Gimme Shelter
Jawa Sand Crawler (resin 1/96 Randy Cooper kit)
With too much decent new telly to watch so far this year, my workshop and Sandcrawler both got neglected until mid January when I finally got the inspiration to chance the wind and rain between my back door and workshop - finally my mojo hath returned and I have ventured all 20 feet out to my workshop and the warmth of my oil filled radiator in it.
With a base prime of grey down, I have now added a black and light brown prime for some base colours which have had chipping and masking mediums spotted on to them prior to the overall dark brown airbrushed top coat.
There is a simple reason I never go near military modelling - I can't weather models. However, this kit demands it so the process and stages I am undergoing are a very big new adventure for me. I have a MIG technique's guide book which should help too.
Masking the control deck from the inside took 2 hours - it was very fiddly and this picture highlights how much tidying up is needed around the upright window pillars
DSCF7493
DSCF7495
DSCF7499
primed bogie track cover plates
DSCF7500
DSCF7501
VALLEJO Model Colour Light sky Grey brushed on as a base colour for the metallic scratched and flaky areas - I assume this is the right way to work (lowest colour on first)
DSCF7503
DSCF7504
HUMBROL Masking Fluid being dabbled on hereon the black, light sky grey and light brown areas
DSCF7505
DSCF7506
DSCF7507
next stages: airbrushing the first base coat of the overall dark brown prior to adding the washes and pixels
Are glad this is up and running again, I can not get over how massive it looks on the bench top.
As for the weathering it all sounds like your on the right path, only thing I might add is that the masking fluid might be a bit blobby, i mean it wont have any sharp angles to it and in this scale I might expect to see rust or paint flakes all jagged and sharp, just my thoughts so no need to pay any attention to them.
cheers there Rockpop - thinking about it, you are right. I have some mediums that can be used for raised surface texturing which I think I shall add at a later time and blend in with whichever colour be needed. Luckily, I have a yellow / ochre shade that perfectly matches the Halfords light brown primer, so I wont end up with colour blend indifferences if I need to add the lower colours to an upper surface texture. I have done some investigations into using Vallejo chipping mediums later on in the process; this looks like break up paint and leave a nice gnarled and snagged paint effect - testing and time will tell
bye for now - John
Thank goodness I had 3 bottles of Alcad II RAF Dark Brown on the shelf - all 3 bottles were used up in 2 overall coats on top of the Halfords base brown primer
DSCF7510
DSCF7511
first of the upper shades being added - Alcad II Raf Dark Brown
DSCF7512
DSCF7513
just waiting for the postman to deliver fresh stock of some more Alcad II shades, cleaner and some weathering agents
lots of paint going it to this, I hope your using a good sized air brush or this must be taking you ages. Is there going to be any red added to paint scheme?
That was certainly something I had to consider first once the rattle primer tins were finished with. I had 4 Iwata HP-CS on the job as I needed to work fast and Alcad II tends to need a complete flush out after the reservoir gets refilled more than 4 times on a row - so I got all 4 ready and set up and simply went from one to the next and then to next and so on until the job got completed using 3 bottles and about 16 reservoirs refills across all 4 Iwata's.
I am working from Lorne's Sculpting a Galaxy book which has an A3 sized colour profile photo of the crawler - hoping to best re-create that - lets see - as I have said, I have not dabbled with this type of paint and weathering before...
thanks for following
How much paint???? Bloody hell!! Great work, Sir!
I love the work I'm seeing on here as I've always had a passion for sci-fi, but haven't built anything in that genre since the first x-wing and tie-fighters in the 70's by whoever(I can't remember who it was), when I was but a wee kid! Anyone who might know me from my car modelling will know that I HATE plastic and would replace every kit part with scratch-made from metal, so kits are out of the question. While I love building historic race-cars, where everything has to be so perfect and precise, this is the perfect place to use-up all my tubs of "greeblies" ( yes, car modellers have  them, too and try and create something of interest. I don't think the project will be a known subject, it will definitely be something that "grows" from my childhood fantasies and twisted mind, so, who knows?:wicked::mental: It will be all-metal, too!!
I have a couple of on-going projects, so it may be a while til I start anything, but, I'm watching and learning, so be assured, when I do, you guys will be the first to know! Any thoughts, input, advice and help would be most appreciated.
Cheers, H
another small update from the Tatooine outer rim desert
so here is a photo of the original ILM model that was smartened up for the special edition revised release of A New Hope, courtesy or Lorne Peterson's book ' Sculpting A Galaxy' - mine is still a good journey's worth of work away from this but it gives you an idea of where I am headed.....
DSCF7522
starting adding some of the grime layers below
DSCF7514
DSCF7514
masking out some of the darker panel blocks
DSCF7516
lighter shades start being added to the bogie plates below
DSCF7517
and more panel masking
DSCF7518
DSCF7519
DSCF7520
Die Wanna Wanga !
Looking very nice, can’t wait to see the end result!
