giemme
It's a HOG! 1/72 Italeri A-10A Thunderbolt II
1 hour ago, giemme said:
Magnificent! :clap: Welcome on board, Andy :thumbsup:
One question, if I may: I see you modelled your A-10 with the split ailerons, to act as speed brakes. Is this a possible configuration for a parked aircraft? The kit allows for this option, but I couldn't find, from a first quick search, any pictures of airplanes with this feature deployed. TIA
Welcome to you too :thumbsup:
Ciao
Giorgio
The model was done as an extended review/build article, and it was simply a case taking up an option by modelling them open - I'm not sure if it's an actual possible configuration....
....but they were closed on the subject aircraft when I photographed it for the same magazine issue, as seen here (not my photo):
Got it, thanks Andy :thumbsup:  I'll keep searching though, 'cause I kinda like the idea to pose the ailerons split open :)
Ciao
20 minutes ago, limeypilot said:
It definitely does Ian, thanks :thumbsup:  Although I think that aircraft is taxiing and not parked, so part of the doubt is still unsolved :hmmm:
Hopefully @Gene K can recall something about this ... :)
Ciao
3 hours ago, limeypilot said:
Disproves my assumption that the interiors would be white, as depicted on my model!
Detail & Scale Vol.19, page 40, bottom right photo - 79-166 of the TAWC parked on the Eglin AFB ramp with a yellow cover over the unoccupied ACES II seat.....
Just found this - lots of links to A-10 stuff here:
http://warthognews.blogspot.co.uk/
Edited by andyf117
Slightly OT (forgive me Giorgio) but a question for the hognoscenti (groan).
Is this kit a better bet than the Academy 1/72 one? I have the Major (then Captain) Campbell boxing of the Academy kit in the stash, and had vaguely thought about giving it a shot during the 10th anniversary group build, but if it's no good it might fall back to the bottom of the pile.
On 1/10/2018 at 10:40 AM, giemme said:
76th TFS A-10A No. 1
BTW, does anybody know where to find more pics of this specific airframe? This one seems to be the only one showing up on Internet.
A
I can't help with that particular airframe, but they were all very standard markings  ... excepting the Crew Chief art on the inside of the step doors. For example, here's one from the 23rd Tactical Wing, 76th Tactical Fighter Squadron Vanguards at England Air Force Base back in 1982: :whistle:
(Yes, the nose gear door needs correction)
Gene K
Excellent stuff Andy, thank you very much! :thumbsup: Duly bookmarked. Thanks also for the heads up on the book :thumbsup2:
Gene K
I think I know the pilot of that aircraft ... :D :D
Ciao
I like the look of this one giemme, I have a soft spot for this brute!
Rob
10 hours ago, andyf117 said:
If the article's in SAM Vol 20 No.9....
1
That's the one - with a photo of my Douglas VC-9C on the inside back cover.
Rob
Cheers Rob, great to hear from you :thumbsup:  Glad to have you on board, mate :)
Ciao
On 1/13/2018 at 7:26 AM, giemme said:
 Is [speed brakes open] a possible configuration for a parked aircraft?
I've dug through the Dash One (Flight Manual), and can't find engineering logic confirming or denying that the speed brakes can stay open without electrical or hydraulic power. However, the cockpit check before starting engines has the  pilot place the speed brake switch in the position to match the airplane ... same with the flaps. Having said that, I don't ever recall seeing the speed brakes open on a parked Hog (but then,  the memory cells are not as bright as they once were).
To avoid any possible "mis-configuration", why not place a pilot in the cockpit and a crew chief alongside the airplane, simulating after start checks? In that "pose" you could put any control surface into any position you want - the speed brakes, the flaps, the slats, the ailerons, rudders, elevators ... . :phew:
If you decide to open the speed brakes, here's a diagram showing the full open position (there are no preset positions, so you can pose them at any angle).
Gene K
Edited by Gene K
:) Great insight (as usual; I had no doubt you'd come up with useful info :wink:  )
I shall ponder that; any hint by anybody who knows about suitable USAF pilot and crew chief figures during the first Gulf War would be greatly appreciated.
This solution would partially hide the nice detail of the resin cockpit and would require a base (not exactly the house specialty at Giemme productions), but might be worth it.
It raises a couple (three, actually) of further questions , though:
- would the boarding ladder be deployed or at rest, with its door closed?
- is it possible that the avionics bay is open during this phase? I only ask because the kit has the open bay as an option
- @philbrad posted this link http://www.2951clss-gulfwar.com/piwigo/index.php?/category/1 in which you can see the airplane I'm modelling being repaired after battle damage. In one of the pics (this http://www.2951clss-gulfwar.com/piwigo/upload/2016/06/18/20160618060210-b099a498.jpg), it looks as though the inside surface of the tail planes, where the elevators are hinged, is painted a sort of yellow. The kit instructions call for the same color for the avionics bay; would it be the same for the inside of the wings, which gets visible once the ailerons split? And what about the ailerons "interior" surface?
