Moa
Barkley-Grow T8P-1 Passenger plane - Execuform, 1/72nd.
What is a thing that looks like a Lockheed Model 12 Electra and a Beech 18, but is neither?
A 1937-born Barkley-Grow T8P-1, of course!
Continuing with the vacuum-formed building trend, here is a product from Execuform, that gives you the basic shapes as a sort of base onto which you have to add the detail you want. Only the main shapes come in the kit with some leaflets containing a plan, images and information. The decals and accessories (engine, wheels, cockpit and cabin detail) are to be provided by the modeler. I have built products from this brand before and they should be considered a white canvas onto which you can express your modeling artistry, on subjects most of the time nowhere to be found as injected or resin kits. If do some scratch-building, Execuform saves you a lot of time by producing the masters and pulling the styrene shells, but they are not meant as complete kits.
The Barkley-Grow was not a particularly successful design, although it managed to operate with a number of airlines and private owners. Three airframes seem to be still today being exhibited at museums.
The Barkley-Grow was operated on wheels, skis and floats, making it especially useful as a bush plane in Canada, where it saw a bit of recognition, negated to it in the US.
The seaplane version had an additional, smaller, central vertical stabilizer. The land version had a fixed landing gear with characteristic pants.
Of pleasant lines and uncomplicated design, especially on wheels, it makes a good candidate to try your skills at this somewhat neglected media. It teaches you in the process quite a bit.
Notable operators were Canadian Pacific, the US Antarctic Service, Yukon Southern Air Transport, Pacific Western, Northland, Prairie Airways, Associated Airlines, a private individual: Alexander Papana (YR-AHA, Trăiască Regele "Long Live the King", same exact registration by the way wore by Papana's Bellanca 28-92 trimotor), and the Peruvian government (OB-GGK, Cruz de Chalpón).
 This is what you get in the Execuform package. The basic shapes and reference material:
Outlines with a permanent marker to easily located the edge of the parts:
Parts off the backing sheet (keep the scraps. they will be used later):
Parts sanded up to the line previously traced:
Excursion to the spares bin and aftermarket parts drawers to find engines, props, wheels, etc.:
Separating the future cowls:
Gluing the cowl and float halves (not sure yet if I will present the model on floats are panted wheels):
Floats and cowls with a cursory tide-up (notice the roundish stern on the floor, that has to be sawed off:
Stern sawed off to real shape (the floats are a few millimeters longer to allow you to do this):
Float noses also come with the kit, in case you feel you need them to achieve a better shape -or mess-up):
The kit provides cowl fronts:
Carburetor intakes from unknown donor. As they are hollowed and firm in the drill bit, the mold edges are cleaned up:
Just in case the struttery for the floats is being prepared (I WANT MORE CONTRAIL AEROFOIL MATERIAL!!!!):
Inner "N" float struts assembled. Passenger seats scratched, pilot-copilot seats and control wheel from spares box:
Remember I said do not discard the scraps? here a cockpit/cabin floor is made of from a piece:
Dry run of the setup:
To deal with the roundish (inaccurate) finish of the float step, a cut is made:
A styrene sheet piece is inserted in the cut with glue:
So the blobby area can be later on removed:
After the glue has set, then you can cap the stern:
The float bottom flutes will have to be "sharpened" a bit using sandpaper wrapped on a dowel of appropriate diameter.
Edited by Moa
to correct typo
The tail surfaces have to be thinly sanded, without excesses. The two parts on the left still need some thinning down:
Correct sanding is the clue to any vacuum-formed model:
Pants are separated:
Using a contour gauge the bulkheads are made from the scrap plastic. Some of the halves are glued together. Demarcation of windows and doors begins:
39911856594_10c8448b8b_b.jpg}
Separation lines for all control surfaces will have now to be engraved. The tail has a complex assembly, and that will have to be taken care of too.
Edited by Moa
to correct typo
An almost unknown subject and a vacform to boot.
Interesting one this.
Wow, another one I've never heard of. Those basic sheets are the worst use of plastic sheet I think I've ever seen in a vac kit. There seems to have been no thought given to part spacing and minimising wastage!
Ian
One of those Barkley-Grows is at the Alberta Aviation Museum, in Edmonton.
AAM 111
Chris
I also had never heard of this aircraft, and the very fact a real one and a vacform exist of it is more than enough motivation to build it, personally not a great lover of Execuform vacs though, haven't built one for more that 25 years, and that didn't turn out well.
You on the other hand are doing a great job, will be following this one.
Ian
Hi Ian
I think that the separation of the molded parts has to do with providing a good and even plastic thickness throughout the sheet. If you put the parts too close you generate on one side wrinkles, and may be too-stretched styrene in some areas.
At least that was my experience using the Mattel vacuforming machine.
The pants are opened at the bottom to slide the wheels in:
The Aeroclub Wasp Junior is a perfect fit to the cowl:
Very neat work on the whole thing but the cowlings just made me say "wow" out loud.  So in text speak I guess that's a "WOL"!
