Old Viper Tester Posted October 6, 2017 Share Posted October 6, 2017 (edited) In the 1970s and '80s, the USAF Test Pilot School (TPS) used the A-37B for both aircraft performance test and departure/spin test instruction. For the performance test portion of the curriculum students would collect test data to define takeoff and landing, cruise, and climb performance. To make it interesting, all the up and away testing was accomplished single engine. For departure/spin instruction, the A-37 was used for demonstrating departure entry techniques and handling peculiarities of wing-loaded (as opposed to fuselage-loaded) aircraft. Spin instruction began with glider flights using the Blanik L-10. Instruction then moved to the A-37 with TPS instructors in the right seat for student test pilot flights, instructors in the left what for student flight test engineer flights. Student test pilots would then progress to the YA-7D to demonstrate departure, spin, and spin recovery techniques. The spin program is the reason for the black stripe on the right wing. This was to aid ground-based optical trackers determine aircraft attitude during the maneuvers. The A-7s had black triangle outlines on the wing upper surfaces to distinguish between the top and bottom of the aircraft during tracking. Hasegawa/Minicraft issued the A-37B kit in the late 1970's with TPS markings. As I remember it, the markings in this kit were pretty crude and did not include the Yaw and Pitch Sensor (YAPS) boom that replaced the nose-mounted air refueling probe. Ready to take Runway 22. No mini-gun muzzle outlet - flight test instrumentation has replaced the mini-gun in the nose compartment. Cruising to the designated spin area. Fuel jettison the aid ground-based optical trackers acquire the aircraft on the run-in to the spin area. Good views of the nose mounted YAPS boom. Return to base. Over the north shore of Rogers dry lake looking south. Lakebed runways and compass rose (bottom of image) are marked with a black oily mixture. Thats the approach end and "last chance" area for Runway 22 to the right of the left tip tank. Thanks for looking, Sven Edited October 6, 2017 by Old Viper Tester grammar 11 Link to comment Share on other sites More sharing options...
72modeler Posted October 6, 2017 Share Posted October 6, 2017 Sven, What an awesome scheme! Never seen that one before- thank you for sharing it. It would look great next to my F-16B in Edwards AB markings! Mike Link to comment Share on other sites More sharing options...