TIA
Ciao
Edited by giemme
5 minutes ago, Gene K said:
Well, Gene, see here at 00:32!
Good, that gives me more options :)
Thanks for that link, Gene :thumbsup:
Ciao
Modern Hobbies has very nice pilot figures, but I haven't seen any ground crew on their site. I think Airfix have a 1980's -ish ground crew set.
:doh: Of course they have, I bought that very same set in may 2016, for an upcoming (well, sort of :) ) project involving an F-14 ... I'm getting old ... :chair:
Thanks a lot for the heads up, Cookie :thumbsup:
Since we are here, how about a Monday Progress Report? :wink:
Time to make that tub fit into the fuselage; I removed the pouring block (took the easy way out, Dremel-ing most of it) and refined the bottom surface using a sanding block and a chisel
dav
Before proceeding, though, I measured the gap remaining between the fuselage halves when inserting the resin tub as is: it was a good 1.3mm. The fuselage side walls are at best 1.2mm in the thicker spots, which means I had to reduce their thickness down to a maximum of 0.35mm; very thin, and making that area very fragile. So I thought I'd better first cut out the kit coaming and fix that without risking to break the front fuselage off ...
I cleaned up the resin IP (sorry for the blurred pic)
dav
These were the parts to be removed
dav
and here's a preliminary dry fit, before starting to remove the excess plastic form the sidewalls. The IP was glued to the tub with a dollop or two of PVA, for the sole purpose of test fitting the whole assembly while going.
dav
After much scraping/filing/sanding (mainly on the kit plastic, but also on the resin tub, to some extent), I got here
dav
dav
dav
A quick dry fit of the windshield showed a small gap port side
dav
while starboard was Ok-ish
dav
So to fix that, I added a plastic sheet cutout (0.2mm thickness) glued in with Tamiya Green Cap and filled with CA
dav
:hmmm:  Looks like there's someone on the background of that pic that is going to join the workbench, at some point ... :D
After refining
dav
dav
At this point, I washed all the resin parts in warm soapy water and let them aside to dry; since I felt like fettling ( :chair: ) I started working on the nose, to accommodate the Master GAU-8 gun.
Here's the starting point
dav
Using various drill bits and my scraping gizmo ...
dav
... and a round file, I got here
dav
Test fit
dav
dav
I then test fitted the nose to the rest of the fuselage: this is going to need some fairing in/gap correction ... :frantic:
dav
dav
More fettling: I started gluing the PE bit to the cockpit tub. Ruder pedals
dav
and these two things right behind the seat, port side, which I bent around a toothpick to obtain the rounded shape (all PE parts glued in with CA)
dav
Seat removed from pouring block and test fitted
dav
The resin canopy opening mechanism is kind of fiddly ...
dav
dav
It's made of two parts that are supposed to hinge to each other, and you need to put a rod underneath the front one to keep them in the open position, so I did do a dryfit to try and determine the length of that rod. Fiddly, as I said, but I'll come back to that (also with some pics to explain better) in due course.
Meanwhile, all comments welcome
Ciao
Great start there Giemme.
Thinning the walls of the fuselage out to accommodate the tub would scare the "Brown stuff"  out of me.
Good fit though, and the cannon end looks well smart.
Maybe a bust to be painted?
Simon.
Thanks Simon :thumbsup:
You just need to take your time and don't rush it  - and keep dry fitting to check where you are
Full figure, actually - 75mm scale ... :ninja::D
Ciao
It always gives me a sense of satisfaction when I get a resin tub ( especially Aires ) to fit in the fuselage it's intended for. That looks pretty good to me, and I'm sure you have other embellishments planned. :clap:
John
John
Thanks John :thumbsup:  Satisfaction and relief, in some way :phew:  :D  As for the rest, I have ideas coming up as I go, will see ... :wink:
Ciao
Love that gun from Master - that's going to make a big difference. Good job fitting the cockpit.
Bill
Me too. That'll be a focal point!!
Giorgio, you inspired me to look at 1/72 A-10 detail sets, and I came across these :
https://www.eduard.com/store/Eduard/A-10-1-72-1.html
- what are your thoughts, in particular the cockpit set vice Aires?
The weapons set is certainly in my future, and the cockpit set and all the extras are extremely enticing.
Gene K
Edited by Gene K
Bill
Thanks Bill :thumbsup:  I agree, the master gun is a huge improvement over the kit part. I'm also thinking of some scratch built improvement for the fairing - will see.
Gene K
Thanks for suggesting to get that Master set in the first place :thumbsup:
As for Eduard detail sets:
judging from those pics, all the PE details are extremely interesting (look for instance at the inside of the ailerons); however, I think I still prefer the resin cockpit for three reasons:
- the resin seat looks much better than the plastic + PE rendition
- I very much prefer the resin IP + clear acetate+ PE solution rather than PE printed gauges; it looks more realistic to me
- the pre-printed colors on PE aren't matching any actual color, so they will require additional paint job
Having said that, Eduard cockpit set is still excellent stuff, and would highly improve the look of the kit
Ciao
