Sign in to follow this
colinlp
Casting rubber
An off the wall question here but maybe someone can take a guess for me.
I cut the tip off a finger a few years ago at the nail base, I also play bass guitar which is a problem. I made a thimble out of Polymorph a few years ago which has worked OK but is a little bulky and and sounds like a hammer hitting the string even with some leather padding. I've tried a few things over the years to make a better version but so far no luck. Recently I've heard of the rubber that can be used for moulds (molds?). Do you think it would be durable enough to be made quite thinly to peel on and off my fingertip without splitting? The tip would be protected by a leather pad so wear wouldn't be an issue.
Sorry for the totally off topic question but i\ hope someone may have an idea, maybe as to a brand or type too
Thanks
No moulding rubber I use or know of would last more than a few on & offs. It rips apart too easily, the thinner it is the quicker it'll rip through
An idea/suggestion; carve a bit of wood to the shape of your finger. Shape a piece of leather over it and then dip into boiling water. This may take a few attempts to get just right. The leather will shrink and harden. It will become a thin hardened cover for your finger
