stevej60
Tamiya M4 in 1/35 scale.
Well that worked a treat!  :coolio:
One minor issue, per discussions elsewhere, the return-rollers were steel and should be OD, however the paint wore off fast so a hit of OD to the centre and some graphite on the wheel rims later should work just nicely (guess who has quite a few 1/72 return rollers to metallicize).
Cheer's Sarge an easy fix thank's for the info!
And 'metalize' the tops of the skids a bit, too!
Looking good Steve.
Rearguards
Badder
Thank's for the input guy's now corrected rollers and a dry brush of Aluminium on the  skid's,started the track painting as apart from
a "dusting" once the track's are done I'm about there as far as the lower hull is concerned,one question were the pads on the track's
Rubber or metal?
Rubber or metal?
Hi Steve,
Nice progress. You're slightly ahead of me as I haven't touched the tracks yet. I have just glossed the complete lower hull assembly though and am about to start weathering.
To answer your question I'd have to see the other side of the tracks, but I assume they are flat rectangular pads, in which case they were rubber.
Rearguards,
Badder
4 hours ago, Badder said:
Hi Steve,
Rearguards,
Badder
Thank's badder here are said track's base coat painted ready for weathering and detail painting of those outer track pad's.
Now I can think of moving onto the upper hull which just pop's on when finished but putting to one side now for a couple of day's as work bekon's!
The tracks look like T48 rubber chevron to me.....Useful reference here (scroll down a bit, clicky images, then clicky again for massive):  http://www.theshermantank.com/sherman/suspensions-and-tracks-what-makes-for-a-smooth-and-comfortable-ride/
Nice job Steve, what colours did you use on the tracks.
:ditto: :D
Regards,
Steve
1 hour ago, fatfingers said:
:ditto: :D
Regards,
Steve
Thank's folk's I mixed Tamiya hull red with their deck tan,two coats brushed into all the detail,when dry I wiped a just moist(acrylic thinner)cloth
gently across the chevrons to bring back the rubber finish then a thinned black wash(NATO black/water) into the detail and left to dry, brushed
aluminium (almost dry on the brush) along the edges of the track's to finish.
That's looking excellent Steve. Very good progress. :thumbsup:
Kind regards,
Stix
Nice work Steve. Is that 'dry brushing' on the bogeys? Looks brilliant. May have to borrow that :whistle:
Many thank's,I have an old flat brush(in fact the wood part's long gone} just for dry brushing the trick is never clean it,just chuck it in the box and
leave it if you use acrylic's,probably not a good idea with enamels!
Hi folk's,little progress this weekend with the next step,quite a few partsin the turret with a complete gun mantle radio etc,I will be
painting the interior although I'm apprehensive about adding the crew as I'm not a lover of figure painting.
Looking good Steve, figures do bring things to life.
That looks great under a coat of paint. And I agree with Ozzy - figures really do add to these AFV projects.
Kind regards,
Stix
Kind regards,
Stix
Thank's Stix I,m going to add the commander in the turret,I've got all the handles and light's all fitted ready for primer great to be building
another tank so not really ruling out a second entry later maybe in a smaller scale.
Good job Steve, nicely painted bogeys, I like those sand skirts
Cheer's Hewy,gave the upper's a base coat after pre-shading the reccesses in black then on low power a coat of sand,I'm debating wether to
give it a hard edge but in this scale and due to the fact I think the sand would have been an in theatre paint job may leave as is.You
tend to find the gloss coat blend's it all nicely.
Edited by stevej60
Aye up Steve.
That looks great in those colours! Nice job :coolio:
Regards.
Steve
Lovely!  :thumbsup:
That's it.....I will build all my UM M4A1s after all, but I'm doing some of them like that!  Italy, here I come.  :P
Cracking job, looks real good steve
As ever Steve, you are motoring on and to good effect - it looks superb in it's camo and decals. :thumbsup:
Kind regards,
Stix
