Ozzyman69
Triple AVRO 707 (A,B,C) British fighters&research; 1/72
Hello for everyone.
When an idea is presented, we analyze the feasibility and design technician solution containing all basic elements of the new product and new models project.
I have the pleasure to welcome all modellers, guests, participants and friends to the fourth of my WIP here on a forum and to the new one topic.
I am looking at the watch, getting a bit worried because I think it is necessary to inform you today about how I intend to approach the work on for the triple AVRO 707 assembly. To tell the truth, I really like a British aircrafts and jet fighters also.
The first step is still created in the traditional way:
-          Open boxes;
-          Spare parts inspection for the general condition;
-          Read the manual;
-          Close the boxes and forget all above (especially text instruction content)...
To be continue...
Best regards.
Andrii
Edited by Ozzyman69
Well.
Hello, friends! The result of British fighters and research aircraft WIP by resin kits here in images.
The fuselage internal cockpit parts are installed into and the halves are connected between each other
By the way, it is a good quality for the resin kit.
To be continue.
Andrii
I`d like to know what have been the result after the adhesive resin compound cure time. I am checking it right now.
From my point of vew it is OK.
There's some lovely work going on here Andrii, I can't wait to see the end results.
6 hours ago, Lowbrow said:
What is the blue stuff on the join lines?
Hello, @Lowbrow! That`s a good question. I applied a two-components epoxy glue for that. :welcome:
Andrii
Oh, all right, thanks for the comment, Chris! :) I expect a positive result as well.
Looking great!
16 minutes ago, Maverick231 said:
Looking good!
I like the Avro 707 and would very much like to do exactly what your doing here.
A good team is the key to success:thanks:
Best regards.
Andrii
14 minutes ago, Ex-FAAWAFU said:
Looking great!
So far so good, Thanks a bunch for your support.
Thank you friends for visiting this page and for a positive comments.
So.
I have continue to work again.
To prevent entering from dust (I expect to do some corrective action of joint lines with dry sanding) to the cockpit area, it is necessary to prepare and then close by transparent parts as well.
And the original glare-shields are replaced by other material (black tape will be better).
To be continue.
Best regards
Andrii
Edited by Ozzyman69
:cowboy:
I`ve done some of routine work for today.
Canopies had installed already for all three aircraft fuselages (I used the "Faller" super - expert glue for that).
Please ignore the remnants of glue on joint lines. I will soon be correcting. The glue surface must be excessive application for acetate clear parts (with thin wall structure) security of installation.
The engine (for "B" version) inlet fairing assy after adjustment of gap between body and mounting flange is OK .
I`ve done smoother (around canopy frame) for fillet making.
Hope that`s all right.
Best regards
Andrii
...a litle bit progress in the work:
Edited by Ozzyman69
Fantastic work here, these'll be great when finished.
Duncan B
Duncan B
Thanks. I`m going to try do it great. It takes too long time for me but I am not in a hurry.
Andrii
It`s nothing much today. I`ve just restored a bit of panels and lines after damaged by sanding.
The next task
Wing installation:
"Right hands up here under here"
" Now left hands UP"
Done.
Vertical fin and rudder assy installation
We probably need to get the extra epoxy glue off. It`s got to be cut out from the join lines.
 ...and from here
like this
I`ve done
Hello everybody!
So, I came home within two week after my Telford SMW 2017, Cosford RAF museum and Birmingham gorgeous trip. There are so many people on the show!!!
And all that together creates positive impression - one feel good inspiration. I think a modellers inspiration is in that direction.
I continue my WIP on this weekend.
Well, I`ve done some corrective action with all joint wing - to - body lines
The engines cowlings inlet lips are installed also.
The progress was slow, I know.
Cheers.
Andrii
Edited by Ozzyman69
WZ736 is at MOSI in Manchester. Many years ago I was part of the Technical Crew that used to "buff" the exhibits. I once got in the 707. There isn't a lot of room and visibility was terrible! I wouldn't have like to fly in it.
Here it is. Sadly the interior is gone, from memory I had to sit in a plastic chair from the canteen.
These are coming along nicely.  I knew about the differences in intake configuration (& obviously the side-by-side seats in the C), but I hadn’t realised how much the wing form varied.
It would all be done in computers and wind tunnels now, which is no doubt far safer & cheaper, but less fun for us modellers!
Andrii.
it's looking VERY NEAR and IMPRESSIVE
COMING along quite quickly and THANK you for clear photos too.
:goodjob:
:penguin:
Where did you get them from? And are they expensive?
