tonyot Posted March 17, 2018 Author Share Posted March 17, 2018 (edited) Hiya Folks, Another quick update,... been whittling and sanding away while watching the Rugby today!; Academy/Eduard; Checking up my references and photos I realised that the RCAF Lib had its mid upper turret removed after moving from the ASW role to Met Duties,.....so the opening was enlarged using a file and the blanking plate from the Hasegawa kit was to be used to cover it over; DSCF2730 by Tony OToole, on Flickr You can see it here in place and covered with filler , ready to blend it in with a sending session later. Also,... the engine nacelles of the Academy kit have quite a few sink marks now that the moulds are getting old, so these were filled, plus the panel detail is very faint and has vanished altogether in some places, so as the nacelles are a very important part of the aircraft these were re scribed and will hopefully show up under a couple of coats of paint now. DSCF2732 by Tony OToole, on Flickr I`ve also done a bit more sanding, filling and sanding of both models and getting them prepared for painting,....... maybe tomorrow? Cheers for now, Tony Edited March 17, 2018 by tonyot 2 Link to comment Share on other sites More sharing options...
tonyot Posted March 19, 2018 Author Share Posted March 19, 2018 Hiya Folks, Another quick update,.....almost ready to start painting,...the wings were test fitted and the parts needing to be sprayed white were prepared by sticking them onto a length of tape; Academy/Eduard; DSCF2734 by Tony OToole, on Flickr Hasegawa/Eduard DSCF2736 by Tony OToole, on Flickr And here are the parts of both kits during painting,.....although I ran out of matt white undercoat, which is a bit of a bummer! DSCF2737 by Tony OToole, on Flickr I`ll be brush painting the upper surfaces, varnish etc. Cheers Tony 3 Link to comment Share on other sites More sharing options...
tonyot Posted March 22, 2018 Author Share Posted March 22, 2018 Another update,....... Painting underway with the brush now, applying the upper surface TSS camouflage, starting with Aeromaster Dark Slate Grey; Hasegawa/ Eduard; DSCF2739 by Tony OToole, on Flickr Academy/ Eduard; DSCF2740 by Tony OToole, on Flickr I have also made paper outline copies from the decals for nose art and made masks, ready to apply the yellow later. I`ve also dug out a set of resin wheels with the pattern of tread suitable for the Canadian aircraft,..... I have a set for the RAF aircraft somewhere too; DSCF2741 by Tony OToole, on Flickr Cheers, Tony 6 Link to comment Share on other sites More sharing options...
tonyot Posted March 25, 2018 Author Share Posted March 25, 2018 (edited) Hiya Folks,.....another update,..... First,.... the resin Eduard Brassin wheels for the SEAC Liberator with the cross tread have arrived; DSCF2742_NEW by Tony OToole, on Flickr And painting was almost over on the models with the application of the upper surface camouflage scheme; Hasegawa/Eduard; Using Aeromaster Dark Slate Grey and Pactra EDSG, trying to replicate a slightly sun bleached look, but not overly done; DSCF2745_NEW by Tony OToole, on Flickr And the wings and fins attached with propellers in place, and the leading edges of the flying surfaces painted,.......judging by the available photos the rubber de icing boots on the inner wing were removed but those on the outer wing retained,... and those on the fins had been overpainted with white which had worn away along the bottom due to exhaust gases etc. Note the blanking plate fitted over the mid upper turret too. For their 15+ hour special duties flights in support of agents and guerillas as far afield as Borneo the mid upper turret was removed plus the nose guns,....often the waist guns too and long rang fuel tanks were fitted in the forward bomb bay; DSCF2750 by Tony OToole, on Flickr Academy/Eduard; Using Aeromaster Dark Slate Grey and Humbrol enamel 123 EDSG plus Humbrol 24 Trainer Yellow for the nose; DSCF2747 by Tony OToole, on Flickr DSCF2749 by Tony OToole, on Flickr The wings and fins have been attached and the rubber de icing boots represented on the front of the flying surfaces. The propellers have been attached and a white stripe still needs to be added to each hub cover. A resin radar `dustbin' from the Czechmaster Liberator conversion set will also be fitted. DSCF2752 by Tony OToole, on Flickr The Academy (RCAF) model has had Humbrol 35 gloss varnish applied ready for the decals and the other model will receive its own coat shortly, ready for the decals, Cheers for now Tony Edited March 25, 2018 by tonyot 11 Link to comment Share on other sites More sharing options...
