Rick Brown Posted October 30, 2017 Share Posted October 30, 2017 Chaps. Ref the 03986 kit from a couple of years ago. I remember seeing a few posts discussing this subject, but my question is, would it be cheaper to make this as a MKIIa or a MKVa? I appreciate it'll need resin correction parts (and decals if I go down the Va route) to make a better version of either, but which should I go for? Telford coming up and I need to order the bits..... Rick. Link to comment Share on other sites More sharing options...
VMA131Marine Posted October 30, 2017 Share Posted October 30, 2017 As is, the kit is probably closer to a Mk.Va. It has the metal ailerons and the round oil cooler inlet. Barracudacals does a resin correction set that includes the radiator and its intake ramp; the Revell radiator mounts to flat wing underside. You'll probably want to replace the wheels as well, as the kit supplied ones look odd. Again, Barracudacals has 5-spoke wheels you can use. Most of the issues with the 1/32 kit carried over to their more recent 1/72 scale Spitfire Mk.II. 1 Link to comment Share on other sites More sharing options...
Rick Brown Posted October 30, 2017 Author Share Posted October 30, 2017 Cheers Chap. So... What you're saying is, just buy decals (or more likely masks) and wheels to make it pretty close to a MKVa? Oh, the spinner/prop will need changing too. That lot sounds cheaper than trying to make it a MKIIa. Rick. Link to comment Share on other sites More sharing options...
elger Posted October 31, 2017 Share Posted October 31, 2017 You might want to check the front windscreen which is certainly appropriate for a I or II but maybe not for a V 1 Link to comment Share on other sites More sharing options...
Smithy Posted October 31, 2017 Share Posted October 31, 2017 (edited) 26 minutes ago, elger said: You might want to check the front windscreen which is certainly appropriate for a I or II but maybe not for a V I don't have the kit but I had a quick squizz at the instructions on the Revell website. I don't think the windscreen would be an issue for a Va as the Revell kit has the armoured windscreen externally which it was on most if not all Vas. One thing though which isn't clear from the instructions but does the canopy include the "pop out" section? It most probably should for a Va but you would have to check references and photos for the specific aircraft. Tim Edited October 31, 2017 by Smithy Added some more info 1 1 Link to comment Share on other sites More sharing options...
Rick Brown Posted November 1, 2017 Author Share Posted November 1, 2017 I better have a check of the canopy then. Looking at Hannants, the prop/spinner is pretty darn expensive! I'll go with the kit option for the time being and change it when funds allow, should be easy enough to pop the old one off after the build. Thanks for all your help guys. Rick. Link to comment Share on other sites More sharing options...
Work In Progress Posted November 1, 2017 Share Posted November 1, 2017 Coming back to the original question, the *cheapest* thing to do with this kit, requring the least aftermarket (providing you can live with the basic too-tubby fuselage cross-section, and frankly most people don't care about that) is to build it as the RAF's surviving IIa, P7350, in BBMF usage in a period fitted with the V components. Use one of the three Kits World decal sheets available for various incarnations of this very aeroplane (Hannants have them) and check photo refs. Then you won't even need to get rid of the crowbar. 1 Link to comment Share on other sites More sharing options...
