Kawasaki Ki-48-1 `Lily`, Burma, 1942
Hi everyone,
 Just found time, so I hope you don`t mind seeing some shots of my latest effort
My attempt at AZ`s 1/48 `Lily`
Finished to represent an aircraft of: 8th Sentai, 3rd Chutai, Burma, 1942
Built mostly from the box contents except for the nose gun barrel which I lost somewhere along the road
Added ignition harness from wire, aerials, seat belts and.................
pitot tube.
Wasn`t too bad a build, a big improvement over their Vengeance which was the last one of theirs I tried.
Hope you enjoy,thanks for looking
Cheers Russ
  • Like 48
4 hours ago, JWM said:
Nice both! Is Lily an old Maniya kit?
J-W
Hi J-W, I don`t think so, as far as I`m aware it`s their own
27 minutes ago, Zigomar said:
Nice job on her Russ but what a pity they missed the nose!
Hi Jean, it`s actually the one with the improved nose glazing, it looks a bit better but not 100% still
3 hours ago, Head in the clouds. said:
Superb Russ....you are arf knocking em out, how do you do it?
Easy, I don`t watch TV, continental shifts helps too :smile:
I normally have two or three on the go at the same time, in different stages of assy` for when I paint my self into a corner, which happens quite a bit.
Glad you like it.
Great job Russ on both! I really like your weathering, restrained but there, and your choice of subjects.
I heard the Vengeance was a bear in general but is there anything you can pass along in particular.
Thanks!
All the Best!
Dom
Thanks!
All the Best!
Dom
Cheers Dom, the main problem I had was the fuselage halves didn`t match up either lengthwise or heightwise, the canopy sat very high ( I sanded about 2mm off mine ) and the exhausts were a nightmare ( the kit ones are rattling around inside the fuselage ).
Apart from that, the usual limited run kit fit and instructions apply.
- Hi Russ,
- I didn't knew AZ had issued a kit  version with a modified nose glazing, I have the first one in my stash but I think I won't built it owing to this nose unless I should find an A.M vacu correct set but I'm not sure there is one available. Your Lily is a testimony of your skill  in building and painting
3 hours ago, Ian said:
One of your best Russ. Love that hint of overlap on the camo - not sure if was accident or design but it looks fantastic.
Ian.
Cheers Ian, the camo` has a thin blue line at the demarcation of the brown and green
Indeed, but somhow it is not seen if you look first time. You see that borders are a bit stronger but colour change is not obvious. Perheps this is a question of light at the photos...
 I think that idea of this camo is rice fields, with water reflecting blue sky on the borders of field. I did my Ki-15 with this kind of camo and I've seen also Ki-21 with such blue demarcations.
J-W
J-W
That's correct and it mentioned in the old Thorpe book on the JAAF camos. A very nice interpretation indeed.
Really? - because it was only my speculation...
J-W
Edited by JWM
