clive_t
Airfix 1:32 QF 17-pounder Anti Tank Gun
2 minutes ago, Flyingdutchman said:
Very nice! As a Dutchie myself I appreciate that you’re making this diorama.
Evert
Thanks Evert, very kind of you :)
More progress today - the base received what I suppose you'd call a 'pin wash' - albeit in a larger scale! I felt the gaps between the stone setts was a bit too prominent, so I brushed in some thinned black oil paint, and then wiped most of it off. I then stuck the big rubble pile on where it needs to be:
I then set to work hiding the gaps between rubble and base, where they were most noticeable:
Then just to smooth out the pile adjacent to the ground I applied my old favourite, some "ground-up chinchillas" :D (OK, chinchilla dust for the uninitiated!) over some PVA:
A bit more work on the smaller rubble pile - just a couple of dark washes and some dry-brushing in a pale stone tone:
Finally for today, I made some pockets for the Denison smock, from a small amount of 'Grey stuff':
Hopefully some more progress tomorrow :)
Thanks for watching! :thumbsup2:
Wonderful work Clive :worthy:
I built this one about six years ago in remembrance of my grandfather who was with the 58th (Duke of Wellington’s) Anti-Tank Regiment RA (TA). They operated 57mm (6pdr) and 17pdr guns. The regiment operated with 46 (North Midland) Infantry Division; during September 1943 they were assigned to X Core, assisting the 5th US Army in their invasion of Salerno. In October of that year it entered the Italian campaign, operating with V Corps again, only this time under Eighth Army.
He was demobbed with a perforated ear drum. My dad now has the model.
Looking forward to seeing yours finished :D
Thanks Mr Ratch, for your most kind comments. Thanks also for sharing the pics of your own, a wonderful diorama :thumbsup2:
Just catching up Clive, looking very nice.
Looks like you've had the builders in:D. Coming along nicely Clive. I must get some of the chinchilla dust when I'm back in the old country next week.
John.
Thanks Ozzy :thumbsup2:
John.
Looking not too dissimilar to the aftermath of one of my first attempts at major DIY back in my first days as a home-owner :D
Not much progress to report, sadly - Saturday was a bust for me, no modelling at all. This evening, just a bit of time for some priming of the two Airfix figures:
The more I think about it, the more I am convinced that this fellow will be casually smoking a cigarette. Not that I condone such activity, you understand!
It's only once sprayed this guy that I notice the lower pockets on the Denison smock are a little on the small side. I am hoping that once painted, that will be less apparent :(
Thanks for watching :thumbsup2:
More progress this evening. The other side of the big rubble pile was bedded in with bits and pieces of loose rubble, and yet more crushed chinchillas:
The walkway was then glued on to the base, with the wall just placed there as a guide. That won't be fixed in until last:
Obviously the undulations in the base plate meant that some gentle persuasion was needed in order to keep it from springing up! Looked a bit better with the weight removed, though:
Then finally for this evening, I fixed the smaller rubble pile to the base and the walkway, and filled the gaps with yet more Milliput, and a sprinkling of loose brick-slips provided as part of the ruined wall kit:
All of which frenetic activity left it looking like this:
Thanks for watching, as always :)
Another day, another step closer to completion... The second brick barrier was fixed in the required position. I also bedded everything a little:
The stuff I used to do the bedding in came about as the beneficial result of a complete accident... Many instances of happy accidents throughout history, of course: Alexander Fleming accidentally left the window of his laboratory open one night, and discovered penicillin; Abraham Lincoln flew a kite whilst a thunderstorm raged all around him, and discovered... that flying kites in a thunderstorm was not good for the constitution :hypnotised:
For myself, this morning I accidentally discovered that the many months of accumulated dried paint currently clogging the filter at the back of my spray booth is in fact a most excellent earth-coloured dust:
Now earlier this week, I had another of my many rushes of blood to the head, wherein I thought that I would try and adorn part of the scene with a badly damaged swastika flag. They appear to be quite difficult to come by through the shops, so I thought I would try and make one myself. I made use of some 'Galeria' Heavy Carvable Modelling Paste - very like PVA in appearance, but retains its white colour once dry, and is very flexible. I spread some onto a polythene bag, and left it for a day to dry. Having then carefully peeled it from the bag, it looked like this:
As you can see it suffered some damage in the process, but given that I wanted a ripped and generally trashed flag, I didn't regard this as a big problem.
This morning I made a mask to retain the white colour for the circle in the middle, from some wide Tamiya masking tape:
I then sprayed the thing with Games Workshop 'Blood Red' - seemed appropriate, somehow - and removed the mask. This proved something of a challenge, as I had reckoned without the effects of the sticky surface of the tape on the flimsy sheet. Even more damage ensued:
I then hand-painted a swastika on the remains of the white circle - with a somewhat shaky hand, it must be said:
With some matt varnish brushed on to tone down the sheen of the paint, I then did a dry run with the flag draped over the rubble pile:
Finally, I placed some pieces of wood - some of which was again supplied with the ruined building wall kit - around the place:
I'm still in two minds about the flag at the moment - however it's not fixed so is easily removed. It might help to make my mind up if I give it a bit of an air-brushing and some of my patent 'dust' :)
Thanks for looking in :thumbsup2:
Excellent work on the flag Clive....very creative....that's on my trial list......
Everything else, top notch progress.....:yes:
Simon.
Hi Clive, thought this was interesting.....I saw someone mention a this on forum, might be on here - somewhere anyway, for making flags.....I might try it out one day.
http://www.homecrafts.co.uk/inkjet-cotton-lawn-washable-a4-pack-of-5?gclid=CjwKCAiAn5rUBRA3EiwAUCWb21pzF0HJto6btiDQG1QPKP8azhpI_vEgIXJMzjISIZLxzuv2Fh-dzBoC0coQAvD_BwE
Looks interesting, I guess if you had a bunch of designs, enough to fill an A4 sheet, that could be a goer!
Thanksfor the link, I might just follow that up. If nothing else I've just earned some brownie points for pointing the wife at a craft website she didn't know about :D
