Soeren Posted April 2, 2018 Author Share Posted April 2, 2018 (edited) And now my take on the hull camo. The detail bits need to be matching the camo now. Edited April 2, 2018 by Soeren 2 Link to comment Share on other sites More sharing options...
BlackMax12 Posted April 2, 2018 Share Posted April 2, 2018 Looks lots better with the green , I wasn't too sold on just the brown and yellow but looks great now. Lloyd 1 Link to comment Share on other sites More sharing options...
Soeren Posted April 2, 2018 Author Share Posted April 2, 2018 Thank you Lloyd. I feel the same. The green makes it look much more natural. Now I have to figure out how how I want to weather the lower hull before adding wheels and tracks. A few.pictures show it in sandy terrain and the picture from the start more in muddy environment. I tend more towards dry encrusted dirt. Link to comment Share on other sites More sharing options...
Soeren Posted April 3, 2018 Author Share Posted April 3, 2018 Tiger tested with green stripes. Paint is less stark to leave room for filter and color modulation. 2 Link to comment Share on other sites More sharing options...
Ripaman Posted April 5, 2018 Share Posted April 5, 2018 What pressure are you working with on your spray gun, looking good Regards Richard Link to comment Share on other sites More sharing options...
Soeren Posted April 5, 2018 Author Share Posted April 5, 2018 I was working with a H&S Ultra with 0,2 mm nozzle at about 18-20 psi with thinned down Vallejo Model Air paint. The coverage is very thin and so it takes several passes to build up the opacity. Link to comment Share on other sites More sharing options...
Soeren Posted April 23, 2018 Author Share Posted April 23, 2018 Revisiting the Tiger builds to weather the lower hull. Various ammo of mig earth effects with plaster and pigments. Before that I had ak texturizer with dirt and plaster and pigments. This is now after three sessions of sprinkles. 2 Link to comment Share on other sites More sharing options...
Mike Posted April 23, 2018 Share Posted April 23, 2018 Looks good Shame the old pics have gone though Link to comment Share on other sites More sharing options...
Soeren Posted April 23, 2018 Author Share Posted April 23, 2018 I might try to upload to another host. But atm I can only access via mobile or proxy. Makes it a bit less convenient :(. Link to comment Share on other sites More sharing options...
Soeren Posted April 29, 2018 Author Share Posted April 29, 2018 (edited) One week later an update. I messed around with pigments again. The hull got an oil paint and pigment treatment to make the tidemarks look better and than a soft rubdown with a stiff brush before varnish application. I was using this varnisch which is reasonably cheap and seems to work well on the large scale models. https://www.architekturbedarf.de/farben ... 1010-matte Then I went along with track (enamel, plaster mix for the texture and Vallejo acrylic dust wash and finally some lighter pigments to the topmost areas before varnish) Followed by the wheels on one side. Started with a texturizer mix, that of course turned out too dark, then applied two layers of different pigment mixtures fixed with Abtl. 502 fixer. I guess there is a need for some overall dust application now to blend the different tones together and have the less textured areas not look too clean before sealing with matt varnish Edited April 29, 2018 by Soeren 1 Link to comment Share on other sites More sharing options...
Soeren Posted April 29, 2018 Author Share Posted April 29, 2018 (edited) I am happy with the result so far. Gave the wheels a final rubdown of pigments and fixer and didnt end with a varnish coat, because I would like to have the unpowdered paint on the wheels retain its satin sheen. Then I gave the track a drybrush of ModelAir Black metal and a pigment rub of dark steel on the outside and where the wheels contact on the inside. The dirt paint gave some cast appearance where te mteal paint is on now. We´ll see how long it will last. Quickly mounted and one side is finished for now. As expected, not much of the side panel weathering visible anymore. Lots of work for nothing 😵 Will see if there is need for touchups in the end. Maybe some shadows around the details, here and there. But this is for the feature. Thanks for looking. Edited April 29, 2018 by Soeren 2 Link to comment Share on other sites More sharing options...
Soeren Posted May 5, 2018 Author Share Posted May 5, 2018 Todays update. Finally put the other side running gear together. Note to myself, weather both tracks at the same time to match the colors better. But even one track is so time consuming for the after work hobby hour. Added the electronics and had a test run and finally uploaded the first video to my channel. https://www.youtube.com/watch?v=JxSB2ke-62M Link to comment Share on other sites More sharing options...
mick Posted May 5, 2018 Share Posted May 5, 2018 great work Link to comment Share on other sites More sharing options...
Soeren Posted May 5, 2018 Author Share Posted May 5, 2018 Thank you Mick and here is the test fit of upper and turret. Link to comment Share on other sites More sharing options...
Soeren Posted July 20, 2018 Author Share Posted July 20, 2018 Wow. only 2 and a half months later. Mounted the gun and servos and got a friend to print a support ring. The gun is so heavy, the cheap servo really struggles. I now ordered a Savöx SH-253. See how that works. Sanding down the paint on the barrel to make the recoil smooth really added some nice effect with the red primer underneath. Link to comment Share on other sites More sharing options...
Soeren Posted July 11, 2020 Author Share Posted July 11, 2020 I was thinking about this tank for a while now. Still didnt really figure out how to put the top hull on the bottom. So I figured I would need a well engineered reference teachingme on how to do it. To help this stand out I ordered an Aber kit that included some interesting bits, Track hangers cast in brass, I didn´t know that beforehand. The track cable and barrel cleaing rods are included, but not the same quality as the individual sets. 1 Link to comment Share on other sites More sharing options...
