Paul A H Posted January 29, 2018 Share Posted January 29, 2018 Martin Baker Ejection Seat Handles (73611) 1:72 Eduard I've long said that the one thing you can do to improve a basic cockpit is to add harnesses to the seat. Now Eduard have taken things a step further by creating a set of pull handles for Martin Baker ejection seats. No need to make them out of fuse wire when you can snip one from this handy fret. Included are handles for the Mk.5, Mk.7, Mk.GRU 7, MK.10, Mk.12, Mk.16E US and Mk.16A. Review sample courtesy of 2 Link to comment Share on other sites More sharing options...
IGKent Posted January 30, 2018 Share Posted January 30, 2018 Great news! Link to comment Share on other sites More sharing options...
JamesP Posted January 30, 2018 Share Posted January 30, 2018 I wonder how fiddly it will be to get the two halves to lie flat against each other. Link to comment Share on other sites More sharing options...
Julien Posted January 30, 2018 Share Posted January 30, 2018 54 minutes ago, JamesP said: I wonder how fiddly it will be to get the two halves to lie flat against each other. I wonder if you cut them in half and only use the top half, who will ever see the lower half in a 1.72 cockpit? also this way you get double the amount! 3 Link to comment Share on other sites More sharing options...
Julien Posted March 5, 2018 Share Posted March 5, 2018 On 30/01/2018 at 16:34, JamesP said: I wonder how fiddly it will be to get the two halves to lie flat against each other. Just having used these its very difficult to get them to align. Its not so much getting them flat, as they are nickel on the other side even a slight miss-alignment gives you a bright edge. Even though my previous comment was meant in jest, if you do cut them in half and slightly angle the handle down you cant see the underside, and it eliminates the bright edge if they are not aligned. Julien Link to comment Share on other sites More sharing options...