Looking forward to more.
Regards,
Adrian
Never knew a vac or any type existed of this aeroplane. looks like a very basic vac form kit and your work on it so far is looking good. But I did know of its existence following my very first visit to Canada and the Aerospace Museum at Calgary, Alberta, just by the airport.  They have one there and what was interesting is the construction technique use in the building of it. Some kind of truss/trellis work to the wings and hexagonal spars. Something like that.
9 hours ago, Moa said:
Hi Ian
That makes sense, I've just never seen anything looking quite so random!
 It looks as though you're doing a fine job on it so far too!
Ian
The one you saw at Calgary is the same one that's in Edmonton now. I first saw in Calgary during a Family visit, in 1999. A dew years late it was moved to Edmonton.
Here's a picture from that '99 visit.
Calgary'99 007
And here's another that was also at Calgary at that time, but I didn't get it's registration.
Calgary'99 001
Chris
Edited by dogsbody
CF-BLV was NOT the one at Calgary when I went there in 2002. I would have remembered the yellow registration letters. It was CF-BQM on floats if I recall right.  The images above sgow the wing structure I was trying to explain. Nice to know there are more than just the one or two existing.
You are all more than kind.
Thanks for posting the photos, Chris, they will give fellow modelers an idea of the type.
That's right, Paul, and you can see that unusual wing structure in the photos posted by Chris.
I continue to build the fixed landing gear and the float version, jut to give an idea of the process for not so experienced modelers, but I think I almost made my mind on seaplane "Belvedere", which eventually became one of the museum airframes.
Belvedere (CF-BQM) had a blue fuselage and white flying surfaces and logo, with the floats painted in aluminium.
My other options were also a seaplane flown by Pacific Western, with and attractive scheme, and a more traditional Canadian Pacific machine on wheels, just because long time ago my grandfather flew Canadian Pacific from Argentina to the US.
Here the cowls are dry-fitted to the nacelles. So far, if you did things right, the fit is good and the outlines are correct:
Edited by Moa
To correct mistake
Work continues on the floats:
Belvedere had its intakes on the exterior upper quarters of the nacelles, the usual lower intake being absent.
I made the intakes already for the land version, and here the other ones are being made from a sprue leftover, first heating and bending (be careful):
38831767840_1e4e2ef40e_b.jpg}
Then cutting off the elbows:
Then flattening the area closer to the nacelle (base of the intake mouth), and later carefully hollowing out the intake a bit:
Edited by Moa
To correct mistake
The trailing edges of the cowls are now carefully and gradually thinned, just at the edge, to convey the appearance of metal sheet:
Modelers know that appearances can be deceiving, and if it is true that all main parts seem to be there, is the details that take a lot of the building time.
Here are the rudders for the floats, and metal pins being glued to the main float strut legs:
11 hours ago, Courageous said:
More excellent work from 'Mr Vacform' :yes:.
Hi Courageous:
I am, though, an equal-opportunity builder, and actually love them all: injected, vacs, resins. Bring them on! ;-)
Vacs, though, were for me especially important, since they helped me develop many skills later applied in many, many, scratch-building projects.
Vacs teach you enormities. And they help push your modeling boundaries, subject-wise and skills-wise.
But again, I love them all.
And of course, there are out there so many modelers much more qualified than me, true masters indeed. Once again I point (among many others) to the exceptional work of the Queen's subject Roger Holden.
I just like to play, and have fun. And in the process hopefully achieve a decent enough model.
Not sure how I missed this one.  Still, better late than never.
What an attractive aeroplane and some great vac modelling skills on display!
Edited by mhaselden
Now is a good time to look for things that need to be drilled, patched, reinforced, etc, before the parts are put together. In this case the holes for the exhaust tubes:
The kit presents a conundrum, since the aft-wing surface is represented both in the fuselage and the wing itself. You can't just glue to wing on, the area becomes way too thick, so one has to go. I opted for trimming the fuselage bit, since it was thick anyway:
Dry fit:
Piece for repair:
Now, after all those openings...
First the openings are drilled, then, VERY CAREFULLY, enlarged using other bits on the Dremel, step by step...
Maintain symmetry where needed:
Hand tools are better for the final approach:
Mold blemish, perfect to show that there are solutions for most things (like the little triangular bit above to patch the fuselage bottom too large cut):
Thin part fabricated to reinforce the area from the interior:
Glued on:
And once the patch is dry, may be Milliput (better than trying to build up with putty, which sometimes tends to soften the plastic) on the affected outside area and then sanding/contouring.
Edited by Moa
correct typo
The little Milliput patch:
State of the Union of Parts, or Barkley-Grow Commonwealth:
The floats are given a coat of primer to detect blemishes:
38853168780_5d356c86a2_b.jpg}
One good thing about this kit is that the plastic is wonderful to work with, and its gauge is conveniently thick (not overly) so sanding and repairs are easy, and structural integrity is preserved (no flimsiness).
