periklis_sale Posted December 5, 2017 Share Posted December 5, 2017 Hin guys as you might know the trumpeter instructions on how to load out your mig-27m are to say the least nonexistent i want to load out woth twonfuel tanks but not under the wings (under the LERX?) two air air to air under the fuselage and two MER under the fuselage can tou hep me by showing me where to my install the pylons? thanks 1 Link to comment Share on other sites More sharing options...
exdraken Posted December 6, 2017 Share Posted December 6, 2017 Hi, not sure if I understand you correctly, my thought: fuel tank on the center line and/ or moving sections of the wings in forward-swept (un-swept) position only (those tanks cannot move) No tanks on the wing glove section (station 3, 4 on the picture below) air to air missiles: MiG--27 are pricpially attack planes/ fighter bombers. only self defense missile would be carried if at all. likely to be R-60s IR guided missiles. Probably on wing glove pylons (station 3, 4 on the picture below) or outer belly stations (1, 2) MERs can be carried on stations 1,2,3,4 hope this helps! 2 Link to comment Share on other sites More sharing options...
Modelraynz Posted December 12, 2017 Share Posted December 12, 2017 On 05/12/2017 at 20:20, periklis_sale said: Hin guys as you might know the trumpeter instructions on how to load out your mig-27m are to say the least nonexistent i want to load out woth twonfuel tanks but not under the wings (under the LERX?) two air air to air under the fuselage and two MER under the fuselage can tou hep me by showing me where to my install the pylons? thanks Hiya Only the center fuselage pylon was wet out of the 7 hardpoints (with the wing hardpoints only at minimum sweep in ferrying position) I don't think ive ever seen MERs on the lower fuselage pylons either, though quite common on the wing glove pylons, For research, I reckon your best bet is to dive into the russian interwebz: https://yandex.ru/images/pad/search?text=миг-27д&redircnt=1513118155.1 The Best of luck with your build! Link to comment Share on other sites More sharing options...
Modelraynz Posted December 12, 2017 Share Posted December 12, 2017 And wadda ya know: Is a display, but might be an option 1 Link to comment Share on other sites More sharing options...
