stevehnz
Dan-Air Comet conundrum
1 hour ago, bootneck said:
Thanks Chris, I have an Airfix Comet hence my query here.  I flew in a Comet 4C on my first posting to the Far East,  waaaayyyy back when, and am watching this thread for build guidance notes.
Mike
B737-800?  :smirk:
I haven't forgotten the 737 Mike and if you can make use of them, I believe I have a spare set of the Comet 4C wing tanks if you're a good boy. :thumbsup:
Chris.
If you're stuck the drop tanks from the Airfix 1:72nd Vampire T11 are nigh on perfect in size if you can cut a suitable hole in the Airfix Comet wings to receive them. The tanks have moulded-in pylons, but this works in your favour as there's a curved fairing where the wing leading edge meets the inboard edge of the tank, and the pylon helps form this.
Here's my BOAC Comet 4 I did a few years ago (also 26 decals). I cut 1.99 scale metres (1.38cm) out of the fuselage to give the correct length - this equates to two windows which should be the third and fourth ones thus reducing the forward cluster to six each side. In addition to adding the tanks I also extended the wingtips using bits of scrap plastic.
To further clarify the lengths/wingspans:
Comet 1: Original variant, long span wings (115ft) and short fuselage (93ft)
Comet 2: Avon engines, same wingspan and slightly lengthened fuselage (96ft 1in)
Comet 3: Demonstrator version only (1 aircraft). Same wingspan and substantially lengthened fuselage (111ft 6 in). Wing Tanks
Comet 4: Dimensions as Comet 3. Wing Tanks
Comet 4B: Short range, high capacity version originally for BEA. Longer fuselage (+ 6ft 6 in), shorter wings (Sorry, can't remember how much). No wing tanks. This is the variant provided by Airfix and IIRC the wingspan is correct for the 4B.
Comet 4C: Export/RAF version which combined the long wings from the Comet 4 (with wing tanks) and the long fuselage from the Comet 4B.
I believe Dan Air operated all three Comet 4 subtypes - they basically bought all the airworthy Comets available.
Hope this helps!
Edited by Vulcanicity
@Vulcanicity Thanks for showing that, I had been thinking about a -4 on BOAC colours as a follow on to a Dan-Air -4B as covering most of the important differences between the later marks. I don't 'spose I could persuade you to reinstate the photos in the build thread for this? :)
Steve.
Edited by stevehnz
Chris.
Thanks Chris!  I am being as good as Mr Good, from the planet Good :giggle:
 This really does help Phil, thank you for posting these details. :clap2:
I have the following books which should help me combine the above modelling info with what I might find within their pages,
Oh dear;  despite all forms of resistance, I seem to be shifting over to the dark side.  Next, I shall be using the A-word in everyday conversation! :lipssealed:
Mike
Chris.
Chris, don't forget to send Mike the 737 with it's wings as well. :tease:
I hear that he has plenty to spare :giggle:
Does anyone know if there are any replacement engine intakes for any of the Comet kits, as they are all pretty horrendous.
XVTonker
Dan-Air became THE Comet airline of all time..They had 4s,4Bs,4Cs and ex RAF C.4s which was a 4C as far as I can make out but it is still  a C.4 . Lasham had a Comet scrapyard to end all.literally. Quite a few, I think were just for spare parts though including selling bits back to the RAF for the Nimrod fleet.
Edited by bzn20
XVTonker
Not in current production so far as I'm aware although I'll be delighted to be proved wrong.
Yeah, Yeah, Yeah.  :lalala:
