beetcleaner Posted December 28, 2017 Share Posted December 28, 2017 Spraying Humbrol Matt 01 Enamel primer thinned 50/50 through my Badger 200NH. Have never had any trouble spraying any paint before but cannot get paint to flow evenly, or sometimes at all,even with needle screwed all the way back Im religious about cleaning after every session and was happily spraying the above paint last night with no problems at all Teflon washer is ok, needle and tip clean, air pressure is at 20psi and feeder tube is clear with hole on top of jar also clear Would a soak in cellulose thinners help even though it is stripped and cleaned after each paint job? Any advice would be much appreciated Link to comment Share on other sites More sharing options...
little-cars Posted December 29, 2017 Share Posted December 29, 2017 Have you tried just putting water through to see how it behaves ?? Paul Link to comment Share on other sites More sharing options...
spitfire Posted December 29, 2017 Share Posted December 29, 2017 The only problem that I have had with my 200NH is the air valve plugging up, I used to clean my airbrush with white spirits or turps which did not do the valve any good, I now use the more expensive Badger airbrush cleaner and have not had any problems since switching. I remove the needle and spray through the airbrush after each session. Hope this helps Dennis Link to comment Share on other sites More sharing options...
