol afterwards. I've read that an application of Klear over Tamiya AS-12 will "kill" the desired finish so is it ok to use MicroSet/Sol on the NMF without a protective Klear coat?
Afterwards what would be the best product to seal the decals prior to pin wash and weathering? Thankyou for any advice
  • 1 month later...
I've used Airfix decals with Micro-Sol and Micro-Set directly on Tamiya AS-10, 12 and TS-17 and 30 without problems on my 1/72 P-51D models. So its ok to use without clear coat. For an NMF aircraft I always avoid clear coats...
Cheers / André
