Mike Posted October 20, 2017 Share Posted October 20, 2017 Sukhoi Su-34 Fullback BigEd set (BIG49175 for Hobby Boss) 1:48 Eduard Hobby Boss's Fullback has been a huge success, despite it having a few flaws, and Eduard has released a number of Photo-Etch sets to improve on the detail, all of which have been available separately now for a few months. If you haven't yet dipped your toe into acquiring aftermarket for your kit and were planning on getting all sets however, then this BigEd set will be of interest. It includes four sets and places them in one card envelope, passing on a discount on the price for the modeller as a result. On first look the ticket price might look large, but when you add the individual prices together, you do win out and save around 25%. The envelope is sturdy and well able to keep your Photo-Etch (PE) safe from harm, with a taped up flap which is re-sealable using a punched-out tongue and slot. Interior (49824) Two small frets are included, one nickel plated and pre-painted, the other in bare brass. A complete set of new layered instrument panels and side consoles are the primary parts on the painted set, with new rudder pedals; ejection seat details; throttle quadrant; HUD framework with acetate film glazing; rear-view periscope and canopy internal structure also supplied. Oddly, a number of external parts are added, such as a number of sensors and AoA probe in the nose; static wicks on the wings and tail, and chaff and flare racks in the stinger between the engine exhausts. Seatbelts STEEL (49825) In case you don't already know, these belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting. Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE. As well as the belts and cushion pads, you also get a set of pull-handles between the pilot's knees that gets him out of there in case of an emergency. Exterior (48921) This larger bare brass set contains some important upgrades, such as delicate new afterburner rings, with concise instructions on how to achieve the correct shape with them; a replacement to the rear face of the engine that slots over the bullet fairing in the centre; a substantial upgrade to the detail in the highly visible nose gear bay that also acts as crew access, with the ladder also getting new treads and the mudguard being fitted with a new flexible rubber section (in brass of course). Finally, the intake inner walls are skinned with more detailed panels, which will need blending in with the styrene at the edges for a more realistic look. Masks (EX550) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, which are solid masks for each pane. In addition you get a set of ancillary masks for the sundry lights, allowing you to paint your model with little concern for them. Review sample courtesy of Link to comment Share on other sites More sharing options...
