JohnWS
1/72 USN 80' Elco PT Boat with some mods
Love all the scratch building John brilliant job :like:
Regards
Richard
Another quick update.
Painting the hull bottom & sides is complete.  I chose Tamiya Acrylic Flat Red for the bottom and Model Master Acrylic Dark Ghost Grey for the hull sides (& superstructure).  These colours are similar to PT 620's paint scheme following WWII.
The exhaust mufflers & butterfly valve operating mechanisms are glued in place.  The exhaust butterfly valve operating mechanisms were made from stretched plastic sprue.  Painting the mufflers was a bit of a challenge.  I read somewhere that the mufflers should be painted before assembling to the hull.  I have to agree.  This meant a little extra work dry fitting the mufflers & laying out the demarcation line between the the grey & red colours.  This turned out to be a lot easier than trying to mask & paint the sides of the mufflers after they were glued in place.
And one more teaser photo showing the deck structures dry fitted on the freshly painted hull.
Now, it's back to scratch building some more details.
Thanks again for looking in.
John
Edited by JohnWS
Coming along! Neat work. Looks like developing into a really fine model!
26 minutes ago, seadog said:
... Neat work. ...
Thanks!
I mentioned earlier that I like the grey colour over camo green since it will show off the smaller details.  I think the Dark Ghost Grey does just that.  Unfortunately it not only shows off the details, but it makes the mistakes show up, as well - excessive glue, overspray, rough masking edges, debris in the paint, etc, etc. The good news is that by taking care to remove the visible mistakes, the resulting paint job doesn't look too bad ... it just takes longer, and a lot of patience, to get there.  The air has been blue in the boatyard more than a few times.  :swear: lol
Nice to see some paint on the old girl, looks neat.
How does one get a straight and level line for your hull red, particularly that bow curve?
Stuart
33 minutes ago, Courageous said:
... How does one get a straight and level line for your hull red, particularly that bow curve? ...
I'm no expert.  I've seen modellers level the hull on a flat surface for reference, so that the tape/paint line is parallel to the flat surface.  Then they draw the tape/paint line with a pencil measuring the location of the line parallel to the flat surface. The masking tape is then applied along the pencil line.
My technique is a little less scientific & involves a lot more trial & error.
1st,  I picked out three location reference points for the line from a drawing.
I cut a thin strip of masking tape a little longer than the hull & stuck one end at the stern reference point.  Holding the tape at the stern so it wouldn't move, I carefully stretched the tape towards the bow, attaching it to the point amidships & then to the bow, as close to a straight line as possible.  Then the fun began.  I stuck the tape along the line starting at the stern, eye-balling the line from the bow :drunk: to see how straight the tape was.  This meant pulling the tape away from the hull & re-sticking it a number or times to get it right.  When I got to the bow curve, it was a lot of trial & error again, eyeballing it from the bow, sticking tape, pulling the tape off, & re-attaching it.  Instead of the straight line i wanted, the tape always wanted to follow the curve of the hull when I stuck it down.
Once I was happy with one side, I tried to duplicate it on the other.  This meant more trial & error, this time checking the straightness of the tape as well a comparing its location to the tape on the finished side.
Hope this helps.
John
That's great John, thanks.
And their was me thinking that you used a laser level!:wink:
Stuart
8 minutes ago, Courageous said:
... And their was me thinking that you used a laser level! ...
That would be too easy. :D
I've been focusing on detailing the PT boat's superstructure.
The Throttle Push Rod Deck Housing is finished.  I've never run across this item on past builds.  I'm guessing the push rods are operated by the throttles on the bridge & are mechanically connected the engine room telegraphs to signal engine speed/direction.  It's interesting that these rods are enclosed in a housing located on the open deck.
I made the Push Rod Deck Housing from plastic strip & scribed fin detail on the upper surface.  Additional detail was added using shapes made from plastic sheet & bar, and brackets were made from wine bottle foil.  Here's a photo of the completed assembly glued to the model's deck, starboard side;
I'm currently detailing the Day Cabin, behind the bridge.  The detail parts completed to date - windows, a vent, a step, fire extinguishing system boxes, & a door - were made using plastic sheet, rod & stretched plastic sprue as needed.
Here's a few photos showing progress to date;
There's a few additional details that need to be added to day cabin & then I'll be moving on to the bridge & chart house.
Thanks for looking in.
John
Beautiful work John, full of detail :yes:. I notice the windows, just wondering if you fit glazing to these or leave as-is?
Stuart
Thanks guys!  Your encouragement means a lot.
I'm planning to use clear plastic for the window panes.  I'll wait until after the day cabin receives its final coat of paint before glueing on the panes.
