Shar2 Posted February 1, 2018 Share Posted February 1, 2018 Russian MSTA S Detail Sets Eduard 1:35 It always seems to be a busy schedule at Eduard with several releases every month, this month being no different. The Zvezda MSTA S seems to have been well received and comes well detailed out of the box. But for those modellers who really need to have an ultra detailed model these three new sets will be just the ticket. MSTA S Turret set (36366) This single sheet set contains, naturally, all the fine detail parts for the vehicles turret. To begin with you get all the tread plates for the turret roof as well as a tread guard in front of the commander’s sight and bracket plate on the right hand front of the roof. The set also includes and new stowage basket, lots of small items such as new brackets, supports, a new saw, tool brackets, shields, jerry can holder, and gun cleaning rod holder brackets. There is also a new grille for the air filter unit and ammunition box lid, handle and rear sight for the heavy machine gun Hull Set (36367) This single sheet set contains a host of grilles and fittings for the hull. The grilles include those for the engine intakes, both large and small, and air conditioning intake. The set also includes additional detail for the gun travel lock, new heat shields for the exhaust, plus a host of handles, brackets and fixings for around the hull, including all new items for the unditching beam. Fenders (36368) Again, exactly what it states on the pack. Whilst the kit fenders are quite adequate, for scale thickness you will need to use these PE fenders. Before fitting the PE parts you will have to remove the front and rear mudflaps from the kit hull. These are replaced with PE parts, and there is an additional support plate to be fitted to the fronts. The fenders are then fitted with attachment clamps between each section, plus lifting handles on the bottom edge and a heat shield under the exhaust. Conclusion These three sets are great for those who like to have extra detail on their models, but, being separate it allows the modeller to pick and choose how much or how little they wish to add. Especially as the kit itself is pretty darn good already. Highly recommended. Review samples courtesy of Link to comment Share on other sites More sharing options...