Soeren Posted August 21, 2020 Author Share Posted August 21, 2020 Hey, hey, KV-1 done, Panther almost. So started on a new serious project. Got all the PE goodies for the Tamiya Kit and an alluminium barrel with muzzle brake from Schumo kits. That should keep me busy over the next years. The Dragon kit is meant for two reasons. 1st wanted to do it as a Kharkov Tiger. So needed some kit to try the painting. 2nd never build a Dragon Tiger before and need some reference for possibly missing details on the Tamiya kit when Aber doesn’t give us the answer. Nice. Dragon gives us some interior for the turret. So open hatches allow at least for some detail to be visible even though there should be figures filling up most of the space. 1 Link to comment Share on other sites More sharing options...
Soeren Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) Got the order of Montana Spray Cans today. Actually the "Everglade" color is the greenish brown. Is it coffee with milk or baby poo? Well, it is slightly darker an less ochreish than the Vallejo modelcolor RAL 8000. Good primer color if you ask me. So it was time to spray the wheels and prime the hull. Almost one can down. The roadwheels were "evergladed" and the outer wheels got a highlight of VMC RAL 8000, the sprockets were painted RAL 8000 without priming. The Colors are slightly different, but go together very well. Same treatment to the 1/16th scale wheels. The color appears lighter on this pictures than what I see with the naked eye though I feel that a dark brown wash and then some serious highlighting of the outer wheels should be a good start. Will do this together with the hull which I just started working on. Edited August 22, 2020 by Soeren Link to comment Share on other sites More sharing options...
Soeren Posted August 23, 2020 Author Share Posted August 23, 2020 (edited) There are some details missing on the Tamiya hull. Weldline between the front panel. Had to glue one some plastic card sheets to create the channel. Other weldlines in styrene rod manner and the nuts and bolts added. Ah well and the odd torch cut marks of course. Edited August 23, 2020 by Soeren 1 Link to comment Share on other sites More sharing options...
Jasper dog Posted August 23, 2020 Share Posted August 23, 2020 Oh my! Tamiya 1/16 Tiger! if I won the lottery that would be up there with the must haves. I remember it coming out and Tamiya magazine, amongst others, did a review/build of the full works version with sound chip and everything, smitten ever since. Dare I ask, does it still come with sound effects? I'll try and keep up to date with this one. Good luck Darryl Link to comment Share on other sites More sharing options...
Soeren Posted August 24, 2020 Author Share Posted August 24, 2020 11 hours ago, Jasper dog said: Oh my! Tamiya 1/16 Tiger! if I won the lottery that would be up there with the must haves. I remember it coming out and Tamiya magazine, amongst others, did a review/build of the full works version with sound chip and everything, smitten ever since. Dare I ask, does it still come with sound effects? I'll try and keep up to date with this one. Good luck Darryl It is the so called "Full Option" Kit. Yes, it has a complete electronics unit with sounds, etc. It will be able to run, turn the turret, elevate the gun and can recoil with flash when shooting. I couldnt afford those kits when I was young. Well and I wouldnt have done a good job painting them anyways. So now a boys dreams finally come true. 1 Link to comment Share on other sites More sharing options...
Jasper dog Posted August 25, 2020 Share Posted August 25, 2020 I think at the time it was the sound effects that sold it to me, could be wrong, but I'm sure they used a recording of the real thing from initial start up to running. On 24/08/2020 at 09:52, Soeren said: I couldnt afford those kits when I was young. Well and I wouldnt have done a good job painting them anyways. So now a boys dreams finally come true. Like wise, however I still doubt I'd dare do something in that price range or have the skill to do it justice. Good luck, not that you'll need it, sure you'll nail it. Darryl Link to comment Share on other sites More sharing options...
Soeren Posted August 27, 2020 Author Share Posted August 27, 2020 Thank you. Luck an endurance is what I need here as the detailing will take some time. Some wheels are on this one now. Lots of wheels actually. Good that there are rubber rims included. And only on the dragon tank I will have to paint the rims on 48 road wheels. And I thought Panthers have lots of wheels. 2 Link to comment Share on other sites More sharing options...
Jasper dog Posted August 27, 2020 Share Posted August 27, 2020 What fun, 48 road wheels, and an absolute pain if as a crew member you have to change one! 1 Link to comment Share on other sites More sharing options...
Soeren Posted August 27, 2020 Author Share Posted August 27, 2020 (edited) 35 minutes ago, Jasper dog said: What fun, 48 road wheels, and an absolute pain if as a crew member you have to change one! Yeah, and of course it is the the inner most in the center all the time. What did they need to do, demount 8+ wheels to get there? Hmmm, where to start? Btw, went along on the Dragon kit. The detail is great, but I also found a few issues in the early build already. The jack mounts dont work in the way as shown in the instructions and according to the holes in the rear wall, or it is just me. The second is the ventilators inside, you cant mount the PE cover without cutting down parts of it, when you bend the PE according to the prescribed lines as it would be too wide. Secondly, the covers over the tanks need to be mounted together with the radiotaors, the way the incstuctions show it, it wont work. Well, you dont see anything of that anyway when you keep the grating closed. Still, nice option, when you know how to approach it, this is for the other Tiger kits. Also painted and weathered the turret inside, again, ther wont be much if any seen. So stayed really basic, it is just there. Next I started on the PE, as it was the recent step in the Tamiya build. Front fenders this is. Cut the kit parts down, one PE fender complete, the second needs the brackets still. And received the latest ABER product for the early Tiger. Well. if this wasnt enough already. One Fret of PE down, how many were this again? This one will last until it is finished ;= Size comparison Edited August 27, 2020 by Soeren 1 Link to comment Share on other sites More sharing options...
