exdraken
IAI LAVI 1/48 -help?!
Hello everybody
don't really know myself what got me into buying this general shape of resin supposedly representing the best!"! availabl 1/48 model of IAI attempt to challenge the F-16s reign over Israel in the late 1980s
I already learned quite some things, e.g. that it was not powered by a PW-100, but a smaller version (GE-404 sized), also intended for the IAI Super Phantom, the PW 1120...
all in all based on the F-16, but way smaller!!
- interesting-!!!
so, here it is,
not "extremely" detailed or symmetrical (port/ starboard) etc...
any good ideas on how to tackle it?
decals look good at least!
20171118_223216_1
20171118_223234_120171118_223615_1
so here is what I have got an d my best attempts to align the fuselage ;), and also fit the cockpit section into place
20171118_223247_1
20171118_223947_1
F-16 style intake, also fits nearly perfectly :P
relatively nice PW-1120 with the characteristic sectioned petals
20171118_223434_1
so again, any ideas apart form the bin would be very welcome!
Best,
Werner
Are those fuselage gaps caused by internal bits being to wide to fit inside the fuselage? If so you may need to thin the resin in the interior of the fuselage and/or work on reshaping the internal bits to fit the fuselage.
You may need to get some auto body filler if that's not the case. :idea:
If everything fits inside, but you still have the gaps, the fuselage halves may be bowed and you might try hot (not boiling) water then attach them to a length of board or something similar to get them to straighten out. It may take multiple applications, just be careful of your water temp. Someone will be along shortly, Im sure, to correct/expand on my post.
thanks a lot for your valuable input!
I guess there is not too much distortion, but mainly bad moulding.... so filler (lots of it), and scratching will do the trick maybe!
:analintruder: Very nice kit, Werner!
I concur with what Don has suggested above; I'm rather new to the dunking of resin parts in hot (not boiling) water technique, but what I've learnt so far is exactly as Don advised: it's a lot better to heat the resin part gradually than it is to do it suddenly and fast. I've found out that while some resin will straighten out to their unwarped form, some other will still need persuasion, so to speak. Have some iced water always near for when you've straightened your part to the desired shape.
You may have to dunk a part several times in order to get it straightened to the correct shape. When the shape is almost there, you might use a hair dryer to heat the part instead of the hot water - that's if your sheila approves of. :rolleyes:
What's with that intake? If the overall shape is okay but the width (or height) differs, I found it better to cut parts in their middle section (or even transversally) to see if they fit, rather than filing or sanding them to fit.
Don't be afraid to try to straighten resin parts by dunking them in hot water, but watch out how hot the water is or how long you dunk your parts in it if the water's too hot.
Cheers, my mate
Unc2
Greetings from the US,
I have 2 of these kits and they are a REAL pain. There are numerous problems with them from not being true to scale and having numerous air holes in them. I have spent roughly 2 years on one of them just to get something to look close to the real thing.:rage:
If you have some spare F-16 parts, you can come pretty close to getting the kit up to speed. That is what I did. My cockpit is from an F-16C and the weapons stores are from Hasagawa's weapons set. The landing gear bays need a ton of work. I used a spare NLG bay to get something close. The MLG bays will  need to be scratch built. There is little room to get anything in them the way they are.
Yes. The 1/72 scale is a lot better than the 1/48 scale. Both kits will need to have the panels scribed because they come w/o any detail. The 1/72 scale had a better fit to them and required less putty. Good Luck!
