Wm Blecky Posted January 23, 2018 Share Posted January 23, 2018 Hi, I am looking to do an RCAF Mustang Mk.III: and am trying to locate an aftermarket decal sheet or suitable code letters decal. Any help would be appreciated. ThankS. Link to comment Share on other sites More sharing options...
stevehnz Posted January 23, 2018 Share Posted January 23, 2018 Looking at those against the roundel you're looking for something about 18-20", maybe some 12" 1/48 letters/numbers if there is such a thing? Steve. Link to comment Share on other sites More sharing options...
Rabbit Leader Posted January 23, 2018 Share Posted January 23, 2018 mmm... Something tells me that you may struggle to find suitable code letters that broad. If you are after super accuracy, then you may need to do the old 'slice and dice' method. Make sure you buy a sheet that has at least four identical letters / numbers - The Tasman letter / number sheets are very good. Grab a new-ish Xacto blade and cut each letter vertically, one towards the left hand side and the other towards the right. Then it's just a case of applying both decals at the same time (one slightly over the other) so that you achieve the correct width you want. I was struggling to find suitable width 45 Sqd codes for my 1/72 Mossie, so this is what I needed to do. With a little care and finesse (swearing is also acceptable in Australia!), this is what I did. Cheers and good luck.. Dave. 2 1 Link to comment Share on other sites More sharing options...
Wm Blecky Posted January 23, 2018 Author Share Posted January 23, 2018 Thanks Gents! Yes Dave, the more I look, the more your suggested method seems that it will have to be the way to approach this. Any idea as to just how often this style of numbers and letters was used? Other than your Mosquito (beautiful metal finish by the way) and the RCAF Mustang Mk.III I came across, I can not recall seeing it anywhere else. 1 Link to comment Share on other sites More sharing options...
Paul J Posted January 23, 2018 Share Posted January 23, 2018 Interestingly enough, those markings are on this issue of the Mustang III by AZ Models. Check on the Hannants here: https://www.hannants.co.uk/product/AZM7568 1 1 Link to comment Share on other sites More sharing options...
Work In Progress Posted January 23, 2018 Share Posted January 23, 2018 Given that it's on a Mosquito, that is most definitely not a nice metal finish. It is however a very nice representation of an aluminium-painted predominantly fabric-covered wooden structure. 1 Link to comment Share on other sites More sharing options...
TBC Posted January 23, 2018 Share Posted January 23, 2018 (edited) 12 hours ago, Wm Blecky said: Hi, I am looking to do an RCAF Mustang Mk.III: and am trying to locate an aftermarket decal sheet or suitable code letters decal. Any help would be appreciated. ThankS. IPMS Canada RT Volume 29 Number 4 has a great article on 441 Sqd Mustang III's. It also came with free decals in 1/72, 1/48 and 1/32, including markings to do 9G-L. Only codes and serial numbers were provided, no roundels and fin flashes. Edited January 23, 2018 by TBC 2 Link to comment Share on other sites More sharing options...
Wm Blecky Posted January 24, 2018 Author Share Posted January 24, 2018 13 hours ago, TBC said: IPMS Canada RT Volume 29 Number 4 has a great article on 441 Sqd Mustang III's. It also came with free decals in 1/72, 1/48 and 1/32, including markings to do 9G-L. Only codes and serial numbers were provided, no roundels and fin flashes. Thanks TBC. I don't suppose you know where I could find this decal sheet??? I had checked the IPMS Canada website and no surprise, they are sold out Link to comment Share on other sites More sharing options...
RZP Posted January 24, 2018 Share Posted January 24, 2018 I may have this sheet and won't be using the 1/72 decals. I'll check my stash and let you know tomorrow. I helped the author of the article with research info and photos. Richard 1 Link to comment Share on other sites More sharing options...
Wm Blecky Posted January 24, 2018 Author Share Posted January 24, 2018 3 hours ago, RZP said: I may have this sheet and won't be using the 1/72 decals. I'll check my stash and let you know tomorrow. I helped the author of the article with research info and photos. Richard That would be outstanding and greatly appreciated! Thank you Richard. Link to comment Share on other sites More sharing options...
RZP Posted January 24, 2018 Share Posted January 24, 2018 Found them! Send me a PM with your address and I'll get them on the way to you. Richard 1 Link to comment Share on other sites More sharing options...
Wm Blecky Posted January 24, 2018 Author Share Posted January 24, 2018 4 hours ago, RZP said: Found them! Send me a PM with your address and I'll get them on the way to you. Richard Wonderful! Thank you Richard. PM coming. Wm. Link to comment Share on other sites More sharing options...
