Sign in to follow this
Mike
Harrier T.2/T.4/T.8 Upgrades (for Kinetic)
1:48 Eduard
Before Kinetic's relatively new kit of the much missed two-set Harrier trainer, we had a couple of resin conversion sets of varying quality in this scale, so I'm pretty sure the kit has sold very well since release last year (2017).  Eduard's new range of sets are here to improve on the kit detail in the usual modular manner.  Get what you want for the areas you want to be more of a focal point.  As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.
Interior (49882)
Two frets are included, one nickel plated and pre-painted, the other in bare brass.  A complete set of new layered instrument panels and side consoles are the primary parts on the painted set, with new rudder pedals; ejection seat details; sidewall details; coaming instrumentation and some canopy internal structure are also supplied.
Zoom! Set (FE882)
This set contains a reduced subset of the interior, namely the pre-painted parts that are used to improve on the main aspects of the cockpit, as seen above.  Whatever your motivations for wanting this set, it provides a welcome boost to detail, without being concerned with the structural elements.
Seatbelts STEEL (FE883)
In case you don't already know, these belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting.  Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE.  As well as the two sets of crew belts, you also get a set of the pull-handles over the pilot and co-pilot's heads that gets them out of there in case of an emergency.
Exterior (48945)
This larger bare brass set contains some important upgrades, such as new heat-shields for the aft nozzles, with scrap diagrams showing how they should be fluted with a biro and arranged; an interior surface skin for the air-brake bay; an upgrade to the detail in the bicycle landing gear and the wingtip out-rigger wheels, along with some bay enhancements and replacement bay doors, while others are detailed rather than replaced.  New in-scale vortex generators are supplied for the upper wing surface, along with a set of templates that ensure accurate placement, but keep that glue on the frugal side, or you'll have a permanent jig!  Lastly, there are pylon mating surface skins for if you're not arming your Harrier.
Masks (EX577)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.  There are two centre panes to the windscreen, due to there being a choice of parts between variants in the kit.  In addition you get a set of hub/tyre masks for the out-riggers, allowing you to cut the demarcation perfectly with little effort.
Masks Tface (EX576)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with everything above, but also give you another set of canopy masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism.  There are two centre panes to the windscreen on both sides of the pane, due to there being a choice of parts between variants in the kit.  I guess Tface stands for Two Face or something similar?
Review sample courtesy of
