Spitfire Mk.IXe - 1:72 Eduard ProfiPACK
Julien
Spitfire Mk.IXe
When the prototype Spitfire took to the air for the first time on 5 March 1936, few involved could have foreseen where the development of the type would lead. By the end of the Second World War, the type had earned itself a place in the history books as well as the nation's psyche. One of the ultimate Merlin powered variants was the Mk.IX. The Mk.IX was a response to the appearance of the Focke Wulf Fw190, which proved itself more than a match for the Spitfire Mk.V. Powered by the two-stage supercharged Merlin 61, the performance of the Mk.IX was a quantum leap over its forebears, enabling the Spitfire to meet its German foe on equal terms. By the end of the War, over 5,600 Mk.IXs rolled off the production line at Castle Bromwich.
The Kit
Eduard have earned an excellent reputation in recent years with world-class models such as their 1:72 Hellcat, Bf110 and MiG-15. Their models typically feature a mixture of exquisite detail and superb if complex engineering which puts them right at the pinnacle of modern kit manufacturers. The latest all-new 1:72 kit to roll off the Prague production line is the Spitfire Mk.IXe. The e here referring to the wing type which housed a pir of 20mm cannon out board of a pair of 0.5" calibre machine guns.
Inside the sturdy box are five sprues of parts moulded in the blue-grey plastic often used by Eduard and a single sprue moulded in clear plastic. Altogether there are well over 150 plastic parts and, as this is a profipack edition, the plastic parts are accompanied by a small fret of pre-painted photo etched parts and a set of die-cut paint masks. The instruction book is a glossy, stapled A5 affair which includes full-colour painting diagrams. The overall impression is of a really premium quality package. The quality of the mouldings is up to the usual Eduard standard, with clean, crisp details and no flaws anywhere. As with other recent kits from Eduard, there is plenty of fine detail, with parts such as the cockpit comparable to high-end resin items (which, in turn, should tell you how good Eduard's resin cockpit is). The surface detail on the outside of the airframe is exquisitely rendered, with fine recessed panel lines and delicately engraved rivet and fastener detail.
It's clear from the outset that Eduard have taken an uncompromising approach when it comes to detail. The cockpit is fabulous, particularly so in this Profipack edition with its extra photo etched parts. I don't think I've ever seen a Spitfire kit in this scale with a seat made up of three parts, so it's just as well that a set of pre-painted harnesses have been included too. There is a choice of plastic or photo etched parts for the pilot's armour, and further tiny photo etched details for the control column and throttle controls. The instrument panel also benefits from the addition of photo etched parts, with a detailed plastic alternative provided if you don't fancy using the metal parts. Unusually, the cockpit sidewalls have been moulded separately. I can only think that Eduard have done this in order to maximise the amount of detail they have been able to pack in, as well as paving the way for their resin cockpit, which uses the same approach. Once the cockpit has been assembled and painted, it can be fitted between the vertically split fuselage halves, along with the engine firewall, a blank part into which the propeller is fitted later on, and the pilot's head armour. The leading edge wing root also has to be fitted at this stage. The fact that these parts have been moulded separately to the rest of the kit is testament to Eduard's commitment to detail, if not buildability!
The breakdown of the wing is no less complex. As you might expect, the lower wing has been moulded as a single span, with separate upper wing surfaces. Between the two you must sandwich seven parts which together make up the walls of the main landing gear bay. The ailerons and wing tips have been moulded separately, which allows multiple version to be built from the same moulds (alternative parts are included but marked as not for use for the aircraft depicted on this kit's decal sheet). The same applies to the rudder and elevators. Multiple alternatives are included on the sprues, so make sure you use the correct version for your intended subject. Choice is good though, as it makes for a very comprehensive package. The upper and lower cowlings are moulded separately, with the former split along the middle. Even the wing radiators are made up of six parts each, with the surface of the radiators themselves picked out in photo etched metal in this boxing.
Turning the model over, the undercarriage is just as detailed as the rest of the kit. Each of the main landing gear legs is made up of seven parts, with the tyres moulded separately to the hubs and photo etched parts to represent hob covers (where fitted). The separate tyres will make painting easier, which is just as well as the included paint masks don't cater for the landing gear. A long range fuel tank and a couple of small bombs are included, as are a two different types of slipper tanks. The wing cannon barrels are moulded separately, which means they can be added at the end of the build in order to avoid accidental damage.
Decals
Decals are from Cartograf(main sheet) and Eduard (supplemental and should pose no issues. Markings are provided for 5 machines.
  • 2003 (ex TE531), 105th Tajeset, Ramat David Air Base, Israel, September 1953
  • SM147, No. 73. Squadron RAF, Prkos Airfield, Yugoslavia, April/ May 1945
  • RK856, flown by Maj. C. Golding, CO of No. 3 Squadron SAAF, Italy, 1945
  • SM 26, Vorderings Vliegschool/Ecole de Pilotage Avancé, Brustem Air Base, Belgium, 1952
  • PL124, No. 312 Squadron RAF, B-10 Airfield Plumetôt, France, June 1944
Conclusion
This is a welcome release from Eduard in 1.72 for all the Spitfire fans out there. Highly recommended.
Review sample courtesy of
  • 1 year later...
I've got an overtree kit that was moulded in an rather dark grey plastic. I would say that I prefer light grey plastic (as Airfix) as it is easyer to paint and to see the details.
Also I can't find any "headrest" above the pilot seat as in other Spitfire kits. How common was this concerning Spitfire's?
/André
Edited by Andre B
