Sign in to follow this
MAN LKW 5t MIL GLW Truck - 1:35 Hobbyboss via Creative
Hobbyboss 1:35 (HBB85508)
In the 1960s the Bundeswher was looking to replace its fleet of vehicles which stemmed from the birth of the modern German Army. They wanted a fleet of 2, 3 & 4 axle vehicles in the 4 to 10 tonne payload range which had to be amphibious. As it was a large task it was suggested that bidding companies form a common development company for a unified project. This was set up under the leadership of MAN and included Klockner-Humboldt-Deutz, Bussins, Krup, and Henschel. The specification agreed was for a cross country capable, amphibious, all wheel drive, run flat tyres, steel cab,  NBC protection, and a multifuel engine. In 1975 the German Army & MAN signed the contract to produce 4x4, 6x6 and 8x8 vehicles.
The 4x4 or KAT I & KAT I A1 vehicle is the type 452 (and 462 with fitted winch). They are powered by a V8 Deutz diesel engine and are mainly flatbed or covered type trucks. The distinctive cab with the cut away corners stems from the need for the vehicles to be rail transported on standard flat cars. Earlier trucks had fixed cabs but later ones tilting ones which made engine maintenance much easier. All vehicles feature a mount for a MG3 machine gun (basically an MG42!). The tank trucks with either a single 4600L tanks, or twin 2300L tanks are also fitted with a pump. These vehicles actually exceed the max gross weight by one fulle tonne. After testing with the manufacture approval was given for these vehicles with the only compensation being higher tyre pressures.
The Kit
This new kit from Hobby Boss is a reboxing of the standard flat bed truck which we reviewed here. New parts are provided for the tanks. The kit arrives on 12 sprues plus the drivers cab and the tyres, a nice inclusion is masks for the windows. For a standard 4x4 truck the box is packed with parts. Construction starts with the gear box and differentials for the transmission. These are made up and the suspension components (air bags & springs) are added. The tuck chassis is then made up from a surprising number of components and the gear box, differentials and drive shafts are then added. These are highly detailed and made up from a number of components. Once the chassis is finished the wheels can be built up, the tyres added and then they are attached to the chassis.
Work then moves to the cab. The dash board is built up with some of the drivers foot controls added underneath it.  The base plate of the cab has the gear controls and a few other parts added then the dash is fitted. Once this is in the drivers seat and steering wheel are added along with the bench seat for the passengers. This is then the lower part of the cab complete. Moving onto the upper part the windows added along with a couple of internal parts and the main rear bulkhead. The upper cab can then be attached to the floor.  The spare wheel and carrier are completed and attached to the cab, followed by the main doors being completed and added.  The rightside equipment locker is also built up and added. On the outside of the cab the front bumper is added along with the roof hatch, mirrors, wipers and parts for the engine hatch. The completed cab can then be added ot the chassis.  After this is done the exhaust system is built up and added. Along with some additional parts under the cab.
After this the fuel pumps and associated parts are built up for the back of the truck. Plastic hose is supplied for the fuel delivery system.  This part is quite complex and builds up from a number of parts and should look good when finished. After this the two fuel tanks and their mounts are built up. The interlink piping is installed onto the flat bed and then the tanks are added.  The drop sides for the truck are then added to the bed along with the headboard and tailgate. On the underside of the bed the stiffeners are added along with the mudguards. Underside lockers, wheel chocks and jerrycans are added. Finally the bed is mounted to the truck.
Theses are minimal as the vehicles did not carry many markings. Decals are supplied for three temperate camo vehicles. Decals include the Hazardous placards (mising the Class numbers)  and Kemler Code panel (which should be orange, not yellow!) for the front.
It is great to see a modern support vehicle being made available, this gives many diorama possibilities as well as a great stand alone model. The kit is nicely complex and should build up to be a great looking kit.
Highly recommended.
Review sample courtesy of
