Hi,
I will be starting this one, 1/72 Special Hobby Hornet F3 with kit's marking for N0.33 Sqn , RAF Butterworth (now RMAF Butterworth, near to where I stay) , Malaya. this is the first time I'm building a short run multi media kit, hopefully I will have all the Mojos to finnish this one.
I'll be looking to watch this come together, maybe my all time favourite aircraft. I believe it can be a challenging build so possibly slowly slowly with lots of test fitting & thinking through the steps is the way to tackle it.
Steve.
I'll take a back seat as well Thomas.
I agree with Steve, the DH Hornet is a beautiful aircraft and I also have this same kit in the ever growing stash.
Mine (eventually) will be a silver / rocket armed No. 45 Squadron aircraft, so watching your progress may elevate this up the build queue a little.
Cheers and good luck... Dave
<holds up hand>
Please sir, can I watch too? I have one of these in the stash and I'd like to see how it all works out...
To echo what has already been stated, beautiful aircraft and I believe that it's a tricksy kit to build.
I'll certainly follow this too. I've not knowingly seen one of these kits built, so get to it while I sit back and enjoy!! Good choice :-)
Another very attractive aircraft, nice choice, be interesting to see how the Special Hobby kit goes together.
Guys,
Thanks for the interest, I have a test build with the fuel tanks, this is not gonna be an easy build, first of all there is no locating pins to aid the assemble, and flashes are on the mating surface that need to be clean, Joint is not pretty, putty is needed .. More to come...
Best of luck, Tom. Built this before and I remember what a bear it was to finish.
There is a great step by step of this kit at uamf. It might have been James Perrin who documented the build. I forget. You'll have to poke around in the archive. But you might find it very useful.
Thanks Aidy, talk to you later..
SoftScience, thanks,Will look it up in UAMF..
and  some progress, every single parts of this kit need clean up of flashes and the thick sprue runner..
Painted the cockpit dark grey. and remove the plastic below cockpit to make way for resin gun ports later.
Edited by masterqq
Hey Guys,
Progress...
Assembled the fuselage, the resin gun ports fit batter than expected, also spent shell ejector ports are being drilled out.
Nacelles not too much of an issue.
The wing is butt jointed , so I added the plastic strips as an anchor for the join, I hope this will work
The resin radiator is too narrow, so I added a strip of plastic shim, and wing will be assemble next..
More later..
Edited by masterqq
That's good progress Thomas - and now I can see what you intended when you marked out the wing roots
Robert,
Yup that's the plan, I will address the wing joint issue after I attached the nacelle to wing,..
And then the bloody canopy don't fit, I will remove some materials from where the windscreen sit and may be add some shims too..to be addressed later.
Edited by masterqq
I like what you're doing here Thomas and thanks for providing detailed photos and suggesting many ideas for rectification. I say that canopy is no great fit. It's a shame it's not supplied in two parts, which would probably hide the gap and extra work now required. I don't suppose there is a vac-form replacement available? You could 'carefully' crack the kits canopy open, however what do you do if something goes wrong?
Your doing a grand job with this kit, so just sending through my encouragement to help you keep going.
Cheers.. Dave.
Rabbit Leader,
Thanks for the tips, it will be consider when I address it later.. :)
Anyway, The horizontal stabilizers are identically molded, that's mean the actuator will be facing the same side when assembled, So I cut out one of it and make one with epoxy putty.. now both will face downward with assemble.
Also added metal pin for strengthening the joint later.
I'll be following along, as I hope to build my kit of this...someday. After my wife divorces me and takes the children perhaps. If my memory doesn't fail me, I believe the wing dihedral in the kit is off as well, canted too far upwards, I think.
1 hour ago, masterqq said:
Rabbit Leader,
Check you refs on this, it may be a DH thing as I believe having one up & one down is correct for Mosquitos.
Steve.
Steve,
You are right, I check and only see one side having the actuator, look like it is really having one up & one down, thanks for pointing that out to me. to be reverse back later.
Edited by masterqq
