Shar2 Posted February 2, 2018 Share Posted February 2, 2018 Spitfire Mk.IX Detail Sets for Revell Brassin 1:32 The Revell Spitfire Mk.IX, while being a nice kit, is a little simplistic in areas, but then the price may reflect that the detail has been toned down a bit. If you want to add that much needed extra detail, Eduard come to the rescue with this cockpit set and two sets of gunsights, in early and late form from their Brassin range. Cockpit Set (632111) - The set comes in a very well packed cardboard with the parts in several zip lock bags and prevented from being shaken around by two foam pads. There are thirty eight resin parts in a mixture of medium and dark greys, plus a clear acetate sheet, a sheet of pre-painted etched brass and a sheet of unpainted photo etched parts, and a small decal sheet. Unfortunately the decals and acetate sheet are missing from the review sample so I won’t be able to comment on them too much other than where to use them. The detail on the resin parts is quite amazing, being super sharp, with good depth, although some parts have small sections of flash which need to be removed on top of the removal from the casting blocks. The cockpit is literally a tub made up of the front and rear bulkheads, what would be the fuselage side walls and the lower fuselage interior. The kits interior rib detail needs to be completely removed to allow the fitment of the tub, which shouldn’t take too long with a nice sharp curved blade and some sanding sponges. The moulded detail on the bulkheads and inner fuselage parts needs to be seen to be believed, add to this all the smaller sundry parts and you will have a truly amazing cockpit. There is an alternative resin instrument panel for which decals of the instruments are provided if you don’t want to use the etched items. Painting of the parts, especially those pre-moulded will be a bit of a chore, but with care you will end up with something of a masterpiece which would be good on its own, let alone fitted to the model. The resin is further enhanced with the addition of the two sheets of etched parts, the pre-painted seat belts which are quite complex, but with care and attention will build into a pretty amazing representation of the real things, as well as the instrument panel with the pre-painted dials on the back plate. All that needs to be added is some clear to represent the glazing. The unpainted sheet contains a selection of brackets, levers and fixtures for around the cockpit, such as the compass bracket, sight braces, seat details and toe straps. The acetate sheet contains marked out areas which go to make up the gunsight glass. Gunsight early (632113) - Contained in a hard blister pack with protective sponge layers you have three resin sights, resin mounting bracket and PE support straps. There is also an acetate sheet, which, when the marked areas are cut out, makes up the glass components of the sight. Detail is very nicely done on the resin, with the cogged edge of the range wheel being readily apparent. Gunsight late (632114) - As with the early sights mentioned above, this set also comes in a hard blister pack and also contains three sights and their mounting brackets in resin. The PE sheet contains the hood that mounts on top of the sight, and the acetate sheet provides the glass components. There is also a small decal sheet that has four NO HAND HOLD decals, using one for each sight provided; it goes on top of the sight glass hood, leaving one spare Conclusion The Revell Spitfire is a very nice kit out of the box, especially for the price, but it really could do with some extra detail to make it pop. With the cockpit set you can really go to town, and with all the parts provided it will look very busy and cramped, just as the real thing is. If you don’t want to go that far, then that’s where the sight sets come in, adding a bit of dash to the coaming. Review samples courtesy of 1 Link to comment Share on other sites More sharing options...
