8 hours ago, Cookenbacher said:
I ordered some Orocal 810 and 631. Those are the two I saw mentioned for model masking.
Great choice! :thumbsup:
Ced's right about cutting paper; at work, we ended up ordering a new cutting map right after the first test... :chair:
Ciao
Thanks Giorgio - I'm glad I'm not the only one who has an 'engraved' mat! :)
Cookie my MAC valve arrived yesterday so I'll be trying it out later - thanks to you for your tips :)
The cutter has arrived, and it works beautifully - managed to cut out roundels and numbers for the Hellcats, and managed to engrave a BPF roundel on the cutting matt on the first try! Right of passage I guess, and everything went fine after that. Off for some lunch, then give the new masks a whirl.
And then it was time to try out the masks.
I used wide Tamiya tape as 'transfer' tape.
100_1074
Placed the outer edges of the 'outline'.
100_1077
Painted the Dark blue first. Usually I use Vallejo Steel blue for roundels, but my bottle was a the bottom of a pile of boxes, so I used Mission Models Glossy Sea blue hoping it would contrast with the Lifecolor just a tad.
100_1078
Now masked up for the white.
100_1079
You can see on the left fuselage roundel, that the rear most 'bar' is a little crooked - this will come back to haunt me.
Mission Models acrylic white applied. This stuff does spray almost as well as enamels.
100_1081
Unmasked.
100_1083
You can see that the rear most 'bar' is crooked, but I think it shouldn't be too difficult to fix. There's also a bit of general clean up to do, but still better than decals!
The other side.
100_1084
It's surprising that the lettering turned out so much better than the roundels, but they only needed to be applied once as opposed to the roundels where everything had to be lined up twice.
I can't wait to make more masks - and figure out more techniques for applying them.
Wow nice work Cookie, those are stunning results, especially considering that was your first go at it B)
Stew
Wow, that's really impressive Cookie. The options seem endless once you've got that technique nailed. Who needs decals? I'm watching with interest.
Justin
Great stuff Cookie! :)
Engraved cutting mat - join the club! A right of passage as you say and the mat still works fine eh? I considered buying a replacement but then thought hey, it's only a sticky mat and I'll probably need to get another when the sticky wears off.
Impressive stuff, as usual :)
:yahoo: Great going, Cookie :clap:
Which of the two vinyls have you been using for this? I only have the 810 and found it to be very flexible; if you burnish it properly, it will avoid paint running into panel lines.
Also, I use 3M Magic tape as a trasnfer tape, in thin strips (i.e., I use the strips to go across all the mask bits enough to pick them up all, but not to cover them all - if this makes sense to you)
Ciao
Thanks for the encouraging words everyone!
I need to work on my application technique, the Portrait cutting machine made beautiful masks. The main problem was with the 'bars' on the roundels making the entire mask outline 'unstable' able to twist and stretch - my previous attempts with pre-cut 'regular' round roundels (good band name) were much easier.
On my first test cut, the machine didn't load the cutting mat all the way and it engraved a nice roundel on top! I didn't know how far it was supposed to load, so was unaware of anything being off. It's worked fine every time since. Like you say, the mats are inexpensive and the stickiness is probably the first thing to actually fail. I want to try cutting some vinyl without the mat to see how it goes.
I used 831 on this try because the 810 won't arrive until the end of the week. Thanks very much for the tip on the 3M transfer tape, this is where my technique needs to improve!
Blimey cookie those masks have worked a treat. Lovely stuff.
Rob
