bootneck Posted December 9, 2017 Share Posted December 9, 2017 Hello all you phabulous Phantom enthusiasts. I am building up the info I will need to convert a 1:144 scale F-4J Phantom into a F-4K/FG.1 version and would like to know whether the nose contours are the same. I have some info on the enlarged rear and underside for the engines but could do with some differences in contours if that info is out there. At this scale, it is not imperative that every inch of detail is exact and I just need to work out where to add milliput to get the shape correct. Thanks in advance for any helpful advice, and plans/drawings if possible. Mike Link to comment Share on other sites More sharing options...
Jabba Posted December 9, 2017 Share Posted December 9, 2017 As far as I am aware there is no difference between the two as if I am right the FG1 was based on the F-4J. Link to comment Share on other sites More sharing options...
iainpeden Posted December 9, 2017 Share Posted December 9, 2017 I tend to agree with Jabba; although I believe the FG.1 nose was foldable to allow for our smaller carrier lifts. I don't think there would be much difference in 1/144. Link to comment Share on other sites More sharing options...
bootneck Posted December 9, 2017 Author Share Posted December 9, 2017 Thanks both. That allows me to just concentrate on the rear of the fuselage. Mike Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted December 9, 2017 Share Posted December 9, 2017 Don't forget the intakes are 1/3 wider on the FG1, and there is a distinct hump on the intake trunking about 4 feet aft of the intake. Not much in 1/144 perhaps. Link to comment Share on other sites More sharing options...
stever219 Posted December 9, 2017 Share Posted December 9, 2017 Ian and Jabba are correct, there's no discernible difference in the shape of the front fuselage but the engine intakes were widened by about six inches IIRC to allow for he higher mass flow required by the Speys. In 1/144th that'd be about 1/24th of an inch or 40 thou in old money. Link to comment Share on other sites More sharing options...
bootneck Posted December 9, 2017 Author Share Posted December 9, 2017 40 thou is good enough for me, thanks. Do you know how far back the widening went? Was it just the actual opening, and then blend in to the fuselage, or did it go further back? cheers Mike Link to comment Share on other sites More sharing options...
boffin Posted December 10, 2017 Share Posted December 10, 2017 I'm sure you know but just in case..... Whirlybird have announced a FG1 and FGR2 in 1/144 for future release. George Link to comment Share on other sites More sharing options...
bootneck Posted December 10, 2017 Author Share Posted December 10, 2017 Hi George, yes, and thanks, I am aware of that; however, I have approx. 30 phantom kits of various types in 1:144 but not much cash nowadays, therefore converting some of what I have could be fun. Then again, I could mash it all up in the attempt and have to go for Whirlybird's anyway (You know I want to! ). Mike Link to comment Share on other sites More sharing options...
