Mancunian airman
Bomb trolley size ??
Hi all
I am soon to commence a 48th scale Mosquito and I noticed in the Airfix kit that there is a 4,000Ib bomb :clap:
I would consider scratch building a trolley for this but dont have any idea of the size.
I suppose the smaller Airfix bomb trolley in their Bomber supply kit (72nd) could be scaled up BUT I dont know if its even the right type . . . .
Has anybody got the 'Flightpath ' version in 48th who could give me some dimensions: length, width and size of wheels/tyres please
in anticipation :tmi:
Ian
Measurements from mine:
frame length - 112mm
     “.    Width - 24mm
width to outside of wheels - 33mm
wheel diameter - 10mm
drawbar length - 22mm
frame width is slightly varied (probably due to my poor folding skills) but 24mm is taken across the frame just in front of the rear axle.
Thank you Gordon
Just two other question, is the frame girder type with an open frame other than the supports ?
Do you have a photo of yours please  ?
Ian
44 minutes ago, Mancunian airman said:
Thank you Gordon
Ian
11 hours ago, Mancunian airman said:
Hi all
Ian
The real Type C  bomb trolley (That was the type used for 4000lb cookies ) was 15ft 8" long and 4ft 0" wide.
Selwyn
Sadly I don’t have a photo (partly because I don’t use Flickr photobucket etc) As modelled by Flightpath the rear section is an X shape open frame, the rest is a solid floor. The dimensions as I’ve made mine is 24mm length by 20mm wide open area, the cross X brace 2mm wide and starting from the solid floor which ends 24mm from the rear axle, so there is an unbraced section approx 3mm long in front of the rear axle. The last support is at the very end of the solid floor, the supports are 23mm apart. Once the Cookie is on, very little is visible apart from the X braces, supports and front tapering section.
hope that all makes sense?
Selwyn
So according to those dimensions Selwyn (if my maths is correct) and assuming the width is frame not across the wheel the Flightpath C Trolley scales out exactly right width wise, but is around 13mm (or 2’ too long?)
15ft 8" long is the trolley overall length, not the length of the frame.
Selwyn
Selwyn
So by the time the drawbar is included it’s even longer than it should be?
I would have thought so.
Selwyn
Type C trolley has a wheelbase of 14ft 3 1/2ins, a wheel track of 3ft 5ins. Tyres are 18X7ins.
Type D trolley has a wheelbase of 14ft 8ins, a wheeltrack of 3ft 5ins. Tyres are 18X 7ins also. Both can carry one 4000lb bomb. I would post up the relevant AP pictures but don't seem to be able to do so.
you  might have already seen these already Ian  but just in case
@Selwyn  and @Ossington  maybe able to give some details on the trolleys shown
3847848155_584cb0f07f_o.jpgLancaster Bomber by Etienne du Plessis, on Flickr
also of  note (from the link) there is a Manchester in the background.
3803548561_36fea8f914_o.jpgLancaster. by Etienne du Plessis, on Flickr
4759613403_4ed9b99d65_o.jpgHalifax Mk. II by Etienne du Plessis, on Flickr
3603569783_eebc03d543_o.jpgMosquito mk. B IV by Etienne du Plessis, on Flickr
I'm putting these up as the colours maybe of use?
the DVD Night Bombers is all wartime colur and has much footage on preparing the Lancasters
https://www.amazon.co.uk/Nightbombers-DVD-H-I-Cozens/dp/B0001GNJK6
here's a clip of servicing  but the rest is like this
HTH
T
Edited by Troy Smith
tidying up, corrections
Here are a couple of pics of Mosquitos getting a cookie:
edit: here is another one:
Jari
Edited by Finn
Many thanks for all those replies, needless to say I have a pretty good idea about the thing now. a couple of bomb trolleys should soon make an appearance B)
Just a small point, the Flightpath example appears to have a 'solid' bottom whereas all the photos show this was not the case . . .
Your description coupled with the photos makes sense
Thank you.
Ian
Some nice colour variations on those bombs and evidence that they had a lot of rough handling before they got to the aircraft.
made me look again (I  was just looking for  trolleys)
note  the part buff/part black fins here
Re the Night Bombers film,
I was in that Hangar on Sunday.
(No 1 Hangar, RAF Hemswell, Lincs)
Jari
Sadly I couldn't access that without being a member . . .
EDIT
Was able to view it the 2nd attempt.
Very useful stuff, have you got a download for the 'D' type I wonder ??
thanks again
Ian
Edited by Mancunian airman
It opened straight away for me?
8 hours ago, Mancunian airman said:
Jari
EDIT
thanks again
Ian
I just happened across that one, haven't seen any others.
Jari
