Sign in to follow this
German Molch Midget Submarine - 1:35 HobbyBoss via Creative Models
Hobbyboss 1:35 (HB85508)
The Molch or Newt/salamander in German were designed as one man submarines or mini submarines. This was the first designed for the German Navy, however it was to prove unsuccessful in combat and suffer heavy losses. The submarine was ultimately based on torpedo technology given its size. Designed for coastal operations it was totally electric in nature with a large battery providing a range of approx 60kms at 5 knots speed. A complicated system of trimming tanks made the boat hard to control which did not help operations. Armament was two G7 Torpedos.
The combat record of the 393 boats built was less than spectacular. In their first outing in the Med in 1944 a flotilla set out to attack allied battleships taking part in the invasion of Southern France. Initially 10 of the 12 boats were lots, quickly followed by the last two being sunk by allied warships. Other operations would also result in little or no victories. Out of 102 sorties in early 1945 70 boats were lost for only 7 small ships being sunk. The Molch was quickly relegated to a training role for other small submarines.
The Kit
The kit is a fairly basic one and arrives on three main sprues, a clear sprue, a small sheet of PE and a small decal sheet. Construction starts with the cockpit, not really in the aeroplane style but the small compartment which contained the operator. A seat and full controls are provided for the compartment which fits into the main hull. How much will be seen especially if you fit the main hatch will be debatable? The entry hatch and periscope are also fitted into the main hull along with a stern part. once these are in the main hull can be closed up. The rear drive is then added along with the main hatch and the stern control surfaces.
Next the two side torpedos are made up. These are each in two halves with the drive propellers to be added. Once complete they are added to the hull.
There is one small sheet which proves a shark mouth for one of the painting options. There are four options with two solid grey ones, and two with multi grey camo. No information is provided about the options.
It is good to see these smaller eccentric submersibles being provided in a scale large enough to make them look good. The only omission I can see is some kind of stand to display the finished model. Overall recommended.
Review sample courtesy of
Nice review Julien, bit of a strange choice for Hobbyboss as the Mikromir Molch was already available in 1/35 but it looks like a nice kit.
All the best Chris
