Hockeyboy76 Posted December 3, 2017 Author Share Posted December 3, 2017 7 minutes ago, nimrod54 said: That's looking good buddy, I bet that opening the vents took a while - I hope that all your fingers are intact. Cheers dude, All fingers accounted for, quite a few extra nicks tho. Not sure if that’s DIY or model related. Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted December 9, 2017 Author Share Posted December 9, 2017 Got some paint on some of the components yesterday. Not technically correct, but I have used Ford Moondust silver for the engine & chassis , Humbrol 53 for the gearbox, and tamiya silver for some engine gubbins. I also primed the body work, which has now shown every slip of the razor saw opening up the grills. Guess I’m back to sanding. 1 Link to comment Share on other sites More sharing options...
Ratch Posted December 18, 2017 Share Posted December 18, 2017 Looking forward to seeing pix of this classic racer 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 2, 2018 Author Share Posted January 2, 2018 Happy New Year fellow modellers. Time to get cracking & to keep @nimrod54 happy, it’s time for some Albion alloy spark plugs. Can you see them? now to this and finally all plugged up Engine and gearbox attached. A little more wiring to do then can crack on with the rest of the car. 3 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted January 2, 2018 Share Posted January 2, 2018 So that's what has taken all of your time up. 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 2, 2018 Author Share Posted January 2, 2018 9 minutes ago, nimrod54 said: So that's what has taken all of your time up. It’s got working pistons inside!🤫 2 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 4, 2018 Author Share Posted January 4, 2018 A little more progress Engine attached to chassis The gold is AKs True Metal gold. It’s great stuff & it hasn’t even been buffed yet. What an evening awaits! 4 Link to comment Share on other sites More sharing options...
nimrod54 Posted January 4, 2018 Share Posted January 4, 2018 Fab job on that engine H, and it looks great in situ within the chassis. 1 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 4, 2018 Author Share Posted January 4, 2018 Cheers dude. Looking forward to cracking on with the body work now. A lot of scratches to eliminate around the opened louvred, grills etc. Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 7, 2018 Author Share Posted January 7, 2018 A little more progress today The last picture is the body work under a first coat of Tamiya TS17 gloss aluminium. Needs a rub down and respray, preferably somewhere warmer than the man garage! 6 Link to comment Share on other sites More sharing options...
nimrod54 Posted January 7, 2018 Share Posted January 7, 2018 Well done on sorting out the body H, looks as though you were able to sort the scratches out, The Chassis is looking good too, wheels on soon? 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 7, 2018 Author Share Posted January 7, 2018 (edited) 2 hours ago, nimrod54 said: Well done on sorting out the body H, looks as though you were able to sort the scratches out, The Chassis is looking good too, wheels on soon? Cheers dude. Hope to get them on soon, sticking with the kit wire wheels as they look pretty good under a coat of silver. Body works the priority tho & scratch building new wing mirrors and screen. Edited January 7, 2018 by Hockeyboy76 2 Link to comment Share on other sites More sharing options...
Peter Lloyd Posted January 9, 2018 Share Posted January 9, 2018 Looking amazing. It's hard to get spark plugs that small to screw in without cross-threading the plug hole, isn't it? 2 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 10, 2018 Author Share Posted January 10, 2018 13 hours ago, Peter Lloyd said: Looking amazing. It's hard to get spark plugs that small to screw in without cross-threading the plug hole, isn't it? It’s even harder to check for a spark!🤔 Thanks for the kind comments. 1 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 10, 2018 Author Share Posted January 10, 2018 Having a few fit issues at the moment. With the fuel tanks installed into the lower tub, the seat back bulkhead now fails to fit & leaves a big gap between upper & lower tubs. Also having fitted the tanks I have made it exceptionally hard to fit the exhausts, which I left off to replace with alloys. New plan is to fit the kit parts and as I can’t find my micro drills after the move and paint the tops black to give the impression of exhaust holes. 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted January 10, 2018 Share Posted January 10, 2018 6 hours ago, Hockeyboy76 said: Also having fitted the tanks I have made it exceptionally hard to fit the exhausts, which I left off to replace with alloys. New plan is to fit the kit parts and as I can’t find my micro drills after the move and paint the tops black to give the impression of exhaust holes. Sorry to hear about fit issues H. On older vehicle kits I have often used short lengths of tubing - sliding these over the kit parts for exhausts and hiding the junction behind body panels. Admittedly they have generally been single exhaust jobs, so I am not sure how easy it would be to do that in this case, but it may be another possibility. Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 10, 2018 Author Share Posted January 10, 2018 58 minutes ago, nimrod54 said: Sorry to hear about fit issues H. On older vehicle kits I have often use short lengths of tubing - sliding these over the kit parts for exhausts and hiding the junction behind body panels. Admittedly they have generally been single exhaust jobs, so I am not sure how easy it would be to do that in this case, but it may be another possibility. Was going to do that with this one dude. I don’t have any tubing wide enough to cover the kit parts / fit the six exhaust stacks per side. Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 11, 2018 Author Share Posted January 11, 2018 Well I was really enjoying this build until I tried to join the top and bottom body work together. After trimming the seat bulkhead to fit over the fuel tanks I managed to get the front halves to join, so they were superglued & clamped. But try as I may, I couldn’t get a decent fit on the rear, and to make matters worse, the engine seems to be sitting too high & the engine cowling doesn’t fit. The engine can’t sit any lower in the chassis & it’s nothing to do with my wiring. I was planning to display it with the cowling off, now I have no choice! Getting closer to completion, just some tidying up of filler around the rear bodywork and a scratch built windscreen to make. 2 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 13, 2018 Author Share Posted January 13, 2018 Getting closer to the finish line. 7 Link to comment Share on other sites More sharing options...
nimrod54 Posted January 14, 2018 Share Posted January 14, 2018 Coming along nicely now buddy, it's a shame that the top cover won't play the game and lie down properly because the fit looks great off the chassis. Your plan to display it with cover off is a good one, it would be a pity to hide all of that engine work. 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 15, 2018 Author Share Posted January 15, 2018 Thanks to @Rabbit Leader for the photo of the windscreen. My clear parts and decals are missing so time to scratch build a screen, using some clear plastic and some left over PE from the spares box These make this Got to be happy with that. It was my third attempt at the plastic, first one was the wrong size and shape, second much better but pinged off to the carpet monster. Strange he’s here as we have wood flooring! 3 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 17, 2018 Author Share Posted January 17, 2018 (edited) SPOILER ALERT Well almost Edited January 17, 2018 by Hockeyboy76 3 Link to comment Share on other sites More sharing options...
nimrod54 Posted January 17, 2018 Share Posted January 17, 2018 Nope, try as I might - I still can't see a spoiler. 2 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted January 17, 2018 Author Share Posted January 17, 2018 1 hour ago, nimrod54 said: Nope, try as I might - I still can't see a spoiler. As you’ve got your 🧥, I will show you the 🚪 1 Link to comment Share on other sites More sharing options...
Ratch Posted January 17, 2018 Share Posted January 17, 2018 This must be some inside joke 2 Link to comment Share on other sites More sharing options...
