Russian T-62 Mod 1960 (01546) 1:35
Mike
1:35 Trumpeter
The T-62 was developed from the T-55, and to the uninitiated could be mistaken for one.  On closer inspection there is 115mm main gun with a longer barrel and improved penetration, which required the turret to be enlarged and the chassis enlarged in turn to accommodate the larger turret ring.  Despite family resemblance and an almost identical layout there is little commonality of major parts due to the size changes that propagated out due to the change of main armament, which was a world first in respect of the smooth bore, allowing it to launch shells at a substantially increased velocity.  The interior equipment however was broadly similar to the T-55, so conversion between them wasn't over-difficult, and even though the vehicle is larger, the crew compartment is still horribly cramped for the four crew.
The Mod 1960 was the initial production model that was preceded by five examples of the T-62A, which were stretched T-55s, and as such below par compared to the T-62.  It was able to carry 40 rounds of ammunition for the 115mm Molot smooth bore gun, and 2,500 rounds of 7.62mm for the PKT coaxial machine gun.  On the turret roof was an optional 12.7m "Dushka" anti-aircraft machine gun, which required the loader to expose his upper body in the hatchway  in order to fire.
Although not as numerous as the legendary T-55, the T-62 has seen numerous variants and license built "lite" copies made in North Korea, but most began life at the Ukrainian factory, with many seeing modifications at the hands of their purchasers at a later date.
The Kit
This kit and its box were included in the Hobby Boss kit (85513) of a KrAZ-6446 tractor and trailer as the load, but as it was also released a couple of years back as a stand-alone kit, I have split it out for expediency and to prevent the original review from getting too large.  The box is typical Trumpeter with the cardboard corrugations showing through on the artwork, and a divider keeping the smaller parts from rattling around inside the box.  There are seven sprues in light grey styrene, seven in brown styrene, four in black styrene, one in clear, two sheets of Photo-Etch (PE) parts, a length of brass wire, a metal gun barrel, decal sheet, instruction booklet and separate painting and decaling guide.  It is one of many kits of the T-62 from Trumpeter, so if you have seen any of them you stand a good chance of recognising at least some of the parts here.
In the usual fashion construction begins with building up of the road wheels, which are made in pairs with separate black tyre parts that offer the possibility of painting the parts separately to avoid masking.  The idler and drive sprocket are both made up of two parts, and each of the two types of road wheel pairings have hub cab parts added to the centre.  The lower hull is fitted with a rear bulkhead, final drive housing and axles, then the wheels are glued onto them, with the track lengths created from the individual brown links on the seven sprues.  Each link has four sprue gates and no ejector pins or sink marks to fill, with 96 links per side needed.  Construction with liquid cement followed by draping and packing the lengths around the wheels while the adhesive is still malleable is your best recipe for success, and you may wish to build each run in two halves for ease of painting and installation.
An unditching beam is fitted to the rear bulkhead along with final drive armour, and attention turns to the upper deck, which needs a number of flashed-over holes opening up for this mark.  The deck includes the upper glacis, which is detailed with lights, mine roller mounts, and the driver's hatch, plus a bow wave deflector, while the engine deck is constructed separately in two sub-assemblies that include PE mesh parts.    These are added later with the fenders, which have been prepared with stowage bins, fuel tanks and exhaust on the port fender before being glued to the hull using the long slots and tabs running along the sides.  The prototypical fuel barrels attach to the rear of the hull by curved brackets, but no fuel hosing is included in the kit, which can easily be fabricated if you desire by checking your references.  The towing cables are made up from styrene eyes and copper/brass braided wire for a realistic look, with lengths and attachment points marked on the instructions.
The T-62's enlarged turret is supplied as an upper and lower part, with only a stub of the coaxial machine gun, mantlet cheek parts needing adding and some holes drilling out before it can be closed up.  The holes are for the multiple grab-rails that encompass most of the turret, with the two hatches, shell-ejection port and various vision ports scattered around the roof, plus lifting eyes and a small searchlight next to the commander's low-rise cupola.  The larger searchlight is fitted to a bracket next to the main gun, and the snorkel tube is attached to the back of the turret, after which you get to choose between adding a cover to the mantlet or leaving is bare.  The main gun is turned aluminium, which is nice to see, but if you don't like these for any reason, you can use the plastic parts that are included, but you are in for a lot more preparation of seams if you go down this route.  A delicate linkage between the gun and searchlight is the last task, other than dropping the turret into place on the hull.  There are no bayonet lugs, so either glue it down, or remember to put a finger on top if you ever need to move or invert it.
Markings
Russian Green anyone?  There is only one option included, and the designers aren't very forthcoming about where and when White 545 was stationed or saw deployment.  The decal sheet includes lots of white numbers in two different styles, plus a pair of Soviet emblems, so if you have a different scheme in mind, this generic sheet may be of at least partial use.  The registration of colours on the emblems is excellent, and the white seems sufficiently dense for the purpose, and everything is nice and sharply printed on my sample.
Conclusion
Another nice model from Trumpeter that will look good next to a T-55 on your display shelves.  The exterior has been well done, but unless you plan to put crew in the hatches, you'll need to leave them closed to avoid displaying the empty interior.  The part count is sensible, with only a few compromises in detail as a result, such as the exhaust that is slightly simplified and partially moulded into the fender.  Overall though, a nice kit that would look super on the back of a tank transporter.
Supplied as part of the KrAZ 6446 Tractor with MAZ/ChMZAP-5247G trailer kit 85513
Currently on sale with a deep 35% discount at Creative at time of writing
  • 2 years later...
On 07/03/2018 at 21:52, Sgt.Squarehead said:
Vinyl tyres?  With hard plastic track?  Why?  :o
They're not vinyl, just black plastic.
  • Julien locked this topic
Guest
