dlh
Another North Cormorant platform
First, thanks to Kallisti for his WIP thread and for advice on this model.  I can work on this build only several hours a day as my neck pain allows, so the build might get slow at times.
So far, I've primed the base of the model.  I've decided, from advice, to paint it black and then overcoat with yellow to get the great weathering effect that Kallisti got.  Pictures of this later.
This model is built of modules, each a small build of its own, so I'm building it that way.  I'm using ModelMaster enamels because I'm a relative beginner and I'm familiar with how they spray.  I'm using Insignia Red and Insignia Yellow because I like the dark colors they produce.  I'm using MM Aluminum to paint the interior floors of the equipment areas; equipment will be brush painted. As Kallisti mentioned, this kit requires quite a bit of cleanup as the part numbers are molded into the parts; some will not be seen, so I'm cleaning up areas that might be seen.  There are also some slight mold lines to smooth.
Here are pics of the module cross members as found and cleaned up.  Also shown are pics of the module frame, assembled first, then painted, not primed.  I experimented with priming and not priming the corrugated parts and could see not difference, probably because both yellow and red are flat colors.  I've included some comparison pics to show the colors before and after painting.  I decided to assemble first and then paint, as I always seem to mess up painted parts when assembling.  (fumbly fingers)
Also, on the fourth and fifth pic, you'll see locators on the frame for the cross members.  I spent quite a bit of time trying to figure out the instructions as to which side of that should be used.  So my pattern is to place the cross member to the "outside" of each locator.  That way they sit flush and don't encounter the small tab above that is used to mount each equipment level.  I used the square when attaching the cross members to the frame.  I glued each cross member to the frame with super glue and then set with accelerator.
I then attached the opposite frame to all four cross members at once.  This approach eliminates and clamping and waiting for the glue to dry.
One side of each corrugated panel is a cutaway revealing the interior detail.  Once assembled, these can barely be seen.  I considered reversing each module with the cutaway to the outside but decided against that.  Maybe I'll do that on a second build of this monster.:nah:
2v2uWn955xBoFJC.jpg2v2uWn9NNxBoFJC.jpg2v2uWn9jGxBoFJC.jpg2v2uWn98nxBoFJC.jpg2v2uWn9zFxBoFJC.jpg2v2uWnuodxBoFJC.jpg2v2uWnu2yxBoFJC.jpg2v2uWnu35xBoFJC.jpg
Edited by dlh
additional info
Good start, great to see another one of these monsters being built :)
31 minutes ago, KEVIN_ARIS said:
can you show us some details please like scale, kit details please,
Hi Kevin,
I have one of these. Pop over sometime and you can have a shufti in the box.
Mike
18 minutes ago, bootneck said:
Hi Kevin,
Mike
Have not forgotton my invite Mike, by the way did you go Telford
Oh one bit of advice - don't spend too much effort painting the internal details of the modules, they are hidden once assembled! I wasted a HUGE amount of time on that...
It looks good!
What kit?
What scale?
How big is the finished model?
Steve
A couple of questions if i may ? One is this a kit or is it scratchbuilt from plans ? Two what scale is it in case someone wanted to build one with a helicopter and/or a supply boat ?
Sure, sorry about that.
https://www.revell.com/germany/other/80-8803.html#.WgoMMbpFw08
Oilrig North Comorant Plastic Model Kit
Product ID: 80-8803
Overview
Skill level: 5
Scale: 1:200
Length: 685 mm
Parts: 615
Description
Primed to pump petroleum
The North Cormorant off-shore oil rig can be found 100 miles (160 km) northeast of the Shetland Islands. Twenty-eight steel nails are used to anchor the rig to the seabed. Forty pipes transport up to 24,000 tons of oil and gas to temporary stores and the mainland every day. This limited edition kit features a waterline with detailed substructure, modular platform structures, a detailed drilling rig, supply cranes with movable loading arms, multiple containers, lifeboats, a heli platform, detailed staircases, forty pipes, railing and decals.
Thankyou for the information
5 hours ago, Bandsaw Steve said:
That’s kind of cool! 😎
Yes, in a weird way.  I've built only cars up this point, and got tired of fretting over every perfect finish.  And at least I can see all of these parts without magnifiers.B)
This is a big kit and the large box contains a LOT of plastic! I built mine last year and put it on my club's table at Scale Model World and so many people said "Oh I've got that in the stash and I've never built it" and even one of the guys from Revell said they'd never seen one built :)
My build from last year is over here - I did get rather silly with it :)