Brandy Posted March 25, 2018 Share Posted March 25, 2018 These are really starting to look the part now the paint is on. Looking forward to more updates..... Ian 1 Link to comment Share on other sites More sharing options...
tonyot Posted March 26, 2018 Author Share Posted March 26, 2018 (edited) Thanks Ian,...... here is another update; Academy/Eduard; Most of the decals are on now,.....just stencils. The letter `A's' don`t appear quite right, too tall and narrow, so I lopped off the top of each letter to make them appear more squat. Also the serial is black when it should also be grey. The nose area still requires some detail painting with black and I need to find some red lines for the propeller warning marking on the fuselage; lib1 by Tony OToole, on Flickr Hasegawa/Eduard; The DK Decals for this aircraft are superb, I`ve always wanted to model this particular Lib; lib3 by Tony OToole, on Flickr lib2 by Tony OToole, on Flickr I`ve sealed the decals in with Kleer,....... time to start some weathering. Cheers Tony Edit,....just realised that I have got the SNAKE marking wrong on the right hand side,.....I was rushing to catch the light for photos so took a 50-50 gamble,..... and having checked up I`m wrong!! Edited March 26, 2018 by tonyot 10 Link to comment Share on other sites More sharing options...
The Spadgent Posted March 28, 2018 Share Posted March 28, 2018 Stunnng work Tony. Fast too. you’re getting a really nice finish with a brush, hat doffed. Johnny. 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted March 29, 2018 Share Posted March 29, 2018 What a cracking pair Tony they look great. Not got a liberator in the stash unfortunately. Will start saving my pennies. Keep up the good work. All the best Chris 1 Link to comment Share on other sites More sharing options...
tonyot Posted March 29, 2018 Author Share Posted March 29, 2018 Cheers Fellas,..... another short update,.... Well following a couple of coats of matt varnish I`ve run a knife over the panel lines and then put a watercolour wash on both models,..... which I`ll rub away once it is almost dry; DSCF2756 by Tony OToole, on Flickr DSCF2757 by Tony OToole, on Flickr DSCF2758 by Tony OToole, on Flickr Getting there now,......towards the homeward run and hope to have them finished over Easter, Cheers Tony 8 Link to comment Share on other sites More sharing options...
AdrianMF Posted March 29, 2018 Share Posted March 29, 2018 There wasn't an "aaagh" emoticon for your wash pictures - that stage always worries me! The two of them are looking super. Regards, Adrian Link to comment Share on other sites More sharing options...
tonyot Posted March 29, 2018 Author Share Posted March 29, 2018 Cheers Adrian,........not to worry,.....they look much tidier now! Hasegawa/ Eduard; DSCF2759 by Tony OToole, on Flickr Academy/ Eduard; DSCF2761 by Tony OToole, on Flickr Ready for the some weathering then the undercarriage, turrets etc Cheers Tony 8 Link to comment Share on other sites More sharing options...
Beard Posted March 29, 2018 Share Posted March 29, 2018 They both look most excellent (as usual). 1 Link to comment Share on other sites More sharing options...
