ModellerUK Posted December 13, 2017 Share Posted December 13, 2017 Hello, I am not sure I am in the right area of the site however I have a 1/72 Tornado Revell Kit which I bought from a member of here about a year ago and I am looking to get stuck into it, I would like to scratch build some of the details in the AV bays however I have never scratch built before, how is best to approach it (best materials/ techniques for correct shapes etc) Link to comment Share on other sites More sharing options...
Black Knight Posted December 13, 2017 Share Posted December 13, 2017 Basic scratch building materials; Plastic card sheets in 10 thou = 0.25 mm 20 thou = 0.5 mm 30 thou = 0.75 mm 40 thou = 1 mm Clear plastic sheet [ can come from vac moulded packaging] Aluminium foil [aka Tin foil] the thicker type on food trays Plastic section in Square; 1mm to 4mm Rectangle; similar sizes Hollow square tubing; similar sizes Hollow rectangle tubing; similar sizes Round tube; from 0.5mm up, also in brass Round rod; similar L. H, U & C sections in small [1mm x Y ] to medium sizes [6mm x Y] Brass, copper, iron and lead wire in various thicknesses, not all types are needed A couple of packets each of Slaters Micro-rod mixed sizes Plastic strip in mixed sizes Various glues; from regular plastic to UV resin and two-part epoxy Fillers; all sorts, but especially Milliput A couple of small boxes to keep scrap in; don't throw away sprue sections. All plastic is very valuable to the scratch builder/detailer Learn to heat stretch sprue too With this lot you can tackle just about any scratch building detailing A bit of imagination is needed to convert a plastic section to a detail on the model eg: I use deep U section to 'box' in some types of wheel bays, H section can be the floor and sides of a cockpit, Slaters strip glued to the fuselage makes the airframe internal ribbing, copper wire becomes wires or hydraulic pipes Get lots and lots of pictures of what you want to depict. Don't try to copy it all, just a portion. Work slowly. Its a 3D Jigsaw without the instructions hth 4 Link to comment Share on other sites More sharing options...
Gorby Posted December 14, 2017 Share Posted December 14, 2017 Black Knight seems to have covered about 99%! I would say, look at an item you need to copy and either mentally, or in sketch form, break it down into simpler constituent shapes. It's perfectly OK to use household items if they look the part; as BK says, plastic packaging is often useful, but also things like paper-clips and fuse wire work well with the correct glue. I use sprue (either stretched or raw) quite a lot and my spares box, of all the bits of unused parts from previous kits, is a goldmine of useful bits. Just experiment, the beauty with scratch building is that it's cheap, so if the first try doesn't work, try again. Just use your imagination and you will probably surprise yourself what you can do. 1 Link to comment Share on other sites More sharing options...
