Crossiant Oliver Posted November 20, 2017 Share Posted November 20, 2017 I'm building Revell's B-25J and I want to build it in the colors of "Mitch The Witch," because it's the markings of the B-25 that is at the Air Museum I voulenteer at. Is there anywhere I can get these markings? While I'm here, what are the pros and cons of the kit? -Oliver Link to comment Share on other sites More sharing options...
Plasto Posted November 20, 2017 Share Posted November 20, 2017 Mitch the witch was B-25 D not a J. im not sure if you want to build an accurate replica of Mitch The Witch or if you want to replicate the Warbird you are familiar with? The Italeri reissue of the accurate miniatures kit has decals for Mitch the Witch it’s also the core t D model. PYN UP decals also has a sheet with Mitch the Witch on it. The Revell B-25 is a reissue if the old Monogram kit.. here is a review https://modelingmadness.com/scott/allies/previews/revell/5512.htm have fun and enjoy your build Link to comment Share on other sites More sharing options...
Crossiant Oliver Posted November 20, 2017 Author Share Posted November 20, 2017 3 minutes ago, Plasto said: Mitch the witch was B-25 D not a J. im not sure if you want to build an accurate replica of Mitch The Witch or if you want to replicate the Warbird you are familiar with? The Italeri reissue of the accurate miniatures kit has decals for Mitch the Witch it’s also the core t D model. PYN UP decals also has a sheet with Mitch the Witch on it. The Revell B-25 is a reissue if the old Monogram kit.. here is a review https://modelingmadness.com/scott/allies/previews/revell/5512.htm have fun and enjoy your build Alrighty then. The B-25 at my museum is a B-25J, just without a top turret. Link to comment Share on other sites More sharing options...
Plasto Posted November 20, 2017 Share Posted November 20, 2017 Looks nice, Do you want to build a model of this warbird or a model of Mitch the Witch in ww2 service?? https://www.pacificwrecks.com/aircraft/b-25/42-87293.html if it’s a Warbird then you can use the kit you have do a nice job on the build and fit decals to match the Warbird scheme. if you want an accurate ww2 example you’ll need a B-25D kit. or you could build what you like as it’s your build. Have fun Plasto.. Link to comment Share on other sites More sharing options...