FalkeEins Posted March 30, 2018 Share Posted March 30, 2018 indeed.. a fantastic addition to your shelf of US types wearing roundels. Which book are you using for reference, the Pateman 'Bridge busters..' or the other one, 'RAF Libs over Burma' ? 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted March 30, 2018 Share Posted March 30, 2018 Very nice Tony. Cracking job. Can't wait to see these finished. All the best Chris 1 Link to comment Share on other sites More sharing options...
tonyot Posted March 31, 2018 Author Share Posted March 31, 2018 (edited) Cheers folks,...... I`m almost there now! On 30/03/2018 at 8:22 AM, FalkeEins said: indeed.. a fantastic addition to your shelf of US types wearing roundels. Which book are you using for reference, the Pateman 'Bridge busters..' or the other one, 'RAF Libs over Burma' ? For this SEAC Lib I`m using quite a few sources with photos depicting this aircraft, including some old issues of Aviation News! In fact,..... although I`ve still got a bit to do on the Canadian aircraft,..... the SEAC one is now finished! I added a set of Rebecca antenna from an old Revell Havoc kit, suitable thinned down, along with the resin wheels and other pre painted items. The nose turret was left without guns as per the SD role and despite adding lots of weight into the nose, the model was still a tail sitter,...which isn`t a problem as most RAF Lib`s had a box placed under the tail skid while on the ground at some point; DSCF2766 by Tony OToole, on Flickr DSCF2772 by Tony OToole, on Flickr I`ll stick a RFI on for this aircraft,....... hopefully the RCAF one will be a day or so, Cheers Tony Edited March 31, 2018 by tonyot 13 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted March 31, 2018 Share Posted March 31, 2018 Wow! She’s amazing, just the right amount of weathering there. Bravo sir. John. 1 Link to comment Share on other sites More sharing options...
tonyot Posted March 31, 2018 Author Share Posted March 31, 2018 Thanks John,......glad you like it mate! For anybody wondering about the Airfix Mitchell,.....I`ve done a bit more including painting the undersides in Neutral Grey and painting the props,.... time to add some Invasion stripes now; DSCF2764 by Tony OToole, on Flickr DSCF2765 by Tony OToole, on Flickr Cheers Tony 5 Link to comment Share on other sites More sharing options...
bigbadbadge Posted March 31, 2018 Share Posted March 31, 2018 Cracking Lib Tony looks amazing, really gotta get one of these, great progress on the Mitchell too, you are like a machine fella. All the best Chris 1 Link to comment Share on other sites More sharing options...
amblypygid Posted March 31, 2018 Share Posted March 31, 2018 That's a lovely looking Liberator, I particularly like the work on the tail-fins, very neat. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted April 1, 2018 Share Posted April 1, 2018 Another excellent result Tony, she really does look very good indeed. The RCAF one is looking good too and nice to see the Mitchell coming along, you really have been busy! 1 Link to comment Share on other sites More sharing options...
stevehnz Posted April 1, 2018 Share Posted April 1, 2018 Those are just magic Tony, I've been having a catch up as you can plot by the likes, super job on both. Steve. 1 Link to comment Share on other sites More sharing options...
tonyot Posted April 1, 2018 Author Share Posted April 1, 2018 Thanks everybody,..... so glad you liked the first one,...... here is the 2nd one finished too; I`ve posted more pics in RFI too, Cheers for your encouragement and all the best,....Happy Easter, Cheers Tony 8 1 Link to comment Share on other sites More sharing options...
Brandy Posted April 1, 2018 Share Posted April 1, 2018 Fabulous, even better than the other one. Good job you have plenty of ammo boxes! Ian 1 Link to comment Share on other sites More sharing options...
stevehnz Posted April 1, 2018 Share Posted April 1, 2018 Brilliant Tony, I do like that, the scheme is a bit amazing & you've caught it so well. Steve. 1 Link to comment Share on other sites More sharing options...
tonyot Posted April 2, 2018 Author Share Posted April 2, 2018 1 hour ago, stevehnz said: Brilliant Tony, I do like that, the scheme is a bit amazing & you've caught it so well. Steve. It did scare me a bit Steve and I was very worried about that nose art,..... but it just had to be tried!! Masking off the yellow to match the outline of the decals was quite hard and a little touching up was needed after they ere applied! Cheers Tony 1 Link to comment Share on other sites More sharing options...
