JohnT Posted January 5, 2018 Share Posted January 5, 2018 I am hoping some Lancaster experts can set me straight. For boring personal reasons I fancy doing my 1/48 Tamiya Lancaster as LM220 "Getting Younger Every Day" which was a B1 or so I understand. It has a number of issues that modifications from the kit The upper turret goes and will be faired over and I will need to choose the correct bomb aimers blister big or small. Now answered and solved thanks to RJP below The bomb bay doors are bulged and here is the first question. Are the bulged doors the one and the same for the "normal" load out and the Tallboy load out? I have had a read and some say they are and some say they are not. If they are not would anyone notice the difference and if they are different in what way? I also read that the cockpit floor needs raised a little as does the bomb bay roof - gulp! I might cheat there. I can get a 3d printed Tallboy from here and it looks the part however that is not a photo. I suspect the price is such that I will speculate and buy it. www.shapeways.com/product/P9W45JP2C/quot-tallboy-quot-bomb Also Kits World do the decals for her so another problem solved. Anything else I am missing maybe? Thanks for pointers and help in advance as always John Link to comment Share on other sites More sharing options...
RJP Posted January 5, 2018 Share Posted January 5, 2018 Have you tried a google image search? I found this, and one of the photographs shows the later bomb aimer blister: http://www.planetdiecast.com/index.php?&option=com_content&view=article&id=88814&catid=13 2 Link to comment Share on other sites More sharing options...
JohnT Posted January 5, 2018 Author Share Posted January 5, 2018 4 minutes ago, RJP said: Have you tried a google image search? I found this, and one of the photographs shows the later bomb aimer blister: http://www.planetdiecast.com/index.php?&option=com_content&view=article&id=88814&catid=13 Thanks for that. I did do one based on "Lancaster LM220" and got lots pictures of corgi die cast models along with profiles but not much in the way of actual photos. I found the one at the top of the link but the one at the bottom clears up the blister size - fantastic thanks. Link to comment Share on other sites More sharing options...
NG899 Posted January 5, 2018 Share Posted January 5, 2018 (edited) Hi John, Stretching the memory banks back a few years, to 2005 on this one. I built a 48th scale Lanc a family friend flew with 115 Sqn at RAF Wicthford in mid-late 1944, HK551, A4-E, back then and made a good few changes to the kit. HK551 had smooth-fronted bulged bomb bay doors which could take 8,000lb-ers. These were similar in profile and contours to the bulged doors used on the Mk.IIs, but without the step in their profile at the front; which is why I have called it smooth-fronted. I made mine closed and built them from styrene sheet formers, planked with styrene strip, covered in filler and sanded smooth. The model depicts the aircraft after its return from a mission however, technically, all the guns should be pointing skywards; to avoid any injury to others or damage to hardware caused by careless cold ground crew fingers and ricochets off the ground. If you drop me a PM with your email address, I'll send you my build notes, the finished model appearing in a Model Aircraft Monthly article in January 2006, which included a lot of 'wet-film' build images; sadly not scanned. Other than the bomb bay doors, areas I suggest you look at are: - All turrets > I scratch built the internal details for all and would now use resin or metal gun barrels too. - The cockpit > again, I scratch built all the internal details, making use of the kit's instrument panel and control column yoke. - Propellors > HK551 had the early pointed ones, which I made by reshaping the kit parts. - Engine nacelles, exhaust and shields > I recommend the Belcher bits items to replace the kit ones. - Bomb-aimer's blister > the kit has the shallow one, I got HK551's deeper one from a Paragon set which, iirc, had the under-fuselage blister in it too. - Ailerons and elevators > the Tamiya kit has the late/post-war metal ones, HK551 had fabric covered ones, having sanded the kit ones free of rivets, I added rib details from styrene strip. - Tyres > HK551 had untreaded tyres, I filled the kit ones and sanded the smooth, adding weighted bulges from filler. - Additional detailing like rudder and elevator trim tab balances, the Monica aerial and window dispenser were scratch built. I also opened the rear door and added some interior detail in there for the fuselage structure, ammunition runs and flare chutes. Remember that on the outboard engines the outboard exhaust passed under the wing, not over it. I have seen too many good Lancs spoiled by the weathering going over the wing. Here are a few photos to help you visualise what I have said above. Cheers Nick Edited January 6, 2018 by NG899 3 1 Link to comment Share on other sites More sharing options...
JohnT Posted January 5, 2018 Author Share Posted January 5, 2018 Nick thats a lovely build and very helpful. I will PM with my e-mail address. much appreciated John Link to comment Share on other sites More sharing options...
Finn Posted January 5, 2018 Share Posted January 5, 2018 Here are a couple of drawings i found online that may be of help: Jari 1 Link to comment Share on other sites More sharing options...
JohnT Posted January 5, 2018 Author Share Posted January 5, 2018 Jari Many thanks for those. Very helpful for the modification that may be required John Link to comment Share on other sites More sharing options...
NG899 Posted January 6, 2018 Share Posted January 6, 2018 John, Three more photos added to my original post. If you can get hold of a copy of Lancaster at War Vol.2 by Ian Allan there are good Avro drawings in the front and back which will help. (I'll reply to your PM this afternoon.) Cheers Nick Link to comment Share on other sites More sharing options...
Mancunian airman Posted January 6, 2018 Share Posted January 6, 2018 (edited) Dont forget to polish off the turret framing on the front turret so that you can frame it correctly . . . . The rear 'Escape hatch' needs to re-sized as well to match the front one I think your aircraft had windows so that shouldn't be a problem Here is my effort that might give you some ideas ? Research is a must I believe so Good Luck with the build Edited January 6, 2018 by Mancunian airman 1 Link to comment Share on other sites More sharing options...
