Mike Mcellaney
Italeri 1/32 F-104G Hellenic Air Force Completed
This is my entry for this group build, the Italeri 1/32 F-104G
I have had this kit for a few months now and have been adding bits to it for the build
The model will be finished as one from the Hellenic Air Force using Bombshell Brew Paint
IMG_0467
IMG_0493
IMG_0489
IMG_0492
IMG_0469
IMG_0471
IMG_0473
IMG_0488
Nice choice Mike.
That kit decal sheet is huge! There really are almost to many options for the 104.
Watching with interest.
James
23 hours ago, modelling minion said:
Very, very nice choice.
Greek Starfighters came in a variety of schemes and with varying degrees of weathering, any idea which you will be going for?
Not sure yet but will be either 715 using the kit decals for the serial numbers and everything else from the Icarus decal sheet or 734 using the Icarus decals
Nice choice! 👍
And a very decent lineup of aftermarket parts! 😀
I am looking forward the build.
Holger
Well after a week its time for an update, I have been working on the cockpit, the main landing bay and the engine
As the only thing you will see of the engine is the rear end all I have painted is what will be seen
IMG_0574
IMG_0575
IMG_0576
IMG_0577
IMG_0580
IMG_0584
IMG_0588
IMG_0589
IMG_0591
IMG_0593
IMG_0596
IMG_0598IMG_0601
IMG_0606
IMG_0608
IMG_0610
Man, that looks pretty darn nice!  The seat and "noisy bits" are especially impressive.
Great work indeed!
Large scale have some advantage when painting.... :)
Agree with the others the seat is particularly good, great start.
Lovely work Mike.
What nmf paint did you use on the main wheel bay?
James
7 hours ago, franky boy said:
Lovely work Mike.
Hi James , that was AK Extreme Metal Aluminium over a Mr Finishing Surfacer1500 Black Primer
I've just tried them for the first time on my build. I have to say I was impressed with the results. I just went onto the bare plastic but you've got much more depth to your finish with the black base. I'll do that next time.
Look forward to seeing more progress.
James
Well I have had a bit of a set back on this one, when fitting the cockpit I went a bit too far with the Dremel and went right through the side of the fuselage
This was Saturday morning, so I went on line, ordered another kit and received it an hour ago curtsey of DPD
This time no resin cockpit but can still use the seat, so lets start again
Ouch, I'm still in the middle of shoehorning the Aires pit in.  I have seen it done, but its getting to be a bit thin in areas on the resin and the plastic (its sitting in the box again for a couple of months whilst I ponder it!).
On ‎25‎/‎11‎/‎2017 at 9:29 AM, Greg B said:
Ouch, I'm still in the middle of shoehorning the Aires pit in.  I have seen it done, but its getting to be a bit thin in areas on the resin and the plastic (its sitting in the box again for a couple of months hi whilst I ponder it!).
Hi Greg, and I thought it was just me going a bit OTT with the Dremel
I agree it is very tight fit and I had the same problem the pit sides and bottom you could see light through them and the fuselage sides were not that much better as I found out
Well going to call this update ROUND 2 of the build
The cockpit tub and instrument panel is the kit with just some added knobs from plastic card on the right hand side
Airscale decals used for the instruments
The seat was salvaged from the Aries pit with RBF tag added plus some additional bits from the Eduard photo etch set for the seat belts
The seat framework is from the Eduard seat
The electronics bay behind the seat is from the kit with again Airscale placards added, still got to add wiring to this area
Cockpit and bay fitted, fuselage joined, joints sanded, primer to check the joints and second fill
This has now been sanded, primed and checked, some areas will still need more filling, this will be done with BONDO GLAZING & SPOT PUTTY
IMG_0641
IMG_0646
IMG_0663
IMG_0669
IMG_0621
IMG_0628
IMG_0695
IMG_0699
IMG_0700
IMG_0703
IMG_0705
IMG_0717
IMG_0719
IMG_0728
Very impressive progress, Mike. Your painting of the cockpit and avionics bay are a joy to behold.
Excellent! The Greek machines were some of the most attractive - in my view ;)
Martin
