Fiat G.50 Freccia from SBS Model
JackG
Around mid last year, FLY had announced a G.50 bis.  Spotted these over at Scalemates, SBS has a couple in the 1/72nd range as well;
regards,
Jack
Edited by JackG
Very interesting and unexpected announcement. SBS generally makes high quality products and I'm sure that these will be very good kits
At the same time I wonder what interest a resin kit of a type already available in plastic can raise. Granted, this kit will be more detailed that the older AML ones, and may well be easier to build. Pricewise though it's likely to be way more expensive than the competition, I can really only see the most fervent G.50 fans looking at this one instead of the Fly kit
Giorgio,  all good points you make.
Outwardly, is there any difference in appearance between the Freccia and Bis - as I understand the Bis has an additional fuel tank internally, so maybe an extra access cover?
regards,
jack
I seem to remember the rudder hinge-line was changed from a straight line to a stepped line and the early smooth cowling got little bumps for the Bis? Not sure if there was anything else though...
Stew
Did the Fly kit ever come out? I know they said they were doing one but I haven't seen anything else about it.
Good point, since we don't know yet when the Fly kit will hit the market, this SBS kit may well be the only around, at least for a while.
The AML kit can still be found but I believe it's now OOP.
Regarding the G.50 bis, this variant had a different tail and rudder and also a different shape of the whole rear fuselage. The tailwheel is also in a different position.
The cowl did indeed have the small bulges but IIRC there were not immediately introduced. They were present on most Bis anyway so are an important feature. There were other small differences in panel lines and other details.
Converting a G.50 into a Bis is possible but involves a bit more work than apparent to a quick look. It should be added that in the same way as with other Italian WW2 fighters, a number of small and not so small modifications were introduced over the various construction blocks without any change in the official aircraft designation, modellers with a particular interest in all small details have a hard time when dealing with these subjects
Looks very good, but the 40 Euro price has put the brakes on this one.  At least Hannants is providing a 10% discount if you pre-order.
Edited by JackG
  • 2 months later...
  • 1 month later...
New boxing - released:
- ref. SBS7019 - Fiat G.50 BIS Regia Aeronautica - https://sbsmodel.com/model/SBS-7019/fiat-g.50-bis--regia-aeronautica-
- ref. SBS7020 - Fiat G.50 BIS German & Croatian - https://sbsmodel.com/model/SBS-7020/fiat-g.50-bis--german---croatian-air-force-
Source: https://www.facebook.com/permalink.php?story_fbid=2003239389696445&id=117380071615729
V.P.
  • 3 years later...
New limited edition boxings soon
Source: https://www.facebook.com/permalink.php?story_fbid=pfbid07Mhv5yuhh3cZcT9iYHazomV2twXCqYS8ijfm6Tvq1xRz6C8RgDdDsmbaJGP32wyxl&id=10005969654380821922
Quote
We are happy to announce our new limited release full kit.
1/72 Fiat G.50 Serie I in two boxing!
SBS 7028 1/72 Fiat G.50 Serie I 'Spanish Air Force'
SBS 7029 1/72 Fiat G.50 Serie I 'Regia Aeronautica & Finland'
Well, it was the most challenging kit to produce in the history of SBS thus it is a limited release of 200 pcs only. (yes, clear resin is challenging...)
They are available only in our webshop (www.sbsmodel.com) and Aviation Megastore of NL and distributed by Beaver Corporation in Japan, but due to it's limited nature it won't be offered to other resellers. If you don't want to miss it, grab one now
Desing by Flying Octopus Design by Otto Jozsa
Order info: www.sbsmodel.com
Note: The Hakaristis are intact in the kit decals, we covered them for FB photos only as one would say better safe than sorry
- ref. SBS7028 - Fiat G.50 Serie I - Spanish Air Force
https://sbsmodel.com/model/SBS-7028/fiat-g.50-serie-i--spanish-air-force--limited-edition!!!
- ref. SBS7029 - Fiat G.50 Serie I - Regia Aeronautica & Finland
https://sbsmodel.com/model/SBS-7029/fiat-g.50-serie-i--regia-aeronautica---finland--limited!!!
305202660-515318307134716-75486810090893
305927350-515318217134725-57932777554826
305279833-515318207134726-17823016802892
V.P.
Edited by Homebee
Source: https://www.facebook.com/permalink.php?story_fbid=pfbid02UtQwc4edEkpN7VEZrovXWZ1UnrTmZ1jD2gbqw63iB6HGN8Ws26r2Ybo2csuVtsGSl&id=100066625010105
Quote
Please let me introduce one of my latest design for SBS Model! This is a conversion from my former design of the italian Fiat G.50 fighter. Many years ago I did the "hard chopped top" version with opened cockpit. After many years, beers and discussions with SBS crew, we decided to go up to the wall and try to make the early version of the fighter. It was a real challenge for both of us, in design and in production points but we achived! This CAD is a redesigned and optimized for the best performance!
The 1/72th scale kit announced here: https://www.facebook.com/permalink.php?story_fbid=pfbid07Mhv5yuhh3cZcT9iYHazomV2twXCqYS8ijfm6Tvq1xRz6C8RgDdDsmbaJGP32wyxl&id=100059696543808
Here I come with some exclusive renders!
Hope you like it!
305576986-420642423499921-11827742937573
305655252-420642420166588-46577903158749
306337148-420642646833232-10784220581188
305990013-420642566833240-56215554947940
V.P.
