Bf 109F Essentials - 1:48 Eduard Brassin - BigSIN
Bf 109F Essentials
In this set Eduard offer us the 109F cockpit, wheels, control surfaces and pitot tubes.
Cockpit Set
The set gives you a complete new cockpit including sides and floor which will fit into the model with some work being needed on the kit moulded details. A mix of resin and PE goes into this to create a small model in itself. There is the option of using a one part instrument panel, or a multi part one using the PE & film supplied. Though lets be honest if you are going to the time, trouble, and expense of this set then it really has to be the multi part affair.
Control Surfaces
This set has has the rudder, tail surfaces and flaps in resin. Balance horns are also supplied in resin. Trim tabs are supplied on a small pe fret (not pictured).
Wheels
This set has the two man wheels with separate spoked hubs. The tail wheel is moulded with its strut in a stronger type of resin.
Bf 109F&G Pitot tubes
This set has three replacement pitot tubes in resin to replace the kit parts. These will I suspect be more susceptible to damage than the kit parts despite looking more realistic.
Review samples courtesy of
