tarlucan Posted December 6, 2017 Share Posted December 6, 2017 I'm after a Hunter F5 in 1/48. Would the Heritage straight wing conversion be a better bet than the Wolfpack option, any thoughts? Link to comment Share on other sites More sharing options...
Wez Posted December 6, 2017 Share Posted December 6, 2017 (edited) I've not seen either but assuming you're starting with the Academy kit or one of its re-releases by Italeri or Revell then you'll need to do the following to correct the basic kit: Replacement cockpit, the kits is too shallow and the seat is closer to 1/72nd. The mainwheels are too small in diameter. The tailplane bullet is too long and the tailplanes themselves require repositioning. As for the F.5 itself, apart from the straight wings and the small-bore exhaust, the belly has a different arrangement for the intakes which is also common to the other Sapphire engined version the F.2. Does either conversion provide this and correct the other inadequacies of the kit? Edited December 6, 2017 by Wez Speelung!! Link to comment Share on other sites More sharing options...
tarlucan Posted December 6, 2017 Author Share Posted December 6, 2017 There's an SBS set which addresses the cockpit and wheels. The taiplane and bullet seem fixable. The Wolfpack conversion only appears to alter the leading edge and wing tips, whereas the Heritage set provides completely new wings. That may fix the intake issue you mention or is it an auxillary intake for the engine? I understood that the kit tailpipe isn't bad for the earlier engined variants. Link to comment Share on other sites More sharing options...
Wez Posted December 6, 2017 Share Posted December 6, 2017 The intakes I'm talking about are the auxiliary intakes on the belly NOT the engine air intakes in the wing. The kit tailpipe isn't right for the Sapphire/early Avon types. You're right, the tailplane is fixable. Link to comment Share on other sites More sharing options...
tarlucan Posted December 6, 2017 Author Share Posted December 6, 2017 Aeroclub did make some replacement tailpipes but they seem pretty rare. Link to comment Share on other sites More sharing options...
Wez Posted December 6, 2017 Share Posted December 6, 2017 2 hours ago, tarlucan said: Aeroclub did make some replacement tailpipes but they seem pretty rare. The Mk.1-5 tail ones are a distinctive feature, the Aeroclub ones would be worth the effort getting. Link to comment Share on other sites More sharing options...
Selwyn Posted December 6, 2017 Share Posted December 6, 2017 3 hours ago, Wez said: The intakes I'm talking about are the auxiliary intakes on the belly NOT the engine air intakes in the wing. The kit tailpipe isn't right for the Sapphire/early Avon types. You're right, the tailplane is fixable. The Tailpipe was common to all variants. The tail fairing differed on different marks! Selwyn Link to comment Share on other sites More sharing options...
Colin W Posted December 6, 2017 Share Posted December 6, 2017 I did a model of the F3 years ago. The wing mod was made by gluing some sprue inside the outer wing panel in line with the inner leading edge. I then cut off the extension and joined the wing halves. A bit of shaping and sanding needed to the sprue and them a smear of Milliput at the end. Job done. I had to rebuild the exhaust as well but the mk3 was different to the others. The comment about the tail and cockpit above is also true but easily fixed. For more details and pictures look up "hunter Colin' on ARC. Cheers Colin Link to comment Share on other sites More sharing options...
